Mini-96 World Challenge
#3091
Class- PROSTOCK
Date- 05/31/2025
Location-Central Texas
Race Time- 269.142 / 4:29.142
Fastest Lap- 3.001
Chassis-PN 2.5W/04EVO board/ 04 Arms/ Nexx knucks
Body- White Jomurema Lexan Roof
Wheelbase- 98mm
Tires-F- Reflex 45* LH slicks/ R- Reflex 30* Radials
Wheels- F- N+1mm 20mm PN BBS Yellow / R- W+2mm 20mm PN Yellow BBS
Motor-PN Anima 5500Kv
Batteries-Eneloop
Front Springs-Green
T-Plate-Nexx #5 Carbon
Motor Mount-PN Multi Mount
Dampener (If applicable)- PN DDS (Green top/Gold bottom springs) PN Dual Spring Top Shock silver springs
Gearing- 8/52 PN Ball Diff
Notes- FREAKIN RIPS!!! Was actually running better than my GLR! Best 98mm chassis I ran today!
Date- 05/31/2025
Fastest Lap- 3.001
Wheelbase- 98mm
Batteries-Eneloop
Front Springs-Green
#3092
Class- OPEN 2WD
Date- 05/31/2025
Race Time- 260.456 / 4:20.456
Fastest Lap- 2.961
Chassis- GL GLR
Body- Green Jomurema Lexan windows
Wheelbase- 98mm
Tires-F- KS1042 (regular height KS firm 42* sidewall glued) / R- Marka V1R10
Wheels- F- N+1mm 19mm PN Dish White / R- W+2mm 20mm PN Yellow BBS
Motor- NHX 2500Kv
Batteries- GNB 350mAh 2S LiPO
Front Springs-Blue
T-Plate-N/A
Motor Mount-GL 98mm
Dampener (If applicable)- Short Center Shock (Blue Spring) / Yellow side springs
Dampener Fluid (If applicable)- 25K Atomic grease- Center / 15K Atomic grease- Sides
Gearing-10/53 GL Ball Diff
Notes- Had MAJOR glitching issues most of the month! I moved the RX multiple times, changed batteries, bodies, but I couldn't get it to go away. Until I moved the antenna wire (ridged wire flysky rx) out from over the top of the rx, and BAM! No more glitching!!!!
Need to work on the ESC settings to get through the corners better (drag brake, forward punch).
Date- 05/31/2025
Fastest Lap- 2.961
Chassis- GL GLR
Wheelbase- 98mm
Motor- NHX 2500Kv
Front Springs-Blue
T-Plate-N/A
Motor Mount-GL 98mm
#3093
Class- PORSCHE
Date- 05/31/2025
Race Time- 265.459 / 4:25.459
Fastest Lap- 3.187
Chassis-MR03EVO
Body-Porsche 911 GT3 RSR
Wheelbase-90mm
Tires-F- PN KS Medium LH / R-PN KSK Soft Slicks
Wheels- F-PN N +1mm 19mm White Delrin Dish / R-PN W 0mm 20mm Yellow BBS
Motor-Rocket 3500Kv
Batteries-Eneloop
Front Springs- PN White
T-Plate-Kyosho #5M white fiberglass
Motor Mount-Nexx 90/94mm RM
Dampener (If applicable)- PN DDS (no top disk/Purple bottom springs) PN Dual Spring Shock ( Purple front/Red Rear)
Gearing-12/53 PN Gear Diff
Notes- 911 was running well, though I had to back it down a bit to fight TR!
Date- 05/31/2025
Fastest Lap- 3.187
Chassis-MR03EVO
Wheelbase-90mm
Motor-Rocket 3500Kv
Batteries-Eneloop
#3094
Class- NARROW
Date- 05/31/2025
Race Time- 261.671 / 4:21.671
Fastest Lap- 3.129
Chassis-MR03EVO
Body- Yaris
Wheelbase-90mm
Tires- F-PN KS Medium LH / R- PN KSK 40* LH worn to 22.4mm
Wheels-F- PN N 0mm 19mm White Delrin Dish / Kyo N 0mm 20mm White RE30
Motor-PN 3500Kv
Batteries- SpeedHouse 800HV
Front Springs-Kyo Orange (soft and short) on Inner Tube Shock Set
T-Plate-Nexx #4
Motor Mount-Nexx 90/94mm MM
Dampener (If applicable)- PN DDS (NO top DISK/Green bottom spring), Nexx Racing dual spring top shock (yellow main spring)
Gearing- 12/53 PN Ball Diff
Notes- The Yaris was the best car tonight hands down with the MX-5 next, then the Pro Stock. Had a few rolls, but it landed rubber side down both times! SUPER FUN!!!
