Tamiya TRF419
#4593
#4595
#4596
I'm looking for a basic black carpet setup for 419x with suspension upgrade. Nothing else has been upgraded beside progressive 2.5-2.8 front and 2.6 rear. Springs any info would be great.
#4597
You better find an aluminum chassis if you haven’t yet. I’d try to copy an Xray T4 2017-2019 set up. Should get you in the ball park
#4599
I didn’t have the right size bearings so I didn’t go further.
#4602
Just fitted the TA-08 Pro parts on my 419XR.
With the correct bearings and some shimming it will fit perfectly
#4603
Brilliant, can you let me know the bearings you required? If I can fit the 08 pro parts that will be fine, anything will be better than my chewed up 419 pulleys!
#4604
With the bearings provided in the TRF 420 kit.
info and assembly see, https://www.tamiya.com/english/rc/rcmanual/42345.pdf
#4605
So I need the bearings from a 420 centre pulley, and the pulleys from a ta08 pro?
256Likes
