Xray X1 - Formula One Car >
Like Tree366Likes
Old 12-23-2022 | 09:09 AM
  #3151
frito's Avatar
The motech f22 is what a few of us are running
frito is offline
Old 12-23-2022 | 10:36 AM
  #3152
Do the bittydesign body fit on the 23?
perez62682 is offline
Old 12-30-2022 | 08:58 PM
  #3153
rcfiend's Avatar
Quick question, I was going through my spare parts bag and I ran across the Gear Diff Set V2 Part#374900. Will this work on the X1 23? Thanks in advance!
rcfiend is offline
Old 12-31-2022 | 04:17 AM
  #3154
Dan's Avatar
Dan
You need the formula gear diff hex hub end part since that is the 1/12 part diff part number. That is the only difference.
Dan is offline
Old 01-29-2023 | 07:46 PM
  #3155
Ttt
hunterdawg is offline
Old 04-20-2023 | 09:59 AM
  #3156
AMZ's Avatar
AMZ
On the Team X-Ray website , it shows the X1 '23 as being 'Product Replaced'
A new version on the way? or just plain discontinued ?
AMZ is offline
Old 04-24-2023 | 04:30 AM
  #3157
cobrajet's Avatar
I noticed this too, Been looking for one to pick up and the only one I've seen to hit the market was just a few days ago at a local shop with a $100 mark up.
cobrajet is offline
Old 04-24-2023 | 04:48 AM
  #3158
DirkW's Avatar
Last time I bought an X1, I had difficulty finding one, too. Luckily, I found a shop that still had one in stock, but it seems they do only a limited production run on these, and they can sell out many months before a new model will be available. Apparently F1 just isn't as popular as other classes, and there's probably not enough demand for them to do another production run in these situations. So you might be out of luck until the release of the next model - if you're going to stay with the X1, that is.
DirkW is offline
Old 05-19-2023 | 11:31 AM
  #3159
Bsthetech's Avatar
R/C Tech Elite Member
Anyone running the side shock in place of the side tube’s? If so what oil are you using on asphalt? I couldn’t find a relevant sheet on the Xray site.
Bsthetech is offline
Old 05-19-2023 | 01:41 PM
  #3160
fat500's Avatar
The montec f23 body fits well and works great. Rear shock I ran 20wt as the piston has no holes and the car had push. after a couple fluid wt changes went back to the tubes. Easier to change grease on tubes than rebuilding the shock if the track changes like it does on our outdoor track here in fl. if temp was steady would have kept it on.
Bsthetech likes this.
fat500 is offline
Old 06-19-2023 | 12:23 PM
  #3161
Dan's Avatar
Dan
Jan just announced the X1 '24. Seems a bit early to announce the '24 model year when summer just barely started...
Dan is offline
Old 06-21-2023 | 01:31 PM
  #3162
MonkeyCmonkeyDo's Avatar
just like real cars theyre announcing 1 yr in advanced. Lol.
order now~!
-d
MonkeyCmonkeyDo is offline
Old 06-21-2023 | 02:33 PM
  #3163
Last year released the end of September, so only 3 months in advance.
MonkeyCmonkeyDo likes this.
Old 06-27-2023 | 08:52 PM
  #3164
Default Body ?
Hello all, new to F1. I bought a X1 2017 and want to ask what bodies will fit .....other than the original X Ray body.
rystang is offline
Old 06-28-2023 | 09:15 AM
  #3165
Check out some sleek bodies from other brands like Tamiya or Protoform
alpenglowquasar is offline
