Like Tree495Likes
JConcepts Thread
Old 03-04-2020 | 08:14 PM
  #9976
Maybe a bit of a loaded question, but is there a rule of thumb for 2wd front tires as far as grip levels. In what order would you put dirt webs, space bars and ellipse?
nesbot is offline
Old 03-05-2020 | 05:35 AM
  #9977
PW's Avatar
PW
It's been a long time since I've used Space Bar fronts, but I have some good experience with Dirt Web and Ellipses.
-Dirt Web fronts have more initial turn-in and then release the corner.
-Ellipse fronts have less initial turn-in, but have more middle and exit steering.
I think Ellipses can make a car oversteer and over power the rear making the car feel loose on-power exiting corners; this is when Dirt Webs are better. If the car feels tight on-power and you need more steering to finish the corner, then Ellipses are favored.
Chris Reilly and HeavyD99 like this.
PW is offline
Old 03-05-2020 | 07:31 AM
  #9978
Our track has some good clay but it is a covered outdoor track. Since we are still in winter here the track is generally frozen (-10*C !!) and lower traction until it warms up outside. We have been using space bars as a step before going to dirt webs giving the rear a chance to grab any traction possible! As our traction comes up along with the outdoor temperatures sounds like we'll move to dirt webs and ellipses. Thanks !
PW, Chris Reilly and HeavyD99 like this.
nesbot is offline
Old 03-05-2020 | 12:23 PM
  #9979
Hope to get up to Ottawa from Oshawa when it is warmer and less snow/ice.
HeavyD99 and nesbot like this.
Chris Reilly is offline
Old 03-09-2020 | 08:27 AM
  #9980
motorfinger's Avatar
Paul,
Can you tell me when the Dirtweb (for the 4wd front) in the R2 compound will be available? I see that it is sold out on the site.
motorfinger is offline
Old 03-09-2020 | 09:08 AM
  #9981
PW's Avatar
PW
Originally Posted by motorfinger
Paul,
Actually we have them in stock and the website wasn't updated. Thank you for the heads up and we will get the website corrected .
PW is offline
Old 03-09-2020 | 09:24 AM
  #9982
Thank you for the quick reply!
Old 03-10-2020 | 05:39 AM
  #9983
Can you please explain why these tyres behave the way they do?
I have very little dirt experience even having raced 10th scale for more than 30 years as we don't have any 10th dirt tracks (at all) in the UK but I might be venturing to Europe for a few races on dirt.
I like to understand the "why" things work.
RogerM is offline
Old 03-11-2020 | 06:06 AM
  #9984
PW's Avatar
PW
In regards to the front tire discussion and my personal experiences; I think the tire size/shape is key here. The narrower and slightly flatter Dirt Web has more initial turn-in based off the contact patch at neutral and loses some of that contact patch throughout the steering/caster/camber/suspension travel (of course this could be fine tuned for optimum performance for each tire type). I also think that maybe even being a little smaller/lighter could give quicker steering speeds.
The Ellipses are much bigger (wider/rounder carcass) and I think the contact patch is more consistent throughout the steering/caster/camber/suspension and the bigger tire has slightly slower steering speeds. I actually prefer bigger tires the higher the bite is as it makes the car easier to drive; especially on slicks.
I'm sure you could really fine tune the steering/camber geometry to maximize each tire, but most racers don't have the time or knowledge to do this. It's just easier to try each tire back to back and go with the one that is best for the given conditions. If it's spec tire racing, then tuning the front end geometry is huge!
PW is offline
Old 03-11-2020 | 09:31 AM
  #9985
jtodd57's Avatar
Paul-
What are the major differences in handling and "recommended application" for the different B6/6.1/6.2 bodies ? Is one better for loose dirt surfaces, hardpacked clay, ect. ?
big ted likes this.
jtodd57 is offline
Old 03-11-2020 | 11:27 AM
  #9986
PW's Avatar
PW
Originally Posted by jtodd57
Paul-
I honestly don't notice much difference and just run what looks cool or fresh...
The pro guys feel like the P2 is best for outdoor/indoor loose dirt conditions or lower bite turf. The F2 is best for indoor/outdoor med/high bite dirt or med bite carpet/turf. Some guys like the S2 for high bite carpet or clay.
jtodd57 likes this.
PW is offline
Old 03-12-2020 | 05:38 AM
  #9987
Thanks Paul, perfect answer.
RogerM is offline
Old 03-12-2020 | 07:35 AM
  #9988
jtodd57's Avatar
THANKS FOR THE RESPONSE P-DUB !!!
How do you feel about the Illuzion for b6/6.1/6.2 ?? I love that rearward cab look …..any negatives about it ?
jtodd57 is offline
Old 03-12-2020 | 08:14 AM
  #9989
PW's Avatar
PW
I only used it one race and it was on an outdoor loose track and it worked great. I prefer the look of the newer bodies, so I just stick with those .
jtodd57 likes this.
PW is offline
Old 03-24-2020 | 09:16 AM
  #9990
wyd's Avatar
wyd
From: Castle Mamba Max Pro. Feel its power!!!!!!!!!!
Hey PW I know it's the off road thread but any ETA on the Landmine Crawler tires coming back in stock?
wyd is offline
