Mini-96 World Challenge >
Like Tree3035Likes
Old 04-29-2025 | 09:41 PM
  #3016
Class-STOCK
Date- 04/29/2025
Location-Central Texas
Race Time- 318.235 / 5:18.235
Fastest Lap- 3.776
Chassis- PN 2.5W/MR03EVO board/ 04 arms
Body-Jomurema
Wheelbase-98mm
Tires-F-PN KS Soft / R- Marka V1RR10 Soft Radials almost worn to slicks
Wheels- F-PN N+1.5mm 19mm Flanged White 6 hole / R- PN W+2mm 20mm Flanged White 6 Hole
Motor-PN 3500Kv
Batteries- Eneloop 850HV
Front Springs-PN Purple
T-Plate-PN #3 Silver Carbon Fiber
Motor Mount-PN V3 94/98mm
Dampener (If applicable)- PN DDS ( Green top/ PN lt. purple X-Strenght bottom spring) PN Dual Spring Top Shock (Green Front/Purple Rear)
Gearing-12/53 PN Ball Diff
Notes- Same humidity issues as the BoxStock, though easier to recover from mistakes with the added power.
BoxxerBoyDrew is offline
Old 04-29-2025 | 09:47 PM
  #3017
Class-PROSTOCK
Date- 04/29/2025
Race Time- 323.966 / 5:23.966
Fastest Lap- 3.874
Chassis-PN 2.5W/04EVO board/ 04 Arms/ Nexx knucks
Body-Mazda 787B
Wheelbase-102mm
Tires-F- Reflex 45* LH slicks/ R- Reflex 30* Radials
Wheels- F- N+1mm 20mm PN BBS Yellow / R- W+2mm 20mm PN Yellow BBS
Motor-PN Anima 5500Kv
Batteries-Eneloop
Front Springs-Green
T-Plate-Nexx #5 Carbon
Motor Mount-PN Multi Mount
Dampener (If applicable)- PN DDS (Green top/Gold bottom springs)
Gearing- 9/52 PN Ball Diff
Notes- Reflex tires are still holding up well. I was able to dial out some of the edginess out of the ProStock, but humidity was still an issue.
Old 04-29-2025 | 10:23 PM
  #3018
Class- OPEN 2WD
Date- 04/29/2025
Race Time- 308.437 / 5:08.437
Fastest Lap- 3.709
Chassis- GL GLR
Body- White Lexan roof JOMU
Wheelbase- 98mm
Tires-F- KS1042 (regular height KS firm 42* sidewall glued) / R- Marka V1R10
Wheels- F- N+1mm 19mm PN Dish White / R- W+2mm 20mm PN Yellow BBS
Motor- NHX 2500Kv
Batteries- GNB 350mAh 2S LiPO
Front Springs-Blue
T-Plate-N/A
Motor Mount-GL 98mm
Dampener (If applicable)- Short Center Shock (Blue Spring) / Yellow side springs
Dampener Fluid (If applicable)- 25K Atomic grease- Center / 15K Atomic grease- Sides
Gearing-10/53 GL Ball Diff
Notes- LOVING the GLR!!! I was able to drive it better with the higher humidity compared to my Mini Z's. Still figuring out it's quirks, and setting the ESC to my liking, but I'm almost there. I'm trying paint layouts, so I can start laying some color at the beginning of the month. Also trying my hand at cutting with a swivel head razor knife, and cutting out numbers. The numbers are coming out ok, but still working on transferring them from the cut matt to the car. The red 94 is a try at them, all free hand on Tamiya 40mm masking tape drawn with red normal tip Sharpie, ok for my old eyes and shaky hands! My time was pretty good, but if my hand wasn't going to sleep I think I could have broken the 5 minute mark!
I will try for a better time after running my last 3 classes.
