Xray X1 - Formula One Car >
Like Tree366Likes
Old 11-20-2023 | 07:37 PM
  #3181
MonkeyCmonkeyDo's Avatar
racecarguy im gonna say the ones that are in your wheels. I will look later at my f1 hudy set up kit to see if any directions are in their or maybe check a pdf file manual for the f1 hudy set up station.
hths you
-d
MonkeyCmonkeyDo is offline
Old 11-20-2023 | 07:38 PM
  #3182
racenut I was recommended to go back to the stock manual settings for asphalt and start from their.
-d
Old 11-21-2023 | 06:21 PM
  #3183
Originally Posted by Racecarguy
What size bearing fit in these to use on my 24 X1 car?
They don't fit. A pan car front bearing is 1/8 x 5/16 x 9/64. You either have to make a custom collar that fits in there and over the F1 axle, or use a normal TC setup station with these https://www.michaelsrchobbies.com/hu...xle-adapt.html
DirkW likes this.
PROMODVETTE is offline
Old 11-22-2023 | 12:10 PM
  #3184
Use this:
Try these.
MonkeyCmonkeyDo likes this.
chensleyrc1 is offline
Old 11-22-2023 | 06:41 PM
  #3185
Thanks for the help guys, after seeing the formula setup gauge I see they look and work like the regular tc setup gauge and not the pancar setup style gauge. Appreciate it thank you again
Racecarguy is offline
Old 12-03-2023 | 09:05 AM
  #3186
idbdoug's Avatar
Can somebody link me or post a good USA black carpet setup?
thanks
idbdoug
idbdoug is offline
Old 12-03-2023 | 01:19 PM
  #3187
Look at the book and go from there. That's the answer I get all the time. The try it and go from there I run a different set-up from the rest of my gang.
BullFrog is offline
Old 12-03-2023 | 04:18 PM
  #3188
thanks
idbdoug
This one is for a race at Apex which is on black carpet. It's for a X1 23, but I don't think that the cars are different enough that it can't be a good starting point for a X1 24.
Martin Paradis
File Type: pdf
rhodopsine is offline
Old 02-26-2024 | 03:49 PM
  #3189
pug205's Avatar
Hi guys, my brother just bought an X1 16 - is there any parts on the later versions of the X1 like the 23 that can be used on these older cars? Or are they not compatible?
Thinking more for spares and replacements parts as need be.
Cheers
pug205 is offline
Old 03-08-2024 | 04:31 PM
  #3190
I need some help on the XRay F1 24. Adjusting the tierods the ballcups keep popping off when attempting to adjust them. I wanted to tap them and put a 3mm button head to secure them when adjusting. But my tap will not work on the steel balls. Any suggestions on a fix?
BullFrog is offline
Old 03-08-2024 | 05:10 PM
  #3191
Are they open ended so you can secure the stud with a wrench when adjusting? Open ended ones might be the answer. Frustrating.
d
Old 03-09-2024 | 07:05 AM
  #3192
I just stick a 2mm wrench in the hex of each ball stud when adjusting the turnbuckles and it keeps them from popping off. Also, when initially building the tie rods, I coat the threads of the turnbuckles with chapstick and run them all the way down into the ball cups to cut threads. Then I back them out and adjust to the proper length. It makes adjusting the turnbuckles so much easier later on.
Serzoni is offline
Old 03-09-2024 | 02:51 PM
  #3193
x
BullFrog is offline
Old 03-13-2024 | 05:43 PM
  #3194
x
BullFrog is offline
Old 03-14-2024 | 05:44 PM
  #3195
x
BullFrog is offline
