Like Tree133Likes
Tamiya TRF419
Old 04-17-2018, 07:47 AM
  #3826
snopro31's Avatar
Trader Rating: 44 (100%+)
Default Pre cut bodies
Does anyone know if any other cars run the same body mounting?
With all the pre cut bodies out right now I would like to try one but have never seen a Tamiya listed so I was hoping maybe one of the other cars would fit
snopro31 is offline
Old 04-17-2018, 08:22 AM
  #3827
The infinity IF14 shell fits on the TRF419X (should fit on a std 419 if you flip the rear body posts. Pics in the link
https://www.thercracer.com/2018/01/b...eview.html?m=0
snopro31 likes this.
Qatmix is offline
Old 04-20-2018, 04:06 AM
  #3828
Any recomendations for outdoor asphalt large track? 13.5t blinky.
airbiscuit is offline
Old 04-23-2018, 07:48 PM
  #3829
nubs's Avatar
I feel like a total noob, but how the hell do you get bearings out of the bearing holders?
nubs is offline
Old 04-24-2018, 10:49 AM
  #3830
Two answers:
Precut body T4 2017/2018 fits TRF419x. I use Bitty M410.
I remove bearings from hubs using hook tool. This one used in nitro to set or remove exhaust springs.
https://goo.gl/images/h3mfy5
Macio4ever is offline
Old 04-24-2018, 01:50 PM
  #3831
nubs's Avatar
I have that tool and I attempted to use it. I basically ripped apart my fingers as I tried to pry the freaking bearings out.
nubs is offline
Old 04-28-2018, 02:26 PM
  #3832
nubs's Avatar
Ok this is how i got the bearings out. I used some tweezers to get inbetween the plastic and the bearing just enough to create space for a flat head screw driver. Then I put in a flat head and twisted it to make thebearing separate from the plastic significantly more.
nubs is offline
Old 05-01-2018, 01:47 AM
  #3833
I put end of the hook on the line between bearing and plastic. Put a little pressure then move along a line. 2-3 time a bit stronger and bearing pop up. True - you have to watch your fingers as hook may slip and attack your thumb
Old 05-01-2018, 03:03 AM
  #3834
rc_square24's Avatar
Are your referring to the diff bearings? Try flipping them around on a spool/diff and pull on the holder to release the bearing from it.
rc_square24 is offline
Old 05-05-2018, 11:52 AM
  #3835
Does anybody know where I could buy some flanged layshaft bearings in the UK? I need some but can't find a UK seller of the tamiya ones and can't find the specific size
hipwell is offline
Old 05-05-2018, 01:26 PM
  #3836
sosidge's Avatar
I've always found Modelfixings to be a good source for small quantities of unusual bearings and hardware.
sosidge is offline
Old 05-06-2018, 01:22 PM
  #3837
You do not need Tamiya one. For the main pulley this is 840 flanged [MF84] (TRF419X /WS) and 850 flanged [MF85] for TRF419XR. Avid, Acer have them. Shipment is reasonably fast.
jneezie3000 and airbiscuit like this.
Old 05-30-2018, 11:06 AM
  #3838
nubs's Avatar
Does anyone know if there is a low friction set of belts for the 419x that are TCS legal?
nubs is offline
Old 05-30-2018, 01:22 PM
  #3839
Tom1977's Avatar
The only low friction belts, i know, are from TOP RC.
Front 513mm - 171t:
TOP PO-PDT014
Rear 183mm - 61t:
TOP PO-PDT015
Same white belt material like the TA07R one. TCS legal? Don't think so...
Tom1977 is online now
Old 05-30-2018, 01:59 PM
  #3840
nubs's Avatar
Yeah I had seen those, but wanted something I could use in the upcoming TCS race.
nubs is offline
