Xray X1 - Formula One Car >
Like Tree366Likes
Old 11-18-2022 | 07:25 PM
  #3136
Xray should include the gear diff... FFS it isn't luxury without the gear diff. Xray gouging.
mikedoo3 is offline
Old 11-21-2022 | 08:45 AM
  #3137
rcfiend's Avatar
For those of you that have the X1 23, what ESC are you installing. I tried adding my HW XR10 Pro and there is some fitment issues. Is it recommended to move the servo forward to make room for the ESC? Also, I'm just getting back into F1 racing. There use to be a F1 thread that explained setting up an F1 car, is that still available? If so, can someone point in the right direction. Thx in advance.
rcfiend is offline
Old 11-21-2022 | 09:44 AM
  #3138
Default esc XR10 pro stock spec
I use in my X1 2023 the Hobbywing XR10 pro stock spec, it fit perfectly in this small place.
rcguyfpr and hunterdawg like this.
Alain Patry is offline
Old 11-21-2022 | 10:12 AM
  #3139
I put a Tekin in mine. No issue with fit. I installed the ESC on the right side.
hunterdawg is online now
Old 11-22-2022 | 02:49 PM
  #3140
Hi!
Is this a decent setup for my 2015 Xray X1?
HWA38020322
Hobbywing XR10 Justock G3 Sensored Brushless ESC/SD G2.1 Motor Combo (21.5T)
DVF1 is offline
Old 11-22-2022 | 07:43 PM
  #3141
rcfiend's Avatar
Thanks for the pic! Looks like I need to remove my fan from HW esc.
rcfiend is offline
Old 11-23-2022 | 07:48 AM
  #3142
ColbyB's Avatar
usually no way to fit in these cars with a fan but it’s usually not needed with spec motors. If you have the bigger, pro g2 or whatever they call it, you’ll definitely have a hard time fitting it. I can’t see anything bigger than the justock pro fitting.
ColbyB is offline
Old 11-23-2022 | 07:59 AM
  #3143
rcfiend's Avatar
That's what I was thinking as well. I was trying to install the larger pro unit. Appreciate the feedback!
rcfiend is offline
Old 11-23-2022 | 08:00 AM
  #3144
rcfiend's Avatar
Hey one last question. I'll be running on CRC black carpet. Is the kit setup a decent place to start?
rcfiend is offline
Old 11-23-2022 | 08:01 AM
  #3145
rcfiend's Avatar
Originally Posted by DVF1
Hi!
HWA38020322
That should be a good setup. However, the motor will be dependent on your track rules.
rcfiend is offline
Old 12-13-2022 | 01:01 PM
  #3146
What is a good starting weight for a gear diff for med to high grip?
Friulimotosport is offline
Old 12-14-2022 | 06:19 PM
  #3147
Where can I find tire side wall decals in the US?
DVF1 is offline
Old 12-20-2022 | 10:50 PM
  #3148
sloanedogg's Avatar
Has anyone drilled a hole in the top deck of the 23’ car so that they can use the long shock setup for bumpy conditions?
sloanedogg is offline
Old 12-22-2022 | 07:54 PM
  #3149
Just picked up a X1 23; my first f1 car. Got a couple noobie questions...
Do all f1 bodies fit on all chassis? or please provide recommendations to good fitting bodies.
I read a while ago about pegging the diff for high traction, is this recommended i do right off the bat during initial assembly for CRC carpet? dont feel like bucking up for the gear diff quite yet.
perez62682 is offline
Old 12-23-2022 | 03:40 AM
  #3150
DirkW's Avatar
No, unfortunately not all F1 bodies fit every F1 car (I bought some Protoform F1 body and it did not fit my X1'18. Normally the Xray X1 came with a body that fits (at least until the previous version) and that was a Montech body, IIRC.
DirkW is offline