Date- 05/31/2025
Fastest Lap- 3.129
Chassis-MR03EVO
Body- Yaris
Wheelbase-90mm
Motor-PN 3500Kv
T-Plate-Nexx #4
#3095
Class- MX-5 Unofficial Open
Date- 05/31/2025
Race Time- 259.521/ 4:19.521
Fastest Lap- 3.124
Chassis-MR04 EVO
Body-Mazda MX-5
Wheelbase-90mm
Tires-F- PN KS-M Medium LH / R- PN KS-M Soft LH
Wheels-F- PN N +1mm Yellow BBS / R- DXR MP1 W -1mm 20mm Carbon Black
Motor-PN 3500Kv V4
Batteries- Eneloop 850HV
Front Springs- Kyo Purple
T-Plate-Nexx #5
Dampener (If applicable)- PN DDS (Purple top/Green bottom springs)
Gearing-13/53 PN Ball Diff
Notes- Nexx Alum 0* Knucks, N0 tie rod,
I wanted to be under 4:20 in the Brushless classes, and I got close in most, but succeeded here! Wasn't feeling the best today, so with a clearer head I probably could have donr it in others. Serves me right for not running 75 lap runs all month, instead of running in open ended practice! I had some runs mid month that would have been in the 4:10s! Anyway, ya live and learn.
Date- 05/31/2025
Fastest Lap- 3.124
Chassis-MR04 EVO
Body-Mazda MX-5
Wheelbase-90mm
Motor-PN 3500Kv V4
T-Plate-Nexx #5
#3096
***no pics because it won’t let me still😡***
Class- Porsche cup
Date- 5/31/25
Location- Omaha
Race Time- 4:46.280
Fastest Lap- 3.191
Chassis- mr04 rm
Body- Porsche 911gt3
Wheelbase- 90mm
Tires- front: pn lowpro slick medium rear: Marka slick v1r15
Motor- Kyosho xspeed 4100
Batteries- speedhouse
Front Springs- green
T-Plate- medium carbon
Motor Mount- nexx racing RM
Dampener (If applicable)- nexx racing
Dampener Fluid (If applicable)- na
Gearing- 7 tooth
Notes-
Class- Porsche cup
Date- 5/31/25
Location- Omaha
Race Time- 4:46.280
Fastest Lap- 3.191
Chassis- mr04 rm
Wheelbase- 90mm
Gearing- 7 tooth
Notes-
#3097
still not allowed to post pics but here is box stock
Class- box stock
Date- 5-31-25
Location- Omaha
Race Time- 4:39.498
Fastest Lap- 3.042
Chassis- mr04 MM
Body- c8 corvette
Wheelbase- 98mm
Tires- Front: pn lowpro 8.5 medium slick Rear: Marka 11 v1r15 slick
Motor- white cap stock
Front Springs- stock black hard
T-Plate- stock
Motor Mount- stock
Dampener (If applicable)- na
Gearing- 7 tooth
Notes-
Class- box stock
Date- 5-31-25
Location- Omaha
Race Time- 4:39.498
Fastest Lap- 3.042
Chassis- mr04 MM
Body- c8 corvette
Wheelbase- 98mm
T-Plate- stock
Motor Mount- stock
Gearing- 7 tooth
Notes-
#3098
Class-box stock
Date-05-31-2025
Location- Kingsport, Tennessee
Race Time- 305.980 5:05.980.