Old 04-30-2025 | 12:25 AM
  #3019
Class- PORSCHE
Date- 04/30/2025
Race Time- 341.222 / 5:41.222
Fastest Lap- 3.999
Chassis-MR03EVO
Body-Porsche 911 GT3 RSR
Wheelbase-90mm
Tires-F- PN KS Medium LH / R-PN KSK Soft Slicks
Wheels- F-PN N +1mm 19mm White Delrin Dish / R-PN W 0mm 20mm Yellow BBS
Motor-Rocket 3500Kv
Batteries-Eneloop
Front Springs- PN White
T-Plate-Kyosho #5M white fiberglass
Motor Mount-Nexx 90/94mm RM
Dampener (If applicable)- PN DDS (no top disk/Purple bottom springs) PN Dual Spring Shock ( Purple front/Red Rear)
Gearing-12/53 PN Gear Diff
Notes- Pouring rain like a Cow pissin' on a flat rock! humidity is up to 70% and cars are on edge bigtime! Had to turn down throttle d/r 3 clicks and steering d/r 2 clicks from last week, and still had 4 rolls on this run! It rolled close to me, so getting to it was quick! on all 3 SWB cars I ran today a 4.1 second lap was comfortable. Last week 3.8s were that way.
Old 04-30-2025 | 12:42 AM
  #3020
Class- NARROW
Date- 04/30/2025
Race Time- 327.611 / 5:27.611
Fastest Lap- 4.014
Chassis-MR03EVO
Body-Mazda MX-5
Wheelbase-90mm
Tires- F-PN KS Medium LH / R- PN KSK 40* LH worn to 22.4mm
Wheels-F- PN N 0mm 19mm White Delrin Dish / Kyo N 0mm 20mm White RE30
Motor-PN 3500Kv
Batteries- SpeedHouse 800HV
Front Springs-Kyo Orange (soft and short) on Inner Tube Shock Set
T-Plate-Nexx #4
Motor Mount-Nexx 90/94mm MM
Dampener (If applicable)- PN DDS (NO top DISK/Green bottom spring), Nexx Racing dual spring top shock (yellow main spring)
Gearing- 12/53 PN Ball Diff
Notes- Still a work in progress. Has TR problems when set up with the exact wheel/tire/body combo as when on my 90mm Nexx RM pod, when the RM Pod is glued to the track! Going to the WORN rear KSK 40*s solved most of the T/R problem, but I clipped the inside corner a few times and flipped on it's lid! Either coming off the straight or going onto it were my problem corners. Hopefully I'll have it straight next month!
Old 04-30-2025 | 12:47 AM
  #3021
Class- MX-5
Date- 04/30/2025
Race Time- 338.519 / 5:38.519
Fastest Lap- 3.932
Chassis-MR03 EVO
Body-Mazda MX-5
Wheelbase-90mm
Tires-F- PN KS Medium LH / R- PN KS-M Soft LH
Wheels-F- PN N 0mm Yellow BBS / R- DXR MP1 W -1mm 20mm Carbon Black
Motor-PN 3500Kv V4
Front Springs- PN Purple
T-Plate-Nexx #5
Dampener (If applicable)- PN DDS (Purple top/Green bottom springs)
Gearing-13/53 PN Gear Diff
Notes- Car was on edge but running AWESOME! Again I clipped a corner twice and flipped! The main issue I had is the car getting caught up on the wall from the front tires sticking when I would brush the wall coming out of a corner! They are +1 20mm Narrow PN BBS wheels, so I have some +.5mm in my shopping cart. I must have gotten stopped 20 times! It killed my times, so i will try some 0mm later to see how it helps,
Old 04-30-2025 | 07:23 AM
  #3022
Class - Box Stock
Date - 4/6/2025
Location - Iowa
Race Time - 307.054
Fastest Lap - 3.722
Chassis - MR-04 MM
Body - McLaren 12C
Wheelbase - 98mm
Tires - PN KS Medium on 20mm F1 flanged wheels, no tape / Marka V1R10 R2 wheels
Motor - Stock
Batteries - Orion 750 SHO
Front Springs - Orange
T-Plate - Kyosho Carbon Firm
Motor Mount - Stock
Dampener (If applicable) -
Dampener Fluid (If applicable) -
Gearing - 7T, stock diff
BoxxerBoyDrew likes this.
chjosi is offline
Old 04-30-2025 | 12:53 PM
  #3023
Default April Mini96 attendance Box stock, Open RWD, Open AWD
Here are this month's times, hope it is ok to have all classes in the same post.
