Mini-96 World Challenge
#2282
Yeah, my green one is like that, and I dig that violet one too!
As for running with the chopped top, It's much faster and more stable in the fast turns! I was able to bump up my throttle d/r from 80% to 88% and drop 2 tenths in lap times before it started traction rolling in the high speed 90 off the straight again. I'm going to play with wheel diameter and offset, then tires to see what it will do. I will get another Jomurema or 2 when I get the funds, but I'm thinking a R8, probably a Silver Horse RC, first.
#2283
Hi Guy's, I have an hypothetical question for the Box Stock Class. Can a MR-04 that come with the MM motor mount (no damper) be used in box stock, if the board was swap with an ASF one and using a stock brush motor?
Was thinking about that since I really like the feeling of the stock front end of the MR-04... (Don't even know if the board swap is even possible?)
#2284
CrazyRonny, Traveler2 will have to weigh in on the 04 in BoxStock or not with a swapped ReadySet board, but on the swap to a 03 board, I have seen a 04 board in a 03 chassis with 04 top plate online. So I would ASSuME going to an 03 board in an 04 chassis should just require the board and an 03 top plate. But again I saw it online not in person, so take the info with a grain of salt!
#2285
Hey guys,
I got my first mini-z about a month ago and received/set up my mini96 track Monday. Looking forward to joining the competition in just box stock for now with my P1 GTR.
Excited to see everyone's times for this month.. good luck!
Brandon
Brandon
#2287
Hi All! Last week i was able to buy a used track and started practicing.
Starting with 75 laps and a time of 12+ minutes i was able to get it down to 7:20 this afternoon. A few wall bounces but a lot more consistent overall.
I hope to get more consistent and make less bounces in the next few weeks.
Next month i will probably try to join another class as well with my MR03evo or MR04.
Currently im using laptrax on my phone, but that is missing some laps once in a while. I do have a timing system but dont have a windows laptop yet (And cant find any timing software for linux).
June 2024 Layout
Class ~ Open 2WD
Date ~ 30 June 2024 @ 12:50 pm
Location ~ Netherlands
Race Time ~ 440.64 Seconds / 7:20.64 Minutes
Fastest Lap ~ 5.38 Seconds
Chassis ~ Atomic MRX
Body ~ Mosler
Wheelbase ~ 98mm
Tires ~ Front Marka MZR-V5F20 Rear Marka MZR-V1RR10
Springs ~ default
T-Plate ~ N/A
Motor ~ PN v4 2500 kv Brushless
Batteries ~ PN LIPO 385mah
Gearing ~ 53t Spur - 13t Pinion
ESC ~ Hobbywing mini28 in blinky mode
No pictures yet since i don't have enough posts yet to place these.
June 2024 Layout
Class ~ Open 2WD
Body ~ Mosler
Wheelbase ~ 98mm
Springs ~ default
T-Plate ~ N/A
#2288
#2289
I'm sorry to report that I was not able to get any runs in this month, so I'll be skipping June time posts. :-( Life is a bit crazy for the next couple months; I hope to get some runs in for July & August, (fingers crossed).
#2290
I took over running this challenge from LJH three years ago after participating in it for a couple of years, so its time to hand over the reigns to someone else. I still plan to run and submit times, but need to step back a little bit, as it has started to feel like a chore. Luckily Poor_Boy aka David Krinard has agreed to take over for a while. Drive fast and keep the shiny side up!
#2291
Class- box stock
Date- 6/25/24
Location- Smithtown NY
Race Time- 6:58.93
Fastest Lap- 4.74
Chassis- Mr03
Body- Corvette
Wheelbase- stock
Tires- PN
Motor- stock
Batteries- Yeah racing
Front Springs- purple
T-Plate- soft plastic fiberglass reinforced
Motor Mount- stick
Dampener (If applicable)-
Gearing- stock
Notes-
#2292
Class-90mm Narrow Stock
Date-6/17/2024
Location-Winston-Salem, NC
Race Time-329.2
Fastest Lap-4.17
Chassis-MR-03 ASF
Body-Mazda RX-7 FC3S
Wheelbase-90mm
Tires-PN KS Medium fronts, PN KS Soft rears (20mm 0 offset wheels all around)
Motor-ATM 70T
Batteries-GensAce 750s
Front Springs-PN Green
T-Plate-Kyosho CF Hard
Motor Mount-PN MR9094 90mm
Dampener (If applicable)-PN Integrated
Gearing-9/44 Gear diff
Notes-This run is with the FC3S which is 6g lighter than the FD3S I usually run. I only got one run in with this car and none with the FD body.
Date-6/17/2024
Race Time-329.2
Fastest Lap-4.17
Chassis-MR-03 ASF
Wheelbase-90mm
Motor-ATM 70T
#2293
Class-90mm Narrow MX-5 Miata Unofficial Experimental Class
Date-6/18/2024
Race Time-334.3
Fastest Lap-4.30
Chassis-MR-03 FHSS
Body-Mazda MX-5
Wheelbase-90mm
Tires-PN KS Medium fronts, PN KS Soft rears (20mm 0 offset flanged wheels all around)
Motor-Stock
Batteries-Gens Ace 750s
Front Springs-PN Super Soft Blue
T-Plate-Kyosho Soft Fiberglass RM
Motor Mount-Stock RM
Dampener (If applicable)-N/A
Gearing-7/44 Gear diff
Notes-This car is super light, but very stable and quick and is one of the funnest to drive and watch going around the track! It runs great on both Narrow and Wide rears with no setup changes. I only got two run in with it this month, but beat my best May time by 3 seconds.
Date-6/18/2024
Race Time-334.3
Fastest Lap-4.30
Chassis-MR-03 FHSS
Body-Mazda MX-5
Wheelbase-90mm
Motor-Stock
#2294
Class-Porsche Cup Class
Date-6/20/2024
Race Time-309.4
Fastest Lap-3.95
Chassis-MR-03 EVO
Body-911 GT3
Wheelbase-90mm
Tires-PN KS Soft on RTRC 19mm +1 fronts, Marka v1R10 on PN 19mm W0 rears (not pictured)
Motor-ATM 3500
Front Springs-Kyosho Stock
T-Plate-GT55 +0.6 FRP #4
Motor Mount-Nexx Round RM
Dampener (If applicable)-PN G10 DDS and Kyosho Inner Tube Shock MZW442
Dampener Fluid (If applicable)-1300 Silicone Oil
Gearing-PN 64p 13/53 Ball diff
Notes-This car was 2 seconds faster than my May Stock 98mm 4100 car and 9 seconds faster than last month.
Date-6/20/2024
Race Time-309.4
Fastest Lap-3.95
Chassis-MR-03 EVO
Body-911 GT3
Wheelbase-90mm
Motor-ATM 3500
#2295
hi second participation to the challenge. some amelioration.
Class-box stock
Date-06-30-2024
Location- deux-montagnes quebec canada
Race Time- 6:59
Fastest Lap- 5.134
Chassis- mr-03
Body- corvette C8 R
Wheelbase- 98mm
Tires- Kyocsho radial 20 rear 30 front
Motor- kyosho stock
Batteries- speed house 800HV
Front Springs- stock
T-Plate- fiber 5h
Motor Mount- mm
Gearing- 7t / stock diff
Notes- see photos on Facebook group because I can't yet.
Class-box stock
Date-06-30-2024
Race Time- 6:59
Fastest Lap- 5.134
Chassis- mr-03
Body- corvette C8 R
Wheelbase- 98mm
Motor- kyosho stock
T-Plate- fiber 5h
Motor Mount- mm
3035Likes
