Mini-96 World Challenge
#31
Pro-stock
4/26/19
Garage in Florida
443.6
4.75
MR-03
McLaren 12C GT3
98mm
PN oRCP radial rear KS-M compound Medium, PN KS-M compound RCP slick Front super soft
PN 50t
orion 900 hv
stock front springs
#4 carbon tplate
mm2
stock damper with friction plate
kyosho ball diff and 9t pinion
#32
I seem to remember there being a video requirement( someone said that would be easy) for things to count. I know it’s just getting going but if this does start going somewhere, decision on that should be made.
#33
No need for video but we do need a screen shot of the race time.
Cheers,
Jim
#34
Pro-stock
4/24/19
Garage in Florida
425.7
4.90
MR-03
McLaren 12C GT3
98mm
PN 50t
orion 900 hv
stock front springs
#4 carbon tplate
mm2
4/24/19
Garage in Florida
425.7
4.90
MR-03
McLaren 12C GT3
98mm
PN 50t
orion 900 hv
stock front springs
#4 carbon tplate
mm2
Killer fast lap, I have never gone that fast with any of my MR03's.
Cheers,
Jim
#36
Cheers,
Jim
#38
#39
Class- Box Stock
Date- 5/12/19
Location- Rotonda West, Fl
Race Time- 452.9
Fastest Lap- 4.90
Chassis- MR03S2
Body- McLaren F1 GTR
Wheelbase- 98mm
Tires- Stock
Motor- Stock
Batteries- Orion 900HV
Front Springs- Stock
T-Plate- Stock
Motor Mount- MM
Dampener (If applicable)- Stock
Dampener Fluid (If applicable)-n/a
Gearing- Stock
Notes-
#41
The saying slow is fast comes to mind. Always thought it was a dumb saying. The only upgrade is Boca Bearings. I’m sure if I tried I could probably get in the high 4 second range. The stock car is only getting faster as the motor breaks in. I believe that run was my second time running the car out the box.
#42
Got to run two sessions for each of my MR03s. I cut some time off my Fast lap in Pro-Stock and shaved some overall time off my Box-Stock. I ran the GLA with a shaft borrowed from a WL Toys Car but its still not long enough but was able to muster up a fast lap of 5.04 even with a crippled car. The one shaft slips and last night my steering spring broke and I put one out of another controller but it's sticking. I'm beginning to see the potential in the GLA. I believe it will be a beast when everything is corrected. Heres the run. Not very consistent because of the steering and shaft deficiencies.
#43
Cheers,
Jim
#44
Ohhh...I went 383s with the GLA this morning and it was in desperate need of having the dampeners repacked. I am thinking a 375s 75 lap stint is totally possible with an open car.
I will I’ll update my times once I am in front of my laptop.
Cheer,
Jim
Cheer,
Jim
#45
Great Idea - hats off to you for coordinating this project. I’ll be participating in this for sure.
Question - where would a box stock FWD mini z fall in this? Can’t run a 7 tooth pinion (I think the internal ratio is different).
Have that, a stock 2WD, Open 2WD, and Open 4WD.
3035Likes