Stil not able to post picture, but will post on FB
Class-Box Stock
Date-04/30/2025
Location-Norway
Race Time-7:48,38 (468,38)
Fastest Lap-4,94
Chassis-MR-03
Body-Jomurema
Wheelbase-98mm
Tires-kyosho slik 30 front radial 20 rear
Class-Open 2WD
Date-04/29/2025
Location-Norway
Race Time-7:49,55 (469,55)
Fastest Lap-5,12
Chassis-OBRC OBZ
Body- Jomurema
Wheelbase-98mm
Tires-Marka slick front and radial rear
Motor-Atomic 3500kv
Class-Open AWD
Date-04/29/2025
Location-Norway
Race Time-7:31,54 (451,54)
Fastest Lap-4.67
Chassis-GL racing GLA aV2
Body- Beetle lexan
Wheelbase-98mm
Tires-Atomic radials front and rear
Motor-GL racing 3500kv
Fredoise85 is offline
Old 04-30-2025 | 01:29 PM
  #3024
It's good with me if you post your final times for the month in the same post, but you will get your post count up and be able to post pics quicker if you post individually.
Also I'm going to try to start posting my starting times for each class at the beginning of the month, and as I get faster I'll update the same post, like the guys did in the start of the challenge. It was good to see them progress, and what changes they made during the month to get faster. My back is going to be my biggest obstacle doing it, but I'm going to try! My mid back is causing a lot of pain and numbness in my shoulders, arms and hands. Hopefully it gets better soon!!!
chjosi, that is a SMOKIN FAST Box Stock time!!! Awesome driving!!
chjosi likes this.
Old 04-30-2025 | 05:55 PM
  #3025
Box Stock
Date 4/21/2025
Location- California
Race Time-309.78
Fastest Lap-3.61
Chassis-MR-04
Body- Vet
Wheelbase-98mm
Rear Marka 15 +2mm Nexx disks
Front PN medium slick +0.5mm Next disks (not shown in picture)
Motor-Stock
T plate PN #4 steel
Front springs PN purple (soft)
Car is very fast but could not keep it clean for 75 laps
chjosi and BoxxerBoyDrew like this.
Poor_Boy is offline
Old 04-30-2025 | 05:57 PM
  #3026
Stock
Date-4/22/2025
Race Time-296.08
Fastest Lap-3.59
Chassis-PN2.5
Body- Jer
Wheelbase-98mm
Tires- R Marka 15 +2mm F PN KSk 40 slick +0mm
Motor-PN 3500KV
Poor_Boy is offline
  #3027
Pro stock
Date-4/22/2025
Race Time-300.58
Fastest Lap-3.69
Chassis-PN 2.5
Body- Mazda 787B
Wheelbase-102mm
Tires- R Marka 15
F PN KS med
Motor-5500KV PN
Batteries-PN750
Only had time for one run in pro stock
Poor_Boy is offline
Old 04-30-2025 | 05:58 PM
  #3028
Narrow/MX5
Date-4/30/2025
Race Time-331.43
Fastest Lap-3.84
Chassis-MR-03 box stock
Body-MX-5
Wheelbase-90mm
Tires- R PN soft 8.5mm. F PN KSK 40 slick Nexx disk
Motor-3500KV
Batteries- PN 750
Poor_Boy is offline
  #3029
2wd open
Date-4/19/2025
Location- Northern California
Race Time-279.08
Fastest Lap-3.39
Chassis-RX28SE Gen1
Body- Jer
Wheelbase-98mm
Tires- F unknown Med R unknown
Motor-7000KV Team powers (turned way down)
Batteries- 2S lipo
Pick up this RX28 used and did not change anything other then bringing in the front with to protect the servo. This one drives amazing even even with the way to high 7000kv motor.
Poor_Boy is offline
Old 04-30-2025 | 05:59 PM
  #3030
AWD open
Date-4/30/2025
Race Time-317.8
Fastest Lap-3.75
Chassis-GLA
Wheelbase-98mm
Tires- Unknown
Motor-5500kv PN
Batteries- 2S lipo
Poor_Boy is offline
