Mini-96 World Challenge
#61
*Updated May 4 2019
Class- Stock
Date- May 4 2019
Location- Home
Race Time- 401.6
Fastest Lap- 4.46
Chassis- MR03
Body- Kyosho Audi R8
Wheelbase- 98
Tires- Kyosho 30fr / 20r
Motor- PN 70
Batteries- Duracell 800 NiMh
Front Springs- Unknown. Feel equal to PN yellow
T-Plate- Pn 5
Motor Mount- PN
Dampener (If applicable)-
Gearing- 7/44
Notes- Ran full throttle trim in this run. Was much harder to be cleaner through the whole run but fast laps were much faster.
New run May 4th 2019
Class- Stock
Date- May 4 2019
Location- Home
Race Time- 401.6
Fastest Lap- 4.46
Chassis- MR03
Wheelbase- 98
Motor- PN 70
T-Plate- Pn 5
Motor Mount- PN
Gearing- 7/44
#62
Class-Open 2wd
Date-5/5/19
Location-Rotonda, Fl
Race Time-440.8
Fastest Lap-4.50
Chassis-GLR
Body- Mini Z McLaren
Wheelbase-98
Tires-Pn radial
Motor-GL 3500kv
Batteries-GL 330mah
Front Springs-Stock
T-Plate-N/A
Motor Mount-Stock
Dampener (If applicable)-Stock
Dampener Fluid (If applicable)-Losi Diff Grease
Gearing-10t pinion 53t Spur
Notes-this was the first run with new build.
Date-5/5/19
Race Time-440.8
Fastest Lap-4.50
Chassis-GLR
Wheelbase-98
Tires-Pn radial
Motor-GL 3500kv
Batteries-GL 330mah
Front Springs-Stock
T-Plate-N/A
Motor Mount-Stock
#63
Thanks.
With a 70T this car just works. I have 2 local tracks - one is a little smaller and this car is awesome on it. Almost perfect on the 2-wide L sized tracks.
The second track is quite a bit bigger so this car is really just relegated to the mini96 and the smaller local track
#64
Good to see a GLR on the track. I may need to get one of these as well as I just love the GLA.
Sound like you are having an issue with traction rolling. I have had no issues with my 90mm wide car traction rolling but the same chassis at 86mm running the Stratos body will TR if I ham ham fisted. I will also TR my 94mm chassis once the tires get a bit of heat in them.....again I can pretty much eliminate it if I am gentle at the end of the long straights......I have actually come around the turn at the end of the straight in two wheels a number of times and kept it shiny side up.
I did not get to run this weekend but I will get some laps in nest weekend.
I converted on 94mm car to LM spec so I will need some time to get it sorted. I was kind of bummed switching it over as my 94mm chassis felt so good.
Cheers,
Jim
Cheers,
Jim
#65
It’s a work in progress. This car is surprisingly easy to drive and it just go where you want it. The TR is mostly my fault trying to whip it into the hairpins. The GLA seems to slide a bit better now that I adjusted the rear turnbuckles. This car just needs more tuning. It is quit a bit faster and smoother than the GLA or the MR03. I just swapped over to my new TX and have some new rims and tires (different Offsets and compounds), that should keep me busy for a while. I’m also having to sort out a stripped servo arm on the GLA so it’s parked.
#66
I was able to try some different tires on the GLR last night. I went with some Kyosho radial 20 front and the car does not turn as well as with the pn slicks. It just pushes through the entire turn. One good thing is I can adjust the angle of attack and keep on the throttle. Bad thing is the left front tire is wearing fast for just one battery pack. Should I go back to Pn slicks or do you guys any other suggestions. All though I can stay on the throttle through the turn I have slowed .07 on my fast lap and added 15 seconds overall on my 75 lap stint.
#67
I just got a pretty ripping run in on my Pro-Stock car. I have been playing with my LM chassis this morning and have it going pretty well. This was the third attempt on the cells so I was down on power but the car was super consistent after making a small change and only had about 6 seconds on forced errors. I broke into the 3's with a 394.5s. I will update my Pro-Stock times later on as I have to go be The Wee Man's driver today ;-)
Duckman.....I am shooting for you next in the stock class ;-)
Cheers,
Jim
Cheers,
Jim
#68
Class-Stock
Date- 5/11/19
Location- Norwalk CT
Race Time- 399.7s
Fastest Lap- 5.00
Chassis- MR03 RWD
Body- azda 787B
Wheelbase- 102mm
Tires- F-PN KS Med Slick, R-PN KS Type Soft Radial
Motor- PN70T
Batteries- Amazon Basic Orion 1100
Front Springs- PN Purple
T-Plate- Kyosho 6mm Carbon
Motor Mount- Atomic LM
Gearing-4.15:1
Notes-
Class-Stock
Date- 4/22/19
Race Time- 435.6 (7:15.6)
Fastest Lap- 5.25
Chassis- MR03 RWD
Body- 911 GT3 (991)
Wheelbase- 90MM
Tires- F-PN KS Med Slick, R-PN KS "F" Type Soft Radial
Motor- PN70T
Batteries- Amazon Basic 750mah AAA
Front Springs- PN Purple with Kyosho MZW-416 Inner tube front Dampeners
T-Plate- PN 4MM Carbon Long
Motor Mount- Atomic RM
Dampener (If applicable)- Kyosho MZW-216
Dampener Fluid (If applicable)- 20wt
Gearing-11T Pinion on OEM Gear Diff
Notes-
#69
That is quite a difference... I wonder about using super soft rear tires or firm fronts to try to balance the car more to your liking if you feel that it has too much steering. I would recommend against lowering steering angle on a track this size and with such tight corners.
