Mini-96 World Challenge
#3331
Class- Pro Stock
Date- 10/31/25
Location- Austin, TX
Race Time- 428.6 seconds
Fastest Lap- 4.87 seconds
Chassis- MR-04 Evo2
Body- AMG GT3
Wheelbase- 98mm
Tires- Front Kyosho 30 degree slick Rear Kyosho 20 degree radial
Motor- 5600Kv brushless
Batteries- Kyosho Speed House
Front Springs- Kyosho Medium (Green)
T-Plate- Kyosho Carbon Soft
Motor Mount- Kyosho MM2 Aluminum Motor Mount
Dampener (If applicable)- Kyosho MM2 Aluminum Roll Damper
Dampener Fluid (If applicable)- N/A
Gearing- 6T
Notes- This is my first proper R/C car and had a ton of fun getting it all set up and tuned. Had a lot of fun working on bringing down my lap times and trying to get consistent. Gonna get a Box Stock build going for next month. Cheers!
Date- 10/31/25
Chassis- MR-04 Evo2
Body- AMG GT3
Wheelbase- 98mm
Gearing- 6T
#3332
Hey Guys,
HOPE Yall had a Safe and Fun Halloween!!
I had a few too many coldies watching the Nascar Playoffs and fell asleep! My laptop is still out for service so I tried setting up my track and running LapTrax on my iPad, but it would miss atleast 1 lap per 75 lap run, and after it missed 3 laps on my BoxStock run I got frustrated and quit! So I'll only have the 2 classes I ran in last week.
As for November/ December layout we're going to try Gerry Burr's roundabout layout! I tried it when he posted it and it was fun and different than anything else we have run!
Hope yall enjoy it, and I have a feeling we are going to have some very fast runs!!! I'll update the pic with arrow marker and corner numbers after my laptop is back. Im a dumb arse when it comes to doing stuff on my phone! Heck.I hope this post gets posted! LOL
#3333
Looks like we had a few new folks join us, WELCOME!!!!
I'm usually better at posting here and on Facebook, but with my laptop down, and being ignorant with my phone, I've been quite here! Sorry! It should be back this week, so I'll post here as usual.
I give everyone till the 3rd to get the runs they ran up till midnight on the last day of the month to post, and I'll tally and post the results on the 4th.
Hope yall enjoy the Roundabout layout!!
#3335
Well this was probably the busiest month of the year so far! Lots of work travel. I was only able to put in a little more than half the laps (just over 7,000) as I did in September. But in September I also had surgery so was getting in a lot with that. In the beginning I was struggling with CCW. I don’t race 1/10 oval too often but go CCW with that so I knew I would get it. The mini96 can be soo frustrating when you are pinging off the walls. I knew I just needed to keep at it to get my consistency back. I had the fast laps just couldn’t put it together. Both times are slower than last month but again with half the laps it’s not terrible. I ran 1,711 laps just yesterday (23 races) and had the pace for sure in 2WD to be sub 300 and close in box stock but it didn’t happen. Pretty upset with these results but will come back stronger this month!
Class- 2WD Open
Date- 10/29/25
Location- Elk Grove, CA
Race Time- 75/5:01.291
Fastest Lap- 3.469
Chassis- Reflex RX28 Gen2
Body- Rad Body
Wheelbase- 98mm
Tires- PN KSM Med F Marka V1 20deg Radial
Motor- HobbyWing 3500kv
Batteries- Reflex 400mah Lipo
Front Springs- Pink
T-Plate- N/A
Motor Mount- Kit
Dampener (If applicable)- Kit
Dampener Fluid (If applicable)- 30k Kyo
Gearing- PN-53/13
Notes- 63 degrees with 70% humidity
Class- Box Stock
Date- 10/29/25
Race Time- 75/5:06.856
Fastest Lap- 3.673
Chassis- MR03 Readyset
Body- Jom
Wheelbase- 98mm
Tires- PN KSK 40deg F / Marka V1 15deg R
Motor- Kyosho Stock
Batteries- Carrera F850
Front Springs- Kyosho Red
T-Plate- Spring Steel #2
Motor Mount- #7
Dampener (If applicable)- Stock
Dampener Fluid (If applicable)- Kyosho 30K
Gearing- 7T
Notes- Front Knuckles had 2x shims under to lower the ride height. Front tires have 22.6 Reflex rings. Moto. Did water break in on it for 45 mins. Batteries charged @ 1.5 amps. 65 degrees in garage with 68% humidity.
