Tamiya TT02 Thread
#3692
The Yeah Racing steel universals and cups are only $20:
EDIT: Ope, YEA-TT02-015, is on backorder on A-Main. Here you go: Yeah Racing Tamiya TT-02 G45 Steel Universal CVD Driveshafts V2 TT02-015
- Yeah Racing Tamiya TT-02 Steel Universal Drive Shafts (2)
- Yeah Racing Tamiya TT-02 Steel Front/Rear Differential Cups (2)
#3693
I’m new to RC cars and to the forum. Firstly, thanks for all the advice and tips I’ve already found on the forum.
I bought my Son a stock Tamiya TT-02 (Lancia Delta Integrale) for Christmas which we have almost completed building and are looking at sourcing the parts required to get it up and running.
It will be used for playing around on the driveway/in the garden so we’re not looking at going crazy upgrading at present. I’ve ordered a ball bearing kit and oil-filled shocks to replace the friction ones in the kit.
I’ve also bought a Flysky FS-GTC3 transmitter/receiver and a JX-PDI 4409MG servo.
I just need to sort out a battery/charger. As I understand, the speed controller in the stock kit is not designed for LiPo batteries and could risk over-discharging. Does that mean I need to look at NiMH batteries? Any good current recommendations for UK sources batteries and a compatible charger?
I have been given a TLP Fuzzy Logic AC/DC switching charger, although I have no instructions for it and don’t know how to use it. I’m not sure if this is obsolete now.
Any advice to would be really helpful. Thanks in advance!
#3695
I’m assuming LiPo is quite a big upgrade compared to NiMH?
#3696
https://www.ruddog.eu/RUDDOG-Electro...itro-Engines_1
Personally, I think these cutoff devices still go below (6.2 is dicey) the proper recommended threshold (3.2v per cell = 6.4v minimum)
A proper esc is a worthwhile investment in the fun.
#3697
i found a ‘Tamiya Hobbywing 1060 RTR Quirun 60A Brushed ESC NiMH/LiPo 8T limit’ for under £20: is it compatible and will it do what I need?
#3698
Yes, it will work with the stock silver can brushed motor and suit your purpose nicely.
If you want more speed, there are still several brushed motors available. My preference for Rally fun with a TT02 is a 2or 3 slot 19T motor. Good speed and torque, and won’t drain the batteries too fast.
#3699
#3700
let us know which ESC came with the kit.
#3701
The "problem" is these ESCs are not provided into the kits by Tamiya Japan (not even the Tamiya-labeled ESCs are). They're all put into the boxes by the distributors, so they can vary quite a bit. Same as the clear plastic wrapping around the kits - not done by Tamiya themselves (yet some collectors seem to insist upon it, so the kit is in "original" condition (which it is not, strictly speaking)... In Europe, or let's say Germany and some surrounding countries, there are still kits that have a Tamiya ESC, some have a Hobbywing 1060 and some have a Carson ESC. So you really need to check what you actually got.
#3702
Thanks for that…
I’ve just checked and it comes with a Carson Dragster Brushed 70A which appears to be compatible with LiPo batteries (although it doesn’t say if it has a low voltage cut off).
is this a better controller than the Hobbywing 1060 60A (which I have also now ordered!)?
Are LiPo cells/chargers much of a muchness or are their manufacturers/suppliers to look for/avoid?
#3703
Thanks for that…
It looks just like the Hobbywing 1060 (which it says it's rebranded), can't find anything about low voltage cutoff, but if it's rebranded it should.
#3704
1387Likes
