Mini-96 World Challenge
#3031
Class-box stock
Date-04-30-2025
Location- Kingsport, Tennessee
Race Time- 398.050 6:38.050.
Fastest Lap- 4.460
Chassis- mr-03
Body- Corvette
Wheelbase- 98mm
Tires- PN Racing super soft front and radial rear
Motor- kyosho stock
Batteries- Ni-MH AAA 1.2v 750mah
Front Springs- orange
T-Plate- PN #3
Motor Mount- mm
Dampener (If applicable)-
Gearing- 7t / stock diff
Notes: Not enough runs this month. Time sucks.
Date-04-30-2025
Fastest Lap- 4.460
Chassis- mr-03
Body- Corvette
Wheelbase- 98mm
Motor- kyosho stock
T-Plate- PN #3
Motor Mount- mm
#3033
Porsche cup
Date 4/30/2025
Location- California
Race Time-329.60
Fastest Lap-4.03
Chassis-Kyosho
Body- 911 GT1
Wheelbase-90mm
Rear Radials
Front PN KSM soft slick
Motor-PN3500kv
Batteries- NHX 3500
T plate white fiberglass
Front springs PN Yellow
Could not find my good Porsche so had to run this one. Needs some setup help.
Date 4/30/2025
Race Time-329.60
Fastest Lap-4.03
Chassis-Kyosho
Body- 911 GT1
Wheelbase-90mm
Rear Radials
Motor-PN3500kv
Batteries- NHX 3500
#3034
Seeing you Porsche body reminded me, when looking at tires yesterday, I saw Kyosho is releasing MR04 ready sets with a Porsche 90mm and 102mm bodies! So I am wondering if they are going to rerelease them in white bodies? Not sure about the 102mm Porsche, but a new release 911 would be great! I LOVE my 911, but it's a old release body and heavy! Anyway, just curious!
#3035
Class- Box Stock
Date- 04/27/2025
Location- Irvine, CA
Race Time- 5:24.273 / 324.273
Fastest Lap- 4.037
Chassis- Kyosho MR03 Rwd
Body- Lexus SC430
Wheelbase- 98mm
Tires- FR (PN KSM538) / RR (Marka MZRV1R10)
Wheels- PN 10-Spoke 20mm F0 / PN 10-Spoke 20mm R2
Motor- Stock Silver Can
Batteries- PN Racing 900 mAh
Front Springs- PN Orange
T-Plate- PN #4 Spring Steel
Motor Mount- Stock Plastic
Dampener (If applicable)- Stock Center Shock
Gearing- 7T Pinion (PN Pro Match) / Stock Differential (44T)
Notes- Kingpin Flip
Date- 04/27/2025
Fastest Lap- 4.037
Body- Lexus SC430
Wheelbase- 98mm
Notes- Kingpin Flip
#3036
Class- Stock
Date- 04/30/2025
Race Time- 5:28.235 / 328.235
Fastest Lap- 3.972
Chassis- Kyosho MR03 EVO
Body- Jomurema GT01 (Lexan Roof)
Wheelbase- 98mm
Wheels- PN 16-Spoke 20mm F0 / PN 16-Spoke 20mm R2
Motor- PN 3500kv V3.1
Batteries- Reedy 800 mAh
Dampener (If applicable)- PN Disc Damper (Gold Top Spring/Blue Bottom Spring)
Gearing- 13T Pinion / Stock Diff with 64P Spur Mod (53T)
Notes- Kingpin Flip
Date- 04/30/2025
Fastest Lap- 3.972
Wheelbase- 98mm
Notes- Kingpin Flip
#3037
Class- Open 2wd
Date- 04/23/2025
Race Time- 5:25.508 / 325.508
Fastest Lap- 3.910
Chassis- Atomic MRX (Stock Frontend)
Wheelbase- 98mm
Wheels- Atomic S20 F-2 / Atomic S20 R2
Motor- Rocket 2500kv
Batteries- GaoNeng GNB 350mah LiPo
Front Springs- Atomic MRX Black
Front Shock Fluid- 30K
T-Plate- N/A
Motor Mount- Stock
Dampener (If applicable)- Stock Center Shock Atomic Brown Spring
Dampener Fluid (If applicable)- 30K
Side Shock Spring- Atomic Red
Side Dampener Fluid- 30K
Gearing- 10T Pinion / Stock Differential (53T)
Notes- ESC in "Blinky" zero-timing mode.
Date- 04/23/2025
Fastest Lap- 3.910
Wheelbase- 98mm
T-Plate- N/A
Motor Mount- Stock
#3039
Here's the layout for May/June! I wanted to try more layout ideas, but my back wouldn't allow it! This is very close to the track that got the most votes with a slight change to the stair step section to make it flow better! Anyway here yall go, and have fun!
MAY 2025 Clockwise (CW)
Put in corner numbers to easily identify your trouble spots to others.
#3040
On my GLR I turned down the steering and throttle D/R's 3 clicks (2 numbers adjusted per click on my NB4) and doubled the - expo from -20% to -40%, and I could rip around the new layout pretty quickly. This layout is going to favor smooth, rounded nose bodies, at least for me, as the turns come very quickly! I will probably run Jomuremas and MX-5s on most everything except for my 911.