#70
Good day on the track. I have to say I have learned that the LM configuration is fast. I spent a lot of time trying to beat Duckman's stock time with my RM GT1 90mm chassis and just could not even get close, I got down to 410 which is a significant improvement to the my GT3's 435 (same set up) but still significantly off from Duckman's time. I swapped the motor out of my GT1 to the 787 and boom....first try yielded a 399.7.
I had similar luck running my LM chassis in Pro-Stock I spent a bit of time getting it sorted but the car felt good pretty quickly. After this morning's run I tried again and ended up with a 391.1s.
I have to say having a time to chase is super fun.......I kind of feel like I cheated going to my LM car for stock but I tried really hard to get my 90mm chassis on pace and while I did not make it I did make the car MUCH faster then it was. That was fun.
Cheers,
Jim
Cheers,
Jim
#71
Cheers,
Jim
#72
This was from the other night. I had a pretty good run but trying too hard ends in traction rolls. I have to work on my consistency tomorrow. I’ll try some different tires and offsets.
Class- Open 4WD
Date-5/9
Location-Rotonda West, Florida
Race Time-457.8
Fastest Lap-4.37
Chassis-GLA
Body-GL Lexan P1
Wheelbase-94mm
Tires-PN
Motor-GL 5250 kv
Batteries-Nano-Tech 300 mah
Front Springs-stock
T-Plate-n/a
Motor Mount-stock
Dampener (If applicable)-stock
Dampener Fluid (If applicable)-30,000
Gearing-10t pinion
Notes-
Class- Open 4WD
Date-5/9
Race Time-457.8
Fastest Lap-4.37
Chassis-GLA
Body-GL Lexan P1
Wheelbase-94mm
Tires-PN
Motor-GL 5250 kv
Front Springs-stock
T-Plate-n/a
Motor Mount-stock
Gearing-10t pinion
Notes-
#73
Class- Open 4WD
Date-5/12/19
Location- Norwalk Ct
Race Time- 376.8 (6:15.8)
Fastest Lap- 4.71s
Chassis- GLRacing GLA V2
Body- Kyosho Autoscale R8 LMS 2015
Wheelbase- 98MM
Tires- F- PN KS Med Slick R- PN KS Soft Radial
Motor- GLRacing 3500KV
Batteries- 280mah 2S
Front Springs- Stock all around
T-Plate-N/A
Motor Mount- N/A
Dampener (If applicable)- Stock Shocks
Dampener Fluid (If applicable)- Associated 30K
Gearing- 11T Pinon
Notes- Set up as the manual suggests
Class- Open 4WD
Date-4/27/19
Race Time- 383s (6:23.0)
Fastest Lap- 4.79s
Wheelbase- 98MM
T-Plate-N/A
Motor Mount- N/A
Gearing- 11T Pinon
#74
Oh man....so close....I have done a 5s average lap over 20 laps but it is still alluding me when I try to hit that over 75 laps.
Before running this morning I gave the GLA a good cleaning and packed the dampeners. I was still getting a little hopping in turns and literally took a 1/4 of a turn on the rear camber links (a tiny bit more of negative camber) in the hopes it would cause the tire to slide a wee bit more and not catch the edge of the tire and this seemed to help a lot. The car felt totally hooked up on this run but I did have two decent taps with the armco......
MD,
That was a smoking fast fast lap you did there. When you start to string those together you will kill it.
Cheers,
Jim
MD,
Cheers,
Jim
#75
Sadly... my last run on the 96 track as it will be going to another home.
Spent a couple hours running the stock car (my other cars are too dialed in on the tracks I race at locally) and finished with my best run. I think I have one major park in the whole run - the rest of the laps were pretty clean. After seeing the last stock time I wanted to leave with a bang.
Class- Stock
Date- May 12 2019
Location- Home
Race Time- 365.2
Fastest Lap- 4.46 (with a few 4.50’s)- I have video of the lap times (scrolling through the result) but can’t upload here.
Chassis- MR03
Wheelbase- 98
Motor- PN 70
T-Plate- Pn 5
Motor Mount- PN
Gearing- 7/44
Class- Stock
Date- May 12 2019
Location- Home
Race Time- 365.2
Chassis- MR03
Wheelbase- 98
Motor- PN 70
T-Plate- Pn 5
Motor Mount- PN
Gearing- 7/44
3035Likes