Class- 2WD Open
Date- 10/29/25
Fastest Lap- 3.469
Body- Rad Body
Wheelbase- 98mm
Front Springs- Pink
T-Plate- N/A
Motor Mount- Kit
Gearing- PN-53/13
Class- Box Stock
Date- 10/29/25
Fastest Lap- 3.673
Body- Jom
Wheelbase- 98mm
Motor- Kyosho Stock
Motor Mount- #7
Gearing- 7T
#3336
Class- Box Stock
Date- 10-16-25
Location-Omaha, NE
Race Time- 5:02.469
Fastest Lap- 3.756
Chassis- MR04
Body- Mclaren 12C
Wheelbase- 98MM
Tires- Kyosho 30 low height front Marka V1 10 Slick rear +1/+3 offsets
Motor- Stock
Batteries- Kyosho Speedhouse
Front Springs- Green
T-Plate- Kyosho FRP 6M
Motor Mount- MM
Dampener Fluid (If applicable)- 5k
Gearing- 7T
Notes- Best run I think I've had so far in the challenge. This is what happens when I'm left alone at home for a weekend.
Date- 10-16-25
Location-Omaha, NE
Race Time- 5:02.469
Fastest Lap- 3.756
Chassis- MR04
Body- Mclaren 12C
Wheelbase- 98MM
Motor- Stock
Motor Mount- MM
Gearing- 7T
#3337
Date- 10-16-25
Location- Omaha, NE
Race Time- 5:22.488
Fastest Lap- 3.718
Chassis- MR03 EVO
Body- Jomurema
Wheelbase- 98MM
Tires- Kyosho 30 low front Marka 10 Rear +1/+3
Motor- Green 4100
Front Springs- MR04 Orange
T-Plate- Kyosho Carbon soft
Motor Mount- MR04 MM
Dampener (If applicable)- PN Disc
Dampener Fluid (If applicable)- Kyosho 5k
Gearing- PN 9 or 10?
Notes- This car is great but I was not able to keep it together for many laps in a row. Tried again later in the month and wasn't any better. Still getting used to driving brushless.
Location- Omaha, NE
Race Time- 5:22.488
Fastest Lap- 3.718
Chassis- MR03 EVO
Body- Jomurema
Wheelbase- 98MM
Motor- Green 4100
#3338
Class- Porsche Stock
Date- 10-16-25
Location- Omaha, NE
Race Time- 5:28.001
Fastest Lap- 3.883
Chassis- MR03
Body- 911 GT3
Wheelbase- 90MM
Tires- Kyosho 30 Low Marka V1 10 Slick
Motor- Stock
Front Springs- Yello
T-Plate- Kyosho 6H
Motor Mount- RM
Dampener (If applicable)- Oil Shock
Dampener Fluid (If applicable)- 100
Gearing- 8t
Notes - Needed more time for a better run but this will have to do. Faster than last month.
Date- 10-16-25
Location- Omaha, NE
Race Time- 5:28.001
Fastest Lap- 3.883
Chassis- MR03
Body- 911 GT3
Wheelbase- 90MM
Motor- Stock
T-Plate- Kyosho 6H
Motor Mount- RM
Gearing- 8t
#3339
Class- Pro Stock
Date- 10-15-25
Location- Omaha, NE
Race Time- 5:07.758
Fastest Lap- 3.771
Chassis- PN2.5
Body- Jomurema
Wheelbase- 98
Motor- XSpeed black cap
Front Springs- Stock
Motor Mount- PN V4
Gearing- 8T
Notes - Surprised myself a bit how quick this car was at the start, but a busy month left me with no more time to improve. Time to mess around on a big track and come back to the challenge later!
