Tekno RC EB410 Thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree2421Likes
Last edit by:
Print Wikipost
Old 03-08-2018 | 08:46 AM
  #3961
That top hole of the exotek hubs combined with the diff shims will make it so the dog bones won't have enough engagement while in full droop.
I was able to make these HB rear axle rebuild kit longer dog bones resolve the issue. You have to do some minor filing so they fit the outdrives properly but its minimal.
EbbTide likes this.
Tbuggy is offline
Old 03-08-2018 | 08:52 AM
  #3962
EbbTide's Avatar
I think I got the top and bottom confused. Looks like a decent option if you need to run that setup. On clay I haven't needed the shims
EbbTide is offline
Old 03-08-2018 | 08:53 AM
  #3963
Matthew_Armeni's Avatar
Originally Posted by charvel74
I'm currently not running that forward shock setup I wasn't happy how the dog bones align with the outdrives it didn't insert far enough in so I managed to break to outdrives in the process I put all the shims in the rear of the arms to try to push everything forward to correct the angle but still it's not good enough
The arm needs to be shaved down 1.5mm when you flip them around, otherwise the hub is too far forward when compared to stock setup.
EbbTide likes this.
Matthew_Armeni is offline
Old 03-08-2018 | 08:54 AM
  #3964
Here are some pics, I may have already posted these, but don't remember.
Tbuggy is offline
Old 03-08-2018 | 09:32 AM
  #3965
You are right it didn't prove to be necessary on my clay track. I have just been playing around with extremes setup changes so I can identify the changes better. I don't feel I tend to pick up on the subtle differences so when I do extreme changes I can tell right away what the affect may be then tone it down till I like it.
I don't race (yet) but I enjoy being fast and in control on the track!
Tbuggy is offline
Old 03-08-2018 | 09:38 AM
  #3966
EbbTide's Avatar
That's a very good idea actually. It'll help you in the long run with deciding what setup changes you need rather than guessing I would do it myself but every setup change I do are spoons I don't want to use lol (spoons = energy with Lupus)
EbbTide is offline
Old 03-08-2018 | 10:14 AM
  #3967
I did shave them down but I think the exotek hubs m8ght have exaggerated the problem
charvel74 is offline
Old 03-08-2018 | 10:23 AM
  #3968
I believe the Exotek hubs replicate stock geometry so they shouldn't make it any worse, unless you're using the hinge pin hole that's closer to the axle, which I wouldn't recommend.
HK SBR likes this.
Old 03-08-2018 | 10:36 AM
  #3969
That's what I did . I thought it would help the geometry when using the diff risers
Old 03-08-2018 | 11:44 AM
  #3970
Understanding setups is a big part of the hobby that I like. Its fun to play with and learn what does what too me anyhow.
Rarely has someone else's setup worked for me without changing something slightly to suit me.
EbbTide and charvel74 like this.
Tbuggy is offline
Old 03-08-2018 | 11:47 AM
  #3971
EbbTide's Avatar
Same here as far as using someone elses setup. I usually start with the kit setup and work from them or in my current case, I went with the recommended 13.5 setup and made my own changes where I felt I needed it. Like I run no front sway bar and my ride height is different than what the setup asks for. Mostly just the shocks and diffs are the same as the recommended setup lol
Tbuggy likes this.
EbbTide is offline
Old 03-08-2018 | 12:19 PM
  #3972
Are you using the optional C and D plates when you're using the riser pads?
Old 03-08-2018 | 12:47 PM
  #3973
I just changed to the 13.5 setup. Going to give it go this weekend hopefully. Who knows where it will end up at though.
dirtyd_nd is offline
Old 03-08-2018 | 12:56 PM
  #3974
Yes
Old 03-08-2018 | 02:17 PM
  #3975
Tandum4056's Avatar
Is the EB410 a good choice for 13.5 spec class on high traction turf or does it need a bunch of upgrades/fixes out of the box to be competitive. I am torn between this buggy and the XB4 2018.
Tandum4056 is online now