I could switch my front tires to a less aggressive compound, as my steering d/r is at 50% with -40% expo. But it just drives so well, I don't want to screw it up!
Anyway I hope Yall have fun and the layout isn't too difficult!
#3041
Class-box stock
Date-April 2025
Location-Sydney
Race Time-6:09:96
Fastest Lap-4.54
Chassis-MR04
Body- Jomurema
Wheelbase-98mm
Tires-Marka front and rear
Motor-stock brushed
Batteries-Kyosho AAA
Front springs-stock
Rear springs -stock
Dampener (If applicable)-None
Dampener Fluid (If applicable)-none
Gearing- stock
Notes- none
Date-April 2025
Location-Sydney
Race Time-6:09:96
Fastest Lap-4.54
Chassis-MR04
Body- Jomurema
Wheelbase-98mm
Motor-stock brushed
Front springs-stock
Rear springs -stock
Gearing- stock
Notes- none
#3042
Class- AAA stock
Date-April 2025
Location-Sydney
Race Time-6:08:59
Fastest Lap-4.52
Chassis-MR04 Evo2
Body- Jomurema
Wheelbase-98mm
Motor-3500kv
Front springs-stock
Rear springs -stock
Dampener (If applicable)-next racing disk damper
Gearing- stock ball diff
Notes- Nexx racing alloy motor mount
Date-April 2025
Location-Sydney
Race Time-6:08:59
Fastest Lap-4.52
Chassis-MR04 Evo2
Body- Jomurema
Wheelbase-98mm
Motor-3500kv
Front springs-stock
Rear springs -stock
#3043
Class-2wd open
Date-April 2025
Location-Sydney
Race Time-6:14.14
Fastest Lap-4.49
Chassis-GL GTR
Body- PN C9
Wheelbase-98mm
Motor-stock brushed
Batteries-GL Lipo
Front springs-stock
Rear springs -stock
Gearing- stock
Notes- none
Date-April 2025
Location-Sydney
Race Time-6:14.14
Fastest Lap-4.49
Chassis-GL GTR
Body- PN C9
Wheelbase-98mm
Motor-stock brushed
Batteries-GL Lipo
Front springs-stock
Rear springs -stock
Gearing- stock
Notes- none
#3044
Enzo got here and it is SWEET!!! Love the purple, though I'll probably add some Gellow to it so I can see it on the RCP track better! Hope it runs as good as it looks!!!
update: after running I LIKE this body! I went to .5mm 19mm N fronts from 1.5mm to keep the wheels from snagging the walls, then raise the rear Axle to it's highest ride height position from my Stock Jomu setup, but it flat runs!!! I will get some Gellow on it ASAP as the lighting in the track room is not as bright as the workbench in the pic, so the purple might as well be black to my eyes. The purple is cool though!
#3045
APRIL RESULTS
BOXSTOCK-----------------------------------------------------------------------
1)chjosi-----------------307.054/3.722
2)Poor_Boy-------------309.780/3.610
3)AM03GT--------------324.273/4.037
4)BoxxerBoyDrew------331.153/3.993
5)danjoy25-------------369.960/4.540
6)Maaku0220-----------398.050/4.460
7)Fredoise85-----------468.380/4.940
STOCK----------------------------------------------------------------------------
1)Poor_Boy-------------296.080/3.590
2)BoxxerBoyDrew------318.235/3.776
3)AM03GT---------------328.235/3.972
4)danjoy25-------------368.590/4.520
PROSTOCK---------------------------------------------------------------------
1)Poor_Boy-------------300.580/3.690
2)BoxxerBoyDrew------323.966/3.874
OPEN------------------------------------------------------------------------------
1)Poor_Boy-------------279.080/3.390
2)BoxxerBoyDrew------308.437/3.709
3)AM03GT---------------325.508/3.910
4)danjoy25-------------374.140/4.490
5)CrazyFastFord--------406.375/4.338
6)Fredoise85-----------469.550/5.120
PORSCHE------------------------------------------------------------------------
1)Poor_Boy-------------329.600/4.030
2)BoxxerBoyDrew------341.222/3.999
NARROW-------------------------------------------------------------------------
1)BoxxerBoyDrew------327.611/4.014
2)Poor_Boy-------------331.430/3.840
MX-5------------------------------------------------------------------------------
1)Poor_Boy-------------331.430/3.840
2)BoxxerBoyDrew------338.519/3.932
AWD OPEN----------------------------------------------------------------------
1)Poor_Boy-------------317.800/3.750
2)Fredoise85-----------451.540/4.670
We had a good showing for April, all classes but the Stock86 was represented(and I know of only 1 person who has a 86mm body), and 6 OPEN cars!
Poor_Boy had the SMOKIN FAST LAP of 3.390 and time of 279.080!!!
THANKYOU ALL for competing in the Challenge!!! The more people we have the more fun it is, so keep the times coming! If I missed something or screwed something up let me know! Thanks to the Facebook guys for posting here too! It makes keeping everything straight much easier. Take Care and be Safe in the spring weather! BBD
APRIL RESULTS
3035Likes
Guess these are all I have this month =P
