Tekno RC EB48.4 Thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree311Likes
Last edit by:
Print Wikipost
Old 12-04-2017 | 12:58 PM
  #1351
When you get it, ask for help here if you have issues. Lot's of knowledgeable folks.
patyroach likes this.
ezlight is offline
Old 12-04-2017 | 02:53 PM
  #1352
What is the benefit of not running a center and/or rear chassis brace? I see some setups that have the front brace checked, but not the center or rear. Thoughts?
Kev1966 is offline
Old 12-04-2017 | 02:55 PM
  #1353
EbbTide's Avatar
It allows more chassis flex which aids traction on bumpier tracks. If you remove the rear brace, essentially the rear end should feel a little more planted and vice versa.
Kev1966 likes this.
EbbTide is offline
Old 12-04-2017 | 04:07 PM
  #1354
Thanks for the info.
Kev1966 is offline
Old 12-05-2017 | 10:31 PM
  #1355
hi everybody.
Is someone try to change the wide with the "Blocks" ? I would like to try a narrowed width on the front. Good idea?
thx a lot
kryss is offline
Old 12-06-2017 | 12:10 AM
  #1356
Originally Posted by kryss
hi everybody.
thx a lot
Lots of ways to do this with hubs, thinner hex and such. Narrow track width can improve handling characteristics. Mainly more side bite in the corner. Makes overall grip increase or feel like it has, especially on tight indoor tracks. Keep in mind that it makes the car harder to drive and not as forgiving. Might even traction roll. I don't feel it is needed for most tracks, but you are the only one who can test it to confirm its right for you and your track. Test it and share your findings with us here.
Thunder Trail is offline
Old 12-06-2017 | 03:08 AM
  #1357
ok, that's what i expected. I'll try this when the track will be dry.
kryss is offline
Old 12-06-2017 | 10:46 AM
  #1358
1/8 IC Fan's Avatar
the Natural vs. Black Composite spur gear... no differance right? I just happend to find one at the LHS in Natural.
1/8 IC Fan is offline
Old 12-06-2017 | 10:52 AM
  #1359
EbbTide's Avatar
Nope no difference. Just dye for the black spur.
1/8 IC Fan likes this.
EbbTide is offline
  #1360
Matthew_Armeni's Avatar
No difference other than color.
Matthew_Armeni is offline
Old 12-06-2017 | 11:19 AM
  #1361
1/8 IC Fan's Avatar
Thanks guys, figured but was not 100% sure...Dye you say, hmm...
Old 12-17-2017 | 09:19 AM
  #1362
Anyone experience any "slop" in the center diff when installing TKR 5262 CNC Split diff mount? They are installed correctly (bearing notch) but the front of the center diff has about .064 of slop in it. It spins free but it did not have the play when I was using the OEM plastic mount
Yellowhorse7 is offline
Old 12-18-2017 | 10:15 AM
  #1363
I never used the aluminum diff for the EB, I had it on my truggy. No, I didn't notice any play. But that little amount of play, use one of the shims for the F/R diffs and space it out.
ezlight is offline
Old 12-18-2017 | 10:23 AM
  #1364
Old 12-18-2017 | 10:32 AM
  #1365
Use the plastic hold downs. This should solve the issue
Fred Perkins is offline
