Tamiya TT02 Thread
#1743
The TT-02 high speed gear set will fit with the use of some alternative shims/spacers - HOWEVER the TT-02 gearing is very different, and the "fast spur" for a TT-02 is larger than the largest TT-01 spur so you will actually go a lot slower unless you source some special 0.6mod spur gears or try to get everything to line up with 48 or 64 pitch gears instead (not easy considering the TT-01 has fixed positions for the motor).
The 55 Spur with a 28 pinion in the TT-01 gives a ratio of around 5:1.
#1744
#1745
I just have a quick question hoping someone here might have an answer
. I'm ordering the yeah racing titanium screw set to replace the stock screws in my TT02. I think these screws are all metric sizes but I have no idea about what hex driver size I will need for the installation. I checked the yeah racing website but it doesn't say anything about that. So my question is what size do I need? I have hex screw drivers in SAE sizes but not metric at the moment
Thanks in advance.
Thanks in advance.
#1748
Hey guys, looking for some advice here.
I've had a few runs on my TT02 and I noticed that it has unequal on power steering. It tends to push to the left much more than it does to the right, it is especially noticeable when coming around a right hand sweeper. It can make nice tight left hand turns but pushes on the other direction.
I've checked the car on a setup station and everything seems to be more or less equal on both sides (considering the slop it has) including steering throw. Also the car seems to have equal left and right steering when doing low speed circles on the ground.
I also checked for tweak and the car seems pretty straight. It also tracks straight on the straigtaway.
When I punch the throttle with the car in my hand, it pulls down towards the right rear wheels. Could this be torque steer thats fighting the rotation of the car when it's steering to the right on power? (Car tries to lean to left but the motor torque is doing the opposite)
Haven't owned a shaft driven car in a long time, anything I can do with setup to alleviate this or do I have to adapt my driving to it?
Right now I have to go off throttle early before the turn to allow it to rotate.
My setup:
Base TT02
17.5T Motor
#10K Diffs F/R
Front Negative toe-in ~1degree
#500 Oil Dampers F/R with Tamiya Yellow Springs
6mm Rideheight
All else unadjustable.
Thanks!
My setup:
Base TT02
17.5T Motor
#10K Diffs F/R
6mm Rideheight
Thanks!
#1750
My setup:
Base TT02
17.5T Motor
#10K Diffs F/R
6mm Rideheight
Thanks!
My setup:
Base TT02
17.5T Motor
#10K Diffs F/R
6mm Rideheight
Thanks!
#1752
#1754
maybe model something along the lines of the 54651 upper arm mount bracket but extend it so it protrudes from the front or rear so you can slot it for a bar and then put a clamp on to hold a sway bar down.
#1755
Thanks all for your input. I will come up with something. After looking at it a little it really needs to mount to the bulkhead somehow. I think I could make something up with socket screws and some keystock. A better option would be to recast a bulkhead with the bar holders, similar to a DB01.
1387Likes
