Like Tree18Likes
Hobbywing Tunalyzer
Old 06-01-2023 | 03:54 PM
  #46
gigaplex's Avatar
Originally Posted by OffRoadJunkie
That sucks!
What's the USB port for?
I'm guessing future firmware updates from a computer.
OffRoadJunkie likes this.
gigaplex is offline
Old 06-03-2023 | 08:10 PM
  #47
OffRoadJunkie's Avatar
You're right. There is no printer and the USB port is for a future update. LAME!!!!
OffRoadJunkie is online now
Old 06-05-2023 | 05:04 AM
  #48
STLNLST's Avatar
With LSR Speedway closed, where are you all racing now? Are you all going to the Delta Speedway?
many of us run multiple classes and had already transitioned into onroad primarily before LSR closed. I know the offroad guys either go to Whipit in Reno or run Modesto outdoor.
STLNLST is offline
Old 06-05-2023 | 10:25 AM
  #49
Reno and Modesto? That's a lot of driving. What on-road track to you run on?
It's sad to see LSR get shut down. They were very nice owners and it was a nice track. The only issue I had, there didn't seem to be any "energy". It was pretty dull, between races.
Old 10-14-2023 | 02:36 PM
  #50
Default Graphing Results
Hello. I am new to this. I want to put the date from the results into a graph to find the best results. Any recommendations on how to do this?
jujubean is offline
Old 10-15-2023 | 08:35 AM
  #51
Kraig's Avatar
Super Moderator
if you look through this thread you can see a few posts on what some are doing to record this data. If you graph the results or have a few cells do the calculations for you it will make things a little easier to see what is going on.
Rotor Master
Kraig is offline
Old 10-15-2023 | 08:40 PM
  #52
trilerian's Avatar
Rotor Master
There goes my poor naming convention again...
I think you mean this one. Load Master
Somewhere in that thread I have a link to my Github that has some graphs in it.
Edit: I guess I can just put the link here, lol. github - analyzer results
Kraig likes this.
trilerian is offline
Old 11-07-2023 | 07:03 PM
  #53
This is probably a stupid question. Can the Tunalyzer be powered by a charger power supply?
shortcut3d is offline
Old 11-07-2023 | 08:28 PM
  #54
gigaplex's Avatar
Probably, the voltage input range is 6V-16.8V
gigaplex is offline
Old 11-08-2023 | 07:56 AM
  #55
You also have to make sure your power supply has the amperage.
Old 11-08-2023 | 12:47 PM
  #56
The power supply is one of the rebranded server PSUs rated at 12V / 75AMP / 900W with 4mm female bullets.
Assuming that’s more than enough amperage.
I would think the benefit would be more consistent voltage and not adding cycles on a battery
Old 11-08-2023 | 12:58 PM
  #57
trilerian's Avatar
The power supply is fine. It supplies DC voltage, albeit noisy. I run my Tunalyzer on a converted server supply. No issues.
OffRoadJunkie and shortcut3d like this.
Old 11-08-2023 | 08:25 PM
  #58
STLNLST's Avatar
Since I cant find my exact unit I took down my post
STLNLST is offline
Old 11-08-2023 | 11:12 PM
  #59
gigaplex's Avatar
This is what ive used for years rather than charging up a battery. Consistent results every time and if you’re tuning a crap load of motors you dont have to worry about the battery dropping in voltage. This one is similar to the one I have as I can’t find the exact one anymore. Connect to my power supply set your desired voltage and forget about it.
The Hobbywing has a built in voltage regulator, this is a bit redundant. A good idea for other brands though. But make sure you get one with sufficient current rating, 4.5A is too low.
gigaplex is offline
Old 11-09-2023 | 04:49 AM
  #60
STLNLST's Avatar
as I stated previously I could not find the exact one I’ve had for years. Way before the Hobbywing came out. I will have to just take a pic of mine rather than posting what I could find from a quick search
STLNLST is offline
