Mini-96 World Challenge >
Like Tree3035Likes
Old 04-24-2019 | 10:40 AM
  #31
Default Got to run a bit today
Pro-stock
4/26/19
Garage in Florida
443.6
4.75
MR-03
McLaren 12C GT3
98mm
PN oRCP radial rear KS-M compound Medium, PN KS-M compound RCP slick Front super soft
PN 50t
orion 900 hv
stock front springs
#4 carbon tplate
mm2
stock damper with friction plate
kyosho ball diff and 9t pinion
EMU likes this.
Mattdaddy1974 is offline
Old 04-24-2019 | 10:44 AM
  #32
Billy Kelly's Avatar
I seem to remember there being a video requirement( someone said that would be easy) for things to count. I know it’s just getting going but if this does start going somewhere, decision on that should be made.
Billy Kelly is offline
Old 04-24-2019 | 11:42 AM
  #33
LJH
Billy,
No need for video but we do need a screen shot of the race time.
Cheers,
Jim
LJH is offline
Old 04-24-2019 | 11:46 AM
  #34
LJH
Originally Posted by Mattdaddy1974
Pro-stock
4/24/19
Garage in Florida
425.7
4.90
MR-03
McLaren 12C GT3
98mm
PN 50t
orion 900 hv
stock front springs
#4 carbon tplate
mm2
Nice Going MD, We are pretty darn close to each others time.
Killer fast lap, I have never gone that fast with any of my MR03's.
Cheers,
Jim
LJH is offline
Old 04-24-2019 | 11:53 AM
  #35
Thanks. I will try to get the stock mr03 in the next day or two. How long are we running this layout? I’m hoping to be able to get the parts to finish the GLA and try this layout.
Old 04-24-2019 | 12:03 PM
  #36
LJH
You have plenty of time, planning on going to the end of May and then do a new layout every month from there on out.
Cheers,
Jim
asurve25 and celluvivehealth like this.
LJH is offline
Old 04-24-2019 | 12:23 PM
  #37
Sounds great. If I get a chance I’ll post a pic of the car I used.
celluvivehealth likes this.
Old 04-24-2019 | 12:25 PM
  #38
Originally Posted by LJH
Billy,
Cheers,
Jim
Ok, it was discussed in the previous thread. If this does grow it would be something to consider.
Old 04-24-2019 | 08:02 PM
  #39
Default Box Stock plus bearings
Class- Box Stock
Date- 5/12/19
Location- Rotonda West, Fl
Race Time- 452.9
Fastest Lap- 4.90
Chassis- MR03S2
Body- McLaren F1 GTR
Wheelbase- 98mm
Tires- Stock
Motor- Stock
Batteries- Orion 900HV
Front Springs- Stock
T-Plate- Stock
Motor Mount- MM
Dampener (If applicable)- Stock
Dampener Fluid (If applicable)-n/a
Gearing- Stock
Notes-
EMU and LJH like this.
Old 04-26-2019 | 04:22 AM
  #40
orcadigital's Avatar
Thats impressive with stock tires.
orcadigital is offline
Old 04-26-2019 | 06:46 AM
  #41
The saying slow is fast comes to mind. Always thought it was a dumb saying. The only upgrade is Boca Bearings. I’m sure if I tried I could probably get in the high 4 second range. The stock car is only getting faster as the motor breaks in. I believe that run was my second time running the car out the box.
Old 04-26-2019 | 09:00 PM
  #42
Default Updated my times.
Got to run two sessions for each of my MR03s. I cut some time off my Fast lap in Pro-Stock and shaved some overall time off my Box-Stock. I ran the GLA with a shaft borrowed from a WL Toys Car but its still not long enough but was able to muster up a fast lap of 5.04 even with a crippled car. The one shaft slips and last night my steering spring broke and I put one out of another controller but it's sticking. I'm beginning to see the potential in the GLA. I believe it will be a beast when everything is corrected. Heres the run. Not very consistent because of the steering and shaft deficiencies.
Old 04-27-2019 | 04:48 AM
  #43
LJH
The GLA sure can be a beast if it is set up well but boy is it a disaster if it is not.
Cheers,
Jim
LJH is offline
Old 04-27-2019 | 02:30 PM
  #44
LJH
Ohhh...I went 383s with the GLA this morning and it was in desperate need of having the dampeners repacked. I am thinking a 375s 75 lap stint is totally possible with an open car.
I will I’ll update my times once I am in front of my laptop.
Cheer,
Jim
EMU likes this.
LJH is offline
Old 04-27-2019 | 04:36 PM
  #45
duckman996's Avatar
Great Idea - hats off to you for coordinating this project. I’ll be participating in this for sure.
Question - where would a box stock FWD mini z fall in this? Can’t run a 7 tooth pinion (I think the internal ratio is different).
Have that, a stock 2WD, Open 2WD, and Open 4WD.
duckman996 is offline
