Like Tree495Likes
JConcepts Thread
Old 02-16-2024 | 06:18 AM
  #10561
Cain's Avatar
FYI something you may want to pass along for possible listing for more sales, the Yokomo SO 2.0 buggy uses all 48mm sized turnbuckles, which I think are the same size of the RC10B6.4 and I think the new B7 used that too. they are 3mm thick but you could include a drill bit or just mention it. figure way to get more sales via just changing some bagging text
Cain is offline
Old 02-16-2024 | 06:22 AM
  #10562
PW's Avatar
PW
Thank you, I will pass it along
Cain likes this.
PW is offline
Old 02-18-2024 | 02:26 PM
  #10563
Maybe I glanced over the topic, but when are you guys liking the wide fronts? I have a set of pin swags and fuzzbites in wide width coming in just to give them a shot.
Cinnabun is offline
Old 02-19-2024 | 05:21 AM
  #10564
PW's Avatar
PW
They seem to be more popular on older worn Carpet & Turf tracks where traction is a little lower and need some extra steering. They also work well on the front of 4wd buggies when you are looking to tame down the frontend .
RBLove likes this.
PW is offline
Old 02-19-2024 | 10:20 AM
  #10565
Cain's Avatar
to build on what PW is saying, if you are on a track that can fuzz up front slim tires, they work well.
RBLove likes this.
Cain is offline
Old 02-20-2024 | 05:06 AM
  #10566
Cain's Avatar
Another comment on some things being tried with the wide 2wd fronts I have seen others doing has been to run the wide fronts on slim wheels. This gives them a bit more cushion on the tire, also seem to keep the foams from going soft as quick. We noticed that the foams definitely feel quite different between a fresh set versus a used set, so if you find you tires themselves look good but your handling doesn't feel the same, check the feel of the foams.
Cain is offline
Old 03-18-2024 | 10:39 AM
  #10567
Brandon11m's Avatar
I just recently had my local hobby shop order me a set of pre-mount swagger stadium truck tires as well as a set of un-mounted fuzz bites with a pack of #3354W wheels and I noticed the wheels on the pre-mount set are not the same as the #3354 wheels?
The premount looks to have slightly thicker webbing and the concentric ring around each web which the #3354 does not but both wheels do have the JC mark on the outside dish. Is this a change in the design of the #3354 wheel and old stock is still being sold off or is the pre mount using a different wheel that is not otherwise available?
Cain likes this.
Brandon11m is offline
Old 03-20-2024 | 07:27 AM
  #10568
PW's Avatar
PW
This wheel is just for the pre mounted ST wheels and is not available separately.
PW is offline
Old 06-10-2024 | 11:35 AM
  #10569
Matt Trimmings's Avatar
Hey Paul, I was wondering if you happened to have a hazard radio wheel (2450) laying around anywhere or thought about doing something similar to that again. I loved mine years ago and sold that old radio with it, have been searching for one since. Thanks!
Matt Trimmings is offline
Old 06-10-2024 | 11:40 AM
  #10570
PW's Avatar
PW
Unfortunately no
Matt Trimmings likes this.
PW is offline
Old 06-12-2024 | 07:57 AM
  #10571
Cain's Avatar
So any more movement on a different front astro style tire? Basically a nessi maybe done in the fasion of a pinswag tire for a bit more front end grip?
End up using a combo of the Dropsteps rear and schumachers minidarts trimmed up front here and its money for 4wd be cool to see a jcconepts option.
Cain is offline
Old 06-12-2024 | 11:22 AM
  #10572
PW's Avatar
PW
Yes, we are working on something and just received a sample
Cain likes this.
PW is offline
Old 06-13-2024 | 08:43 AM
  #10573
Cain's Avatar
Awesome! Looking forward to your findings !
Can we also get some premounts of the 1/8 Astro tires?
Cain is offline
Old 06-23-2024 | 07:05 AM
  #10574
GOING FAST's Avatar
I just bought a set of the smoothies 2 in silver compound and was wondering what tire sauce works best for these tires. The track is a high bite clay surface
GOING FAST is offline
Old 06-23-2024 | 09:45 AM
  #10575
Do you make a radio bag for M-17 radio’s? Thanks, Dave.
twistert1 is offline
