Tekno RC ET410 Thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree469Likes
Last edit by:
Print Wikipost
Old 06-12-2019 | 04:10 PM
  #931
platgof's Avatar
I got the 22 tooth today and all I can say is wow! I am using a 22T 32P 5MM pinion on a Tekin Pro4 and RSX. It was really amazing seeing how fast it was going. I plan to race this weekend and feeling very confident.
platgof is offline
Old 06-18-2019 | 07:14 PM
  #932
platgof's Avatar
I struggled with the steering being to fast and yanked the Futaba out, and put in a JR Z9000T servo in it.It is slow but feels great and now very predictable. I also was able to turn up the servo speed to 100% on the radio. Took the front shafts out, and sure enough the right side was bent. Took a hammer to it and good as new. A friend (Zach Noia)showed me how to move the rear camber linkage to the outside and readjust the camber. It was night and day in performance, way more stable.
platgof is offline
Old 06-18-2019 | 08:21 PM
  #933
Matthew_Armeni's Avatar
To the outside? What exactly did you do to the rear link?
Matthew_Armeni is offline
Old 06-18-2019 | 10:47 PM
  #934
RCSteveH's Avatar
pictures please
RCSteveH is offline
Old 06-18-2019 | 10:58 PM
  #935
RCSteveH's Avatar
doesn’t the motor mount stick out of the chassis and get in the way of the body with a pinion this large? 18T on my 4300kv seems to be the sweet spot at my local indoor clay track with 150ft straights.
RCSteveH is offline
Old 06-19-2019 | 06:38 PM
  #936
platgof's Avatar
Here you go
platgof is offline
Old 06-19-2019 | 06:40 PM
  #937
platgof's Avatar
This will add a a lot of stability to the rear end.
platgof is offline
Old 06-19-2019 | 06:43 PM
  #938
platgof's Avatar
I use a 540 4600 Pro 4 motor and 22 works great for some reason. I had a 24 in there but it ran too hot and everything got to warm, plus it had no acceleration at all. The 22 seems to have the best going for it. The 21 had faster acceleration, but I want more top end. The 24 was a tight fit also, not good, but worth a try. I have to remover the bottom motor mount slider screw to install the pinion. I also had to do some dremel work to the motor mount to get to the pinion set screw.
platgof is offline
Old 06-20-2019 | 03:33 PM
  #939
rustyus's Avatar
Tell me about it. I don't remember anyone posting about this issue. I thought I was the only one.
rustyus is offline
Old 06-20-2019 | 03:37 PM
  #940
sea1swk's Avatar
You can fit a wrench into the pinion screw, at a certain angle. There is a notch. It is about from the Pan, up to the Pinion. Sometimes I put the pinion on, before I slide the motor bracket in.
sea1swk is offline
Old 06-20-2019 | 04:09 PM
  #941
Here you go
Interesting. I went the opposite route by flipping the hubs and running the shortest link possible.
trf211 is offline
Old 06-20-2019 | 06:37 PM
  #942
platgof's Avatar
Try it, it works really well and fun to drive fast.
platgof is offline
Old 06-20-2019 | 07:24 PM
  #943
I'll test it but my times only went faster the short I went. Currently sitting 1st in our series race at our track with it, should have a good setup sheet in a few more races for indoor clay tracks.
trf211 is offline
Old 06-20-2019 | 10:35 PM
  #944
Can someone please tell me the O.D. of the shock piston with a digital caliper? Please and thank you in advance.
Raul Garcia is offline
Old 06-21-2019 | 10:23 AM
  #945
For those wanting to use the SCT wheels and still have a wider stance like ST wheels provide then check out Exotek +3mm hexes. They also have a +2mm version.
Tbuggy is offline
