Hobbywing Tunalyzer
#48
#49
Reno and Modesto? That's a lot of driving. What on-road track to you run on?
It's sad to see LSR get shut down. They were very nice owners and it was a nice track. The only issue I had, there didn't seem to be any "energy". It was pretty dull, between races.
#51
Rotor Master
#52
if you look through this thread you can see a few posts on what some are doing to record this data. If you graph the results or have a few cells do the calculations for you it will make things a little easier to see what is going on.
Rotor Master
Rotor Master
I think you mean this one. Load Master
Somewhere in that thread I have a link to my Github that has some graphs in it.
Edit: I guess I can just put the link here, lol. github - analyzer results
#56
The power supply is one of the rebranded server PSUs rated at 12V / 75AMP / 900W with 4mm female bullets.
Assuming that’s more than enough amperage.
I would think the benefit would be more consistent voltage and not adding cycles on a battery
#57
The power supply is fine. It supplies DC voltage, albeit noisy. I run my Tunalyzer on a converted server supply. No issues.
#59
This is what ive used for years rather than charging up a battery. Consistent results every time and if you’re tuning a crap load of motors you dont have to worry about the battery dropping in voltage. This one is similar to the one I have as I can’t find the exact one anymore. Connect to my power supply set your desired voltage and forget about it.
#60
18Likes
