Like Tree256Likes
Tamiya TRF419
Old 01-26-2021 | 08:12 PM
  #4576
Recently acquired a TRF419X, looking for a XR conversion kit or a lower aluminum deck for black carpet racing. Haven't found any except a 42333 419XR lower deck but does look like its compatible with the 419X. Any suggestions? Thanks
vr6jett is offline
Old 01-26-2021 | 10:51 PM
  #4577
Raman's Avatar
Prior to the XR, there was the WS aluminium chassis, which is fully compatible with 419X. I have a WS chassis that was only used on carpet if you’re interested.
vr6jett likes this.
Raman is offline
Old 01-27-2021 | 01:49 AM
  #4578
h2e's Avatar
h2e
Not chassis related, but you can purchase the Suspension Upgrade Set (Tamiya 54886), that gives you a notable improvement, especially C-hub reliability and steering angle. Chassis stiffness wise, I am not sure if you need more than the X provides.
vr6jett likes this.
h2e is offline
Old 01-27-2021 | 06:54 AM
  #4579
Messaged you 👍🏻
vr6jett is offline
Old 01-27-2021 | 06:56 AM
  #4580
Thanks I saw that upgrade. I’ve run the exotek C-hub in the past but might look into that.
vr6jett is offline
Old 01-27-2021 | 08:41 AM
  #4581
Raman's Avatar
I’m using the 420 upgrade, much more reliable as far as C hubs.. but I still advise using the Xray hard bumper.. which helps a lot as well
Mitamiya, vr6jett and V8 Rumble like this.
Raman is offline
Old 03-02-2021 | 05:22 AM
  #4582
Simmi's Avatar
Smile
I use all time the complete XRay Front and have no problems with everthimg like C-Hub​​​​​​​
garnt likes this.
Simmi is offline
Old 03-02-2021 | 06:55 AM
  #4583
Do you need any modifications to fit?
TamiyaW1688 is offline
Old 03-02-2021 | 11:33 PM
  #4584
Simmi's Avatar
No they Fit perfekt only less shiming on the Blocks. You can notice on the first pic.
Now I use also the TRF 416 Cups on the Pulley. You need no Blades.
Simmi is offline
Old 08-09-2021 | 01:04 AM
  #4585
badboy's Avatar
Default Upgrade to TRF418/418 suspension
Hi. Can the TRF417 suspension be upgraded to TRF418/419 spec?
Thanks!
badboy is offline
Old 08-09-2021 | 06:31 AM
  #4586
Raman's Avatar
Thanks!
Yes. It can also be updated to 420s as well
Raman is offline
Old 08-10-2021 | 03:50 PM
  #4587
Thanks!
steve I use the 417 suspension on all my newer Tamiyas
Juan Aveytia is offline
Old 08-10-2021 | 03:53 PM
  #4588
Raman's Avatar
@badboy
I have a lot of NIB 418 and 419 arms that I won’t be using. PM me
Raman is offline
Old 08-10-2021 | 03:54 PM
  #4589
Raman's Avatar
You need more? I have NIB ones of those as well.. lol. Need to make room
Raman is offline
Old 08-11-2021 | 09:01 PM
  #4590
How much? And how many sets do you have?
