Mini-96 World Challenge >
Like Tree3036Likes
Old 08-23-2024 | 07:51 PM
  #2446
The almost new KSM Soft Radials made a HUGE difference with front steering of my ProStock! It has perfect steering at 92%, then I added some brass flat bar stock to the outsides of the PN 2.5W chassis. 3.5g per side, and I can flat out rip through the high speed 90's with no hint of T.R.!
Traveler2 and Phatz_60 like this.
BoxxerBoyDrew is offline
Old 08-24-2024 | 03:25 PM
  #2447
So far I’ve beat my July times in Box Stock, Stock, Porsche Cup and 2WD Open. Need to get times with Miata, Narrow and Pro Stock.
BoxxerBoyDrew and Phatz_60 like this.
Traveler2 is offline
Old 08-29-2024 | 11:33 AM
  #2448
Well I'm screwed as usual!!! While helping my Parents finish moving Monday and Tuesday I started having bad cramps in my Rt hand and arm, when I try to do almost anything, even typing, so I don't have any full runs yet this month even though I've run 1,000s of laps. Dr. bumped my meds to try to get some relief, but I don't know if they'll help before the end of the month!
Good Luck to Yall running on this quick layout!!!
Phatz_60 likes this.
Old 08-30-2024 | 01:30 AM
  #2449
Get Well Soon Drew
BoxxerBoyDrew likes this.
Phatz_60 is offline
Old 08-31-2024 | 09:29 AM
  #2450
Default Box stock - August submission
Class- Box Stock
Date- August 31 2024
Location- Sydney, Australia
Race Time- 461.9
Fastest Lap- 4.54
Chassis- MR03
Body- Jomurema
Wheelbase- 98mm
Tires- Front: PN Racing KS Slick SOFT, Rear: PN Racing KS Radial SUPER SOFT
Motor- Stock
Batteries- IKEA 750mah
Front Springs- Stock
T-Plate- PN Racing Carbon No. 3
Motor Mount- stock
Dampener (If applicable)- Stock
Dampener Fluid (If applicable)- N/A
Gearing- 7T
Notes- N/A
Sorry, can’t post any photos. I will post the photo in the Mini96 page on FB.
RACS15 is offline
Old 08-31-2024 | 12:56 PM
  #2451
Ok we’ve finally got all the pieces for a full size mini96wc and starting next Saturday we’ll be practicing and trying to set times
Phatz_60 is offline
Old 08-31-2024 | 01:55 PM
  #2452
Default August 2024 Box Stock
Class-Box Stock
Date-8/22/2024
Location-Winston-Salem, NC
Race Time-295.8
Fastest Lap-3.64
Chassis-MR-03 FHSS
Body-2012 NSX
Wheelbase-98mm
Tires-PN KS Med fronts glued and trued, Marka V1R15 rears
Motor-Stock
Batteries-GensAce 750s
Front Springs-Kyosho Stock
T-Plate-Kyosho FRP 0.6H
Motor Mount-Stock MM
Dampener (If applicable)-None
Notes-I switched back to the Kyosho FRP 6H T-plate and beat my July time by 5+ seconds and got under 300 this month.
Old 08-31-2024 | 01:56 PM
  #2453
Default August 2024 MX-5 (Miata) Unofficial Experimental Class
Class-90mm Narrow MX-5 Miata Unofficial Experimental Class
Date-8/29/2024
Race Time-300.4
Fastest Lap-3.82
Chassis-MR-03 FHSS
Body-Mazda MX-5
Wheelbase-90mm
Tires-PN KS Medium fronts, PN KS Soft rears (20mm 0 offset flanged wheels all around)
Motor-Stock
Batteries-Gens Ace 750s
Front Springs-PN Super Soft Blue
T-Plate-Kyosho Soft Fiberglass RM
Motor Mount-Stock RM
Dampener (If applicable)-N/A
Gearing-7/44 Gear diff
Notes-This car is super light, but very stable and quick and is one of the funnest to drive and watch going around the track! It runs great on both Narrow and Wide rears with no setup changes. I beat my July time by 8+ seconds, but couldn't get a sub 300 second run despite trying several times...
  #2454
Default August 2024 Narrow Class
Class-90mm Narrow Stock
Date-8/28/2024
Race Time-291.1
Fastest Lap-3.66
Chassis-MR-03 ASF
Body-Mazda RX-7 FC3S
Wheelbase-90mm
Tires-PN KS Medium fronts, PN KS Soft rears (20mm 0 offset wheels all around)
Motor-ATM 70T
Front Springs-PN Green
T-Plate-Kyosho FRP 0.6 Medium
Motor Mount-PN MR9094 90mm
Dampener (If applicable)-PN Integrated
Gearing-9/44 Gear diff
Notes-I beat my July time by 6+ seconds and only changed the t-plate from CF hard to FRP 6M. I borrowed a Yaris body from a friend and was able to get 293.6/3.74 with it, but suspect it will be quicker than the RX-7 when I get it set up right. Can't wait to paint my Yaris. It is a very stable body and fun to watch rip around the track. Stay tuned...