Fastest Lap- 3.520
Chassis- mr-04
Body- Corvette
Wheelbase- 98mm
Tires- PN Racing super soft front and radial rear
Motor- kyosho stock
Batteries- Ni-MH AAA 1.2v 750mah
Front Springs- orange
T-Plate- PN #4
Motor Mount- mm
Gearing- 7t / stock diff
Date-05-31-2025
Fastest Lap- 3.520
Chassis- mr-04
Body- Corvette
Wheelbase- 98mm
Motor- kyosho stock
T-Plate- PN #4
Motor Mount- mm
#3099
Class - Box Stock
Date - 5/31/2025
Location - Iowa
Race Time - 269.627
Fastest Lap - 3.001
Chassis - MR-04 MM
Body - McLaren 12C
Wheelbase - 98mm
Tires - PN KS Medium on 20mm F1 flanged wheels, no tape / Marka 15° Radials R2 wheels
Motor - Stock
Batteries - Orion 750 SHO
Front Springs - Stock
T-Plate - Kyosho Carbon Firm
Motor Mount - Stock
Dampener (If applicable) -
Dampener Fluid (If applicable) -
Gearing - 7T, stock diff
Date - 5/31/2025
Location - Iowa
Race Time - 269.627
Fastest Lap - 3.001
Chassis - MR-04 MM
Body - McLaren 12C
Wheelbase - 98mm
Motor - Stock
Motor Mount - Stock
#3100
Class - Pro Stock
Date - 5/31/2025
Location - Iowa
Race Time - 241.696
Fastest Lap - 2.862
Chassis - MR-04 MM Evo2
Body - McLaren 12C
Wheelbase - 98mm
Motor - Kyosho Black Cap
T-Plate - Kyosho Fiber Firm
Motor Mount - Stock
Dampener (If applicable) - Kyosho Oil Damper
Dampener Fluid (If applicable) - Stock
Gearing - 9T, ball diff
Date - 5/31/2025
Location - Iowa
Race Time - 241.696
Fastest Lap - 2.862
Body - McLaren 12C
Wheelbase - 98mm
Motor Mount - Stock
#3102
Looks like we had a few new drivers and some returners. GREAT to have Yall!!!
I'll give it till 3rd and I'll post the May results to give everyone time to post their runs.
Thanks for participating and I hope Yall had FUN!
Same layout as May but CCW (Counter Clock Wise).
#3103
Class-box stock
Date- May 2025
Location-Sydney
Race Time-5:01.39
Fastest Lap- 3.59
Chassis-MR04
Body- Jomurema
Wheelbase-98mm
Tires-Marka front and rear
Motor-stock brushed
Batteries-Kyosho AAA
Front springs-stock
Rear springs -stock
Dampener (If applicable)-None
Dampener Fluid (If applicable)-none
Gearing- stock
Notes- none
Date- May 2025
Location-Sydney
Race Time-5:01.39
Fastest Lap- 3.59
Chassis-MR04
Body- Jomurema
Wheelbase-98mm
Motor-stock brushed
Front springs-stock
Rear springs -stock
Gearing- stock
Notes- none
#3104
Class- stock
Date- May 2025
Location-Sydney
Race Time- 4:55.67
Fastest Lap- 3.48
Chassis-MR04
Body- Jomurema
Wheelbase-98mm
Motor-stock brushed
Front springs-stock
Rear springs -stock
Gearing- stock
Notes- none
Date- May 2025
Location-Sydney
Race Time- 4:55.67
Fastest Lap- 3.48
Chassis-MR04
Body- Jomurema
Wheelbase-98mm
Motor-stock brushed
Front springs-stock
Rear springs -stock
Gearing- stock
Notes- none
#3105
Open 2WD
Date- May 2025
Location- Switzerland
Race Time- 3:51.736
Fastest Lap- 2.757
Chassis-DS28
Body- XVR Stability
Wheelbase-98mm
Motor- 3500 KV
Batteries- Reflex 400mah
Front springs- magnets
Rear springs -stock + magnets
Dampener (If applicable)-30K Kyosho (blue) in damper tub
Gearing- 14/53
Notes- DS28 Stock Spec - the ultimate 28th stock spec. race chassis proposed by VitaminZ RC
Date- May 2025
Race Time- 3:51.736
Fastest Lap- 2.757
Chassis-DS28
Body- XVR Stability
Wheelbase-98mm
Motor- 3500 KV
Gearing- 14/53
3036Likes
