Tekno RC EB48.4 Thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree311Likes
Last edit by:
Print Wikipost
Old 06-11-2018 | 07:45 AM
  #1501
Originally Posted by Skaar_rc
So my question is. How does all the said parts hold up to some average abuse (track day once a week)?
Second question, what parts should I stock up incase anything breaks?
All depends on the track and size of jumps, etc...
There are some track layouts that I never break a single part... sometimes when learning a new layout that might have a large triple or quad and casing a large jump, I might snap an aluminum shock cap... I don't run the middle nor rear chassis braces, so I'll occasionally bend a center drive shaft. I think I bent a shock shaft once, never broke an arm, but the front arm holes tend to wallow out over time, and need to be replaced after about a year or so. After a nasty crash into a pole, I bent the front sway bar once... I usually go 2-3 months of racing before I might break a part after a weird situation. Maybe pick up a spare spur gear.... not a bad idea to check your mesh periodically, especially if you took a nasty cartwheel during a prior race, might be worth applying fresh thread lock on your motor mounts.
Best investment will be a pin replacement tool, I use this one:
https://www.amainhobbies.com/mugen-s...gb0541/p221425
I replace the pins in the driveshafts at the first hint of any flat spots... then you can expect your out drives to last indefinitely.
billdelong is offline
Old 06-11-2018 | 08:25 AM
  #1502
Thank you for your reply bill. Never thought the guy who recommend me the JX servo in youtube would respond again to my question. And I'm glad I took your advise
Just one more question. Any wear issue on the spindle and spindle carrier?
Skaar_rc is offline
Old 06-11-2018 | 08:34 AM
  #1503
I've since moved on to SRT servos
No abnormal wear that I can see on my spindles/carriers... I tend to rebuild my car once every 2-3 race days and clean/inspect my bearings. Tekno does a good job with captured hardware and I think this helps reduce wear, only way I can see stuff wearing faster would be a seized bearing.
Old 06-12-2018 | 06:55 AM
  #1504
Originally Posted by Cain
Got time to run my EB48.4 at the opening race at PRCP raceway. The track was changed to be significantly more technical. I went with what the previous owner had setup which I believe is this setup:
https://wwwcdn.teknorc.com/wp-conten...gh%20Track.jpg
For our conditions, it was significantly more loose than what i felt comfortable with.
So figure this as a starting base, what are some changes you would make for this setup for conditions that are more loose?
I would run the smooth track setup until you feel that your car is getting bounced around too much. CVA's are a big change and IMO are a must unless you're on a really blown out track. They just build much more grip
Bob Barry is offline
Old 06-12-2018 | 08:30 AM
  #1505
Ordered an eb48.4 yesterday from Tower. I'm going to take my electronics off my lx2e (2100kv motor and HW sc8). Super excited for it to arrive! It will be my first time building a kit as I figured why not make use of my time off this summer. I plan to have a fluorescent orange body and tires would most likely be duratrax lockups (I'm more of a basher than a racer).
Mo2000 is offline
Old 06-14-2018 | 11:19 AM
  #1506
Cain's Avatar
Thanks, I'll give the two setups a compare. The track though is like really loose compared to what is considered commonly loose right now lol. Buckshots in M3 compound appear to be tire of choice.
Cain is offline
Old 06-15-2018 | 06:42 AM
  #1507
Just wanted to give a little feedback on the current generation of setups. The smooth track setup is where you want to start for 90% of your tracks. If you can't handle the bumps, then you'll swap to the rough track.
For the smooth track setup, a few of us found it has a small push in the middle of the turn. This isn't a bad thing as it makes the car a little easier to drive without sacrificing speed. If you feel that you need a little more steering, you can move your front hubs forward and you'll have a ton.
The ackerman is missing from the sheets. It should be middle dot for both.
boudin4evr likes this.
Old 06-19-2018 | 01:14 AM
  #1508
Default New release ?
I hope you don’t mind me asking this, will Tekno be releasing an updated EB48.4 ? I Will be getting it for my birthday (which is coming up) and I’m aware the kit has been out for 17/18 months.
Waztrain1234 is offline
Old 06-19-2018 | 08:39 AM
  #1509
boudin4evr's Avatar
how would 100 degree temps affect this shock oil of choice?
i am running the rough track setup except full kickup
I have slight push no power in turns low to medium traction
at night when moisture is in its perfect
thanks
Last edited by boudin4evr; 06-19-2018 at 08:41 AM. Reason: left something off sorry
boudin4evr is offline
Old 06-19-2018 | 03:00 PM
  #1510
Munnster's Avatar
These setups are based around 70* temps, so 650 to 700 shock oil would be a good place to start for temps approaching 100 degrees.
Bob Barry and boudin4evr like this.
Munnster is offline
Old 06-19-2018 | 03:41 PM
  #1511
yea like Jesse said, Rule of thumb is 50 cst for every 15 degrees. Remember it's not an exact science so you'll need to experiment some. The team just did the legwork to get you started
Old 06-20-2018 | 07:56 AM
  #1512
boudin4evr's Avatar
what about my push on no power steering in 180's?
Old 06-20-2018 | 08:47 AM
  #1513
Matthew_Armeni's Avatar
Just to be clear, are you saying that the car pushes into the turn off power?
Matthew_Armeni is offline
Old 06-21-2018 | 02:55 AM
  #1514
We need to see your setup sheet in order to answer correctly.
kryss is offline
Old 06-21-2018 | 02:07 PM
  #1515
boudin4evr's Avatar
yes