Old 08-31-2024 | 01:57 PM
  #2455
Default August 2024 Porsche Cup
Class-Porsche Cup Class
Date-8/22/2024
Race Time-286.7
Fastest Lap-3.63
Chassis-MR-03 EVO
Body-911 GT3
Wheelbase-90mm
Tires-PN KS Soft on RTRC 19mm +1 fronts, Marka v1R10 on PN 19mm W0 rears (not pictured)
Motor-ATM 3500
T-Plate-GT55 +0.6 FRP #4
Motor Mount-Nexx Round RM
Dampener (If applicable)-PN G10 DDS and Kyosho Inner Tube Shock MZW442
Dampener Fluid (If applicable)-1300 Silicone Oil
Gearing-PN 64p 13/53 Ball diff
Notes-This car is super quick and fun, but a challenge to drive consistently. I only got one run in this month, and beat my July time by almost 2 seconds.
Old 08-31-2024 | 01:58 PM
  #2456
Default August 2024 Stock Class
Class-Stock PNR 3500kv
Date-8/26/2024
Race Time-268.4
Fastest Lap-3.37
Chassis-PNR2.5W
Body-Jomurema
Wheelbase-98mm
Tires-PN KS Firm fronts, Marka V1R15 rears
Motor-PN v4 3500vk
Front Springs-PN AA Yellow
T-Plate-Kyosho FRP 0.5 Medium
Motor Mount-PN 98mm v5
Gearing-PN 64p 14/53 Ball diff
Notes-Car now has PN Lexan roof and less ballast, and handout motor from PNNAC race on 8/16-18 in Pittsburgh, also noticed after I got back that my PN #3 FRP T-plate was cracked, so switched to Kyosho 5M. I beat my July time by 5+ seconds and finished just ahead of my Pro Stock car by 0.084 seconds...
  #2457
Default August 2024 Pro Stock Class
Class-Pro Stock GT
Date-8/26/2024
Race Time-268.5
Fastest Lap-3.36
Chassis-PNR2.5W with EVO Board
Body-Jomurema GT01 with Lexan Roof
Wheelbase-98mm
Tires-PN KS Firm on RTRC 20mm +1 fronts, Marka V1R15 rears
Motor-PN50T Bushing
Front Springs-PN Purple
T-Plate-Kyosho FRP 0.5 Soft
Motor Mount-PN 93-102 Multi Motor Mount
Dampener (If applicable)-PN TDS
Gearing-64p Ball Diff 10/54
Notes-PN G10 #4 t-plate was stressed, so changed to Kyosho FRP 5S. I beat my July time by just over a second, but couldn't beat my Stock 3500 time this month.
Old 08-31-2024 | 01:59 PM
  #2458
Default August 2024 Open 2WD Class
Class-Open 2WD
Date-8/12/2024
Race Time-262.6
Fastest Lap-3.29
Chassis-RTRC RTA v2
Body-Jomurema GT01
Wheelbase-98mm
Tires-PN KS Med on RTRC 19mm +1 fronts, Marka V1RR10 Radial +2 rears
Motor-GL Sensored 2500kv
Batteries-PN 2S LiPo
Front Springs-RTRC Yellow
T-Plate-N/A
Motor Mount-Stock
Dampener (If applicable)-Stock
Dampener Fluid (If applicable)-K 5000 grease
Gearing-14/53
Notes-I beat my July time by almost 4 seconds.
Old 08-31-2024 | 03:34 PM
  #2459
danjoy25's Avatar
Class-Open 2WD
Date-Aug 2024
Location-Sydney
Race Time-5:37.323
Fastest Lap-4.150
Chassis-GL GTR
Body-Jomurema GT01
Wheelbase-98mm
Tires-Kyosho 30 fronts & Marka 14mm rear
Motor-TP Sensored 3500kv
Batteries-GL2S LiPo
Front Springs-stock
T-Plate-N/A
Motor Mount-Stock
Dampener Fluid (If applicable)-none
Gearing-14/53
Notes-throttle power only 50%
danjoy25 is offline
Old 08-31-2024 | 03:38 PM
  #2460
danjoy25's Avatar
Class-Stock
Date-Aug 2024
Location-Sydney
Race Time-5:42.987
Fastest Lap-4.188
Chassis-Kyosho MR-04
Body-Jomurema GT01
Wheelbase-98mm
Tires-Kyosho 30 fronts & Marka 10 rears
Batteries-Kyosho AAA
Front Springs-stock
T-Plate-N/A
Motor Mount-Stock
Dampener (If applicable)-PN Racing
Gearing-14/53
Notes-
danjoy25 is offline
