Xray X1 - Formula One Car >
Like Tree366Likes
Old 05-08-2025 | 07:53 AM
  #3286
[QUOTE=bmxdougherty;16185459]
Originally Posted by MUDVAYNE
It sounds like you're using scales to set the tweak. If that's the case, then I would suggest not using those things anymore. I've seen racers chase the perfect setting for months just to get frustrated with no result. I use the coin method (see the link below) and it has never failed me. I also use setup plates that my team has 3D printed as the bigger sidewall on the 10th scale tires will never give you a good reading. Hope this helps...
so I’ve done both scales show 60 grams heavy on front left tire and when doing the coin method the front left tire lifts so much later than the right it almost looks like the tire is sticking to the surface.
Have you tried removing everything down to the bare chassis to see how far off it is from the start? If even, then add the servo, motor and battery and check again. Keep adding the rest of the electronics while checking balance after each add. Hopefully you will discover the issue that way. Personally, I never use scales because I know I would obsess over the splits, lol. Also, not sure if it has been corrected, but I have never had an XRay F1 car have the same ride height all the way around the car. It is always off by 1-2mm but tweak will still be good. Not sure if that is the same issue or not.
hunterdawg likes this.
chensleyrc1 is offline
Old 05-08-2025 | 11:52 AM
  #3287
Check the shims on the kingpins and make sure both sides have the same amount both under and on top of the steering block. If they're not even that will throw it off. Also, check your ride height shims and make sure they're even under the front standoffs. Oh, also check to make sure the set screw on the steering blocks are both snug, and make sure that when you tighten them down to press on the top of the king pin to ensure that the steering blocks are equal to each other. If one is higher or has any gap that will throw it off as well.....
MUDVAYNE is offline
Old 05-09-2025 | 01:06 PM
  #3288
RetroThutmose's Avatar
What's a good starting point for asphalt tires? Surface is medium - med-high grip. Have a 2017 and 2018 X1s I'm trying to rehabilitate for my son. I see some preglued options but I don't have any issues gluing tires to my old, or new, rims if needed.
RetroThutmose is offline
Old 05-16-2025 | 12:41 PM
  #3289
Hello,
I am looking to upgrade my F1 car. I am thinking about the 25 X1, has anyone run the car on black ozite CRC carpet yet? I will be running the car with rubber tire at 190mm width and 25.5 blinky speedo.
thank you
dave
dragracer72nova is offline
Old 05-17-2025 | 05:00 AM
  #3290
Originally Posted by dragracer72nova
Hello,
thank you
dave
The X1 '25 has been the best F1 car I've driven to date. My home track is black ozite carpet, and we just replaced it with the latest generation, so there's plenty of grip. I'm running the CRC F1 tires with the front sidewalls glued. I've made a few small changes from the kit settings, but not many. If you decide to pull the trigger on this kit, let me know if you want my setup. I would HIGHLY recommend this car.
Ken
BullFrog, hunterdawg and Kruss45 like this.
MUDVAYNE is offline
Old 05-17-2025 | 08:25 PM
  #3291
Dan's Avatar
Dan
Helped tune an X1 25. It handles extremely close to a Schumacher Icon (no surprise since its design is very similar)
MonkeyCmonkeyDo likes this.
Dan is offline
Old 06-14-2025 | 02:58 PM
  #3292
Ken
have you tried the exotek F1 tires or the excelerate F1 tires on black carpet yet?
Kruss45 is offline
Old 06-14-2025 | 07:50 PM
  #3293
Hello,
thank you
dave
Get the Exotek tires/wheels, front = #2194 (red dot 38X medium), and the rear = # 2252 (white dot 22X carpet soft) for CRC black carpet. You will need to glue the sidewalls (front and rear), though how much depends on the grip level and size/speed of your local track. While the carpet may be the same as all other CRC black carpet tracks, depending on the types of cars and use level, the amount of grip will vary substantially.
The eXcelerate F1 rear tires are softer than the Exotek 22X tires. After a few hundred laps my eXcelerate rears developed a ring of death on the inside. These flexed and rolled so hard that I had to glue the entire rear side wall even though some said the rears would need no sidewall glue. The eXcelerate rear tires are probably best for smaller tracks, or newer carpet that's not grooved and tacky yet. The rear tires wear much faster than the Exotek rears, so keep an eye on them after you get a few hundred laps on them. The positive about the eXcelerate wheels/tires is that they were roughly 8g lighter per wheel/tire knocking just over 30g off the car.
kn7671 is offline
Old 07-09-2025 | 06:14 AM
  #3294
MiamizFinest's Avatar
My local track is build out of CRC black carpet, I plan on putting it on the track this week but I am not sure what 2S batter should i buy? How MAH rating are you guys running? How heavy is too heavy of a battery?
racing_jason likes this.
MiamizFinest is offline
Old 07-09-2025 | 01:40 PM
  #3295
Exalt battery 4400's
BullFrog is offline
Old 07-09-2025 | 02:10 PM
  #3296
MonkeyCmonkeyDo's Avatar
I run thin coddar 4500mah?! Batterys. Hths u
d
MonkeyCmonkeyDo is offline
Old 07-10-2025 | 05:50 AM
  #3297
I run either a EA 4600 or 6000, whichever one I can get, lol. But wouldn't go any bigger than the 6000.
Old 07-23-2025 | 02:06 PM
  #3298
RCBuddha's Avatar
R/C Tech Elite Member
Default Montech body and front wing chart?
Just curious if there is some sort of chart that shows the compatibility for montech front wings and bodies?
for example, I can get an f17 body, which should fit with the f17 front wing, but will it fit the 22 front wing?
RCBuddha is offline
Old 09-06-2025 | 07:24 AM
  #3299
Looking to put a spool on my x1 2025, is there any cheaper options than the 100 dollar xray spool? I also don’t wanna get stuck using their sour gears.
Old 09-06-2025 | 07:32 AM
  #3300
Dan's Avatar
Dan
Schumacher. Exotek.
I have a spool for sale if you want. Pm me.
Dan is offline