Date- 10-15-25
Location- Omaha, NE
Race Time- 5:07.758
Fastest Lap- 3.771
Chassis- PN2.5
Body- Jomurema
Wheelbase- 98
Motor Mount- PN V4
Gearing- 8T
#3341
October 2025 Results
Hey Everyone, Im trying to do this on my phone, so bare with me. I think I got everything right!! I can barley see the page on my phone!! Damn I need new glasses!!! 🙈
Welcome Jarvz!!! Great to have another driver from around the world!! This month was a busy one for me, so i can just imagine what some.of yall.are doing! We didn't have a big participation, but we had some close lap times across multiple classes!! Great to see!!!
BurgerMaster (Cory Cliff) had a great open run of 301.291 / 3.469, and joelisenat was a top runner in multiple classes!! Congratulations Guys!!!
I really hope.yall enjoy Gerry Burr's "Roundabout" layout! To me its a blast and a fun change!! I forsee some sub 4 minute runs!!!
BOX STOCK
1) joelisenat ---------- 302.469 / 3.756
2) BurgerMaster---- 306.856 / 3.673
3) AM03GT------------ 316.757 / 3.953
4) BoxxerBoyDrew- 324.963 / 3.990
5) Jarvz----------------- 354.428 / 4.272
6) Mathew Bull------ 515.839 / 3.524
STOCK
1) AM03GT---‐------- 317.979 / 3.957
2) joelisenat--------- 322.488 / 3.718
PRO STOCK
1) joelisenat---------- 307.758 / 3.771
2) Mr. Sean H-------- 428.600 / 4.870
NARROW
1) BoxxerBoyDrew--------- 327.254 / 3.943
2) Mathew Bull-------------- 491.132 / 5.348
PORSCHE
1) joelisenat---------- 328.001 / 3.883
2) Mathew Bull------ 495.922 / 5.402
OPEN 2WD
1) BurgerMaster---- 301.291 / 3.469
2) AM03GT‐----------- 327.756 / 3.887
BOX STOCK
STOCK
PRO STOCK
NARROW
PORSCHE
OPEN 2WD
#3342
How is everyone liking the new layout??! It’s super fast. Not hard to put down a pretty consistent run but if you have any bad laps you know that it’s not gonna stick! Fast lap for me is 2.77 in Open and 2.97 in Box Stock!
#3343
Hey Yall,
I got my laptop back from service, and they were able to repair it at no cost and didn't have to wipe my hard drive!! Thanks Geek Squad!
Anyway, my back is FINALLY letting me get some driving in, and I have been trying to get my GLR and Porsche dialed in. My 911 is in Traction Roll City and is wanting to stay there! I have an order on the way with a new 911 body, so hopefully it will be lighter than my Old release 911! My GLR had a bad on power push in the front! The front would plow threw turn 1 and the loop. It was on Marka V1R05 and PN KS 1138 with a 12C body. Well I didn't figure the 12C to last long at these speeds and having repaired the front left fender twice already, but it helped on this layout over the MakoX Lexan. So I first went to V1R10 rears and it helped, then went to PN KS 1142 Low Hight Hard fronts on +1.5, 19mm Flanged PN, and it was very good, BUT then I smacked the outside wall getting back onto the straight and cracked the repair and popped the light bucket out. So after doing some looking and weighing, I decided to go back to "The Ghost" my White Jomu with Lexan roof and wing, as it's the same weight as the 12C with a even lower CG with the Lexan roof!
