Motor Testing and Comparisons
#451
I've read some insights from this thread : Hobbywing G4R or Teampowers V5S ?
And one reply attracted my attention :
During my tests, I have noticed that a high torque motor is great for when you're on and off the throttle. If you're on a highspeed track where you're more on the throttle, less torquey motors have been better options. The high torque motors tend to get hotter on these types of tracks.
What attracts me the most in the G4R is the internal rotor fan and the fact it is a bit shorter than the TP. However, I would prefer to buy the motor with the best match for my track.
Thanks for your input !
G-rem
#452
Thanks for your reply and the work you do on your YT channel !
My main track is quite a large flowing 1/8 track (picture below for illustration). Knowing that I run on this track in 1/10 TC blinky 17.5t, and based on the inherent characteristics of both the HW G4R and the TP V6S (or even maybe the V5S), which one *should* be best suited to my needs ? Open to other brands / models as well if it makes sense.
G-rem
G-rem
- Surpass V6 Stock Spec
- REDS Pro Stock Factory Select
- Team Power V5S.
#453
Thank you very much for your input !
Just for my understanding, what are the characteristics of the HW G4r which don't match with the specific requirements ?
Also, can you confirm the that Surpass v6 and the TP v5s are basically the same, the later being "only" more expensive ?
G-rem
G-rem
#454
G-rem
G-rem
#455
G-rem
G-rem
#457
#458
Here's my video on adjusting the timing under a load. It makes a huge difference.
https://youtu.be/lpEiQAXa0us
PS: I am also betting that it probably took the motor less time to spin the load to the target 27krpm at 46.2* than at 52.8*...Also watch your gearmesh(looser is faster), bad spur gears, drivetrain vibrations, bad bearings, chassis rub, and unbalanced tires....
#461
G-rem
G-rem
I still find the TP v5s more of a small to medium track motor.
On a very large track it still doesn't have the top end of the HW G4R, no matter how you compensate in FDR, the HW still has a bit more top end since the V5s is more torque.
In the infield, I still found the v5s better than the G4R, but I lose 2-3 car lengths to them on the straights
The new TP V6s, seems to have similar torque to the old motor (actually the gauss ready is almost 100 gauss higher than the v5s), but the main thing is that it keeps up, matches or sometimes surpasses the G4R on the straights, but not by much.
I have played with the timing and FDR on the TP motor and it seems to like timing between 35-40. Anything much higher than 45 and the motor gets too hot and fades. You can run lower timing and lower FDR on the TP. While the HW prefers 45 timing or more and higher FDR since it has a lower spec rotor and lower gauss reading on the motor.
#463
532Likes
