Mini-96 World Challenge >
Like Tree3035Likes
Old 04-23-2020 | 10:16 AM
  #811
Originally Posted by LJH
Weird, I literally have not had LapTracker miss a lap in tens and tens of thousands of laps. I have my phone in a cheap tripod I bought off Amazon looking down at about a 75* angle. I am not sure if this is helpful at all but here are some screen shots of my set up.
Thanks for the reply. My settings are pretty much the same. I'm still not sure what the problem is. I'm going to turn on some lights, maybe it needs more light.
MrTexR is offline
Old 04-24-2020 | 10:54 AM
  #812
LJH
Default 90mm Narrow Stock Class
Class - 90 mm Narrow Stock
Date - 4/24/20
Location - Norwalk CT
Race Time - 372.9s
Fastest Lap - 4.61s
Chassis - MR03 RWD
Body - Datsun 240z
Wheelbase - 90mm Narrow
Tires - PN KS Soft Rear/PN KS Firm Front
Motor - PN70BB
Batteries - Eneloop 800mah
Front Springs - Kyosho Green
T-Plate- Medium Kyosho Carbon
Motor Mount - PN MR9094 90mm Mid-Mount
Dampener (If applicable) - PN Carbon
Dampener Fluid (If applicable) - Dry
Gearing - 4.8:1
Notes-
I went to a stiffer carbon T-Plate. It is a little more sensitive to rolling but also faster.
Date - 4/24/20
Race Time - 389.9s
Fastest Lap - 4.71s
Chassis - MR03 RWD
Body - Datsun 240z
Motor - PN70BB
T-Plate- Kyosho M6
Gearing - 4.8:1
Traveler2 and MSAN like this.
LJH is offline
Old 04-24-2020 | 11:08 AM
  #813
Nice body Jim! How do you like the rears at 19mm?
Traveler2 is offline
Old 04-24-2020 | 12:11 PM
  #814
Scionara05's Avatar
Either im doing somthing wrong or i just plain suck at switch back tracks. Always have in 10th and still in this scale. The best lap i clicked off on my 3500kv aaa car is a 4.39 .mod car i did a 4.59 lap. Car isnt flipping its just that my cars are set for more of a sweeping corner not a dive in beake and go style. 1 switch back is fine but 3 or 4 back to back kill me cause i cant get a rhythm. The chicane is fine with me its them damn 180s.
Scionara05 is offline
Old 04-24-2020 | 12:15 PM
  #815
Scionara05's Avatar
Class-3500kv stock
Date-4,30,2020
Location-basement
Race Time-375.04
Fastest Lap-4.53
Chassis-pn 2.5
Body-12c mclaren
Wheelbase-98
Tires-10 rear slick front 20 slick
Motor-dxr sensored 3500
Batteries-1100 mah amazon
Front Springs-orange
T-Plate-pn #4
Motor Mount-pn multi
Dampener (If applicable)-tri setup
Dampener Fluid (If applicable)-dry
Gearing-54x9
Notes-
Old 04-24-2020 | 12:34 PM
  #816
At first I REALLY didn’t like this layout, but after a few runs I started to get the hang of it. Glad to see you back in it. Keep running!
Old 04-24-2020 | 12:46 PM
  #817
LJH
Meridith was out of 51t spurs so I have to run 19.5's in the back for a little extra clearance till I get a 51t spur. It amazes me just how much even a small change like wheels make on these cars. I needed to do some playing around to get it back to where it was with the 20's I am pretty much there and while I am slightly off of my overall fast lap I am consistently faster now then I was on the 20's. .
I just ran another stint with the car and I closing in on you ;-).
Cheers,
Jim
LJH is offline
Old 04-24-2020 | 12:56 PM
  #818
LJH
I feel the same way, I am usually pretty close on fast lap but I am really far off on this circuit......frustrating but I keep working on it.
I have already designed May's track, significantly different from the current track....I am thinking it will be fun.
Cheers,
Jim
NutDriver likes this.
LJH is offline
Old 04-24-2020 | 01:59 PM
  #819
I see that you are using the Eneloop batteries. Have you use the 950mah pro ones? other than running times, I wonder if they are any better/worst
MrTexR is offline
Old 04-24-2020 | 02:19 PM
  #820
Cheers,
Jim
Meridith? Marwan has some spare 51t spurs I’ll send you one! Need anything else?
I couldn’t get 5 laps in with my Focus without rolling earlier (not really sure why it changed because it was pretty good before) so I messed around with the roll center and got it a lot more stable (even though the arms are far from level). I’ll post my newer time a little later
Old 04-24-2020 | 08:22 PM
  #821
tomthegeek's Avatar
Friday Night Race Night, got laps in on both the GLR and the GLF-1. Making progress on the GLR, different tires all around have it sticking very well. I wish I could switch to a 98mm body but this will do for now. The F-1 is just dialed. Got my personal best lap of 4.05s with it tonight. Best part is I haven't changed a thing for this smaller track. I could take it to the huge local track and run it exactly the same. I noticed the front wheels are coned so I don't think my 1deg knuckles are doing much good at this point. Maybe I should switch to the 0 deg. Vacuumed the track yesterday and it seemed to make things more stable overall.
Video of the F-1
tomthegeek is offline
Old 04-25-2020 | 12:37 AM
  #822
That's a cool track tomthegeek. do you have the layout for it anywhere?
MrTexR is offline
Old 04-25-2020 | 04:55 AM
  #823
LJH
I have not tried the 950’s but I would guess they will be down on power slightly compare to the 800”s.
Cheers,
Jim
LJH is offline
Old 04-25-2020 | 04:57 AM
  #824
LJH
The the circuit drawings are shown at the beginning of the month.
Cheers,
Jim
LJH is offline
Old 04-26-2020 | 02:42 AM
  #825
NoBrainer is offline