All I can say now is WOW!!!!!! It is freakin running, and I am now able to run comfortable 2.8xx second laps and hit my fastest on this layout so far at a 2.790!!!
SUPER GOOD for me!! I ran in a endless practice, so no 75 lap time, but even with 5 or 6 TR where I landed on my Lid and had to get up and flip it, which usually was a 12-18 second lap, I had a 3.4 second avg. over 181 laps!
It will TR on the Hard fronts, and I have plenty of Disk wheels, but I just had these PN wheels taped and ready to go, so I used them. I might try with disks to see if I can get rid of the TR, but I'll live with it to have it drive as well as it is! Kind of scared to touch it!
It's raining here now, so the humidity is up to 66% @70.5*. Its a little higher than it has been so maybe the TR will calm a bit when it returns to 55-60% it usually is this time of year!
Now I have my Laptop I'll be here more often! I find rctech easier to navigate on my Laptop vs. my Phone.
Anyway, hope Yall are having fun in this twisty layout!!!
It will TR on the Hard fronts, and I have plenty of Disk wheels, but I just had these PN wheels taped and ready to go, so I used them. I might try with disks to see if I can get rid of the TR, but I'll live with it to have it drive as well as it is! Kind of scared to touch it! It's raining here now, so the humidity is up to 66% @70.5*. Its a little higher than it has been so maybe the TR will calm a bit when it returns to 55-60% it usually is this time of year!
#3344
Well I got a Wild Hair this morning and thought if the extra weight of the Jomu body helped the GLR on this layout, I wonder if the PN Concept C9 body would be even better? The "Ghost Jomu" weighs 2X.XXg while the C9 is 3X.XXg. ( I'll get exact weights in a bit) And BOY did the extra weight help! The car rips the corners with no TR, and is very stable on the straight! I LOVE the look of this body, but never really cared for it as I had TR issues with it compared to a Lexan Roof Jomu, BUT on this track it is the CHIT!!! I ran a sub 4 minute run with multiple 2.7xx laps. I had a few mental mistakes after running long strings and the announced long string laps makes me forget about smooth driving, and I start worrying about screwing up!
I slid it into the outside corner wall and was slow to get it unstuck, so a few +5 second laps, but a FAST run for me!! I'm HAPPY!!!
Class- OPEN 2WD
Date- 11/22/2025
Location- Central Texas
Race Time- 234.008 / 3:54.008
Fastest Lap- 2.773
Chassis- GL GLR
Body- PN Concept C9
Wheelbase- 98mm
Tires-F- PN KS Hard LH (KS1142)/ R- Marka MZR-V1R05
Wheels- F- N+1.5mm 19mm PN 6Hole Flanged White / R- W+3mm 20mm 3D Disk wheels Black (no disk)
Motor- GL 3500kv
Batteries- GNB 350mAh 2S LiPO
Front Springs-Purple
T-Plate-N/A
Motor Mount-GL 98mm
Dampener (If applicable)- Short Center Shock (Blue Spring) / Yellow side springs
Dampener Fluid (If applicable)- 15K Kyo grease- Center / Sides
Gearing- 10/52 GL Ball Diff
Notes- Adding this for now, but HOPE to have a cleaner run before the end of the month!
The track humidity is at 75% @ 68.3*F. Just a hit of TR if I over drove turn 1 and slammed on the brakes while turning sharp, but other than that its FREAKIN RUNNING!!! Every once in a while those wild hairs pays off, though they usually got me in trouble!
Drive Fast!
I slid it into the outside corner wall and was slow to get it unstuck, so a few +5 second laps, but a FAST run for me!! I'm HAPPY!!!Class- OPEN 2WD
Date- 11/22/2025
Fastest Lap- 2.773
Chassis- GL GLR
Body- PN Concept C9
Wheelbase- 98mm
Motor- GL 3500kv
T-Plate-N/A
Motor Mount-GL 98mm
Drive Fast!
3036Likes
