Associated RC 12 R5.2 >
Like Tree24Likes
Old 05-05-2017 | 10:08 AM
  #1126
valk's Avatar
Pretty excited to see what the new car has in store though i think it will be more of the conventions we see elsewhere. But this is ok.
My first car was a 12r5.1 so might be time to come back to ae camp.
valk is offline
Old 05-05-2017 | 11:14 AM
  #1127
Definitely not, you will see lots of new parts.
Kave is offline
Old 05-05-2017 | 11:32 AM
  #1128
aracefan's Avatar
Reading your posts Kave, will most assuredly be bad for my bank account!!
aracefan is offline
Old 05-05-2017 | 01:33 PM
  #1129
I don't run for AE and haven't for a long time but I think it's important to acknowledge when a cool new product is released from any company and I think this is one people who run AE cars will be very happy with.
aracefan likes this.
Kave is offline
Old 07-12-2017 | 11:35 AM
  #1130
tkge's Avatar
I got a 12R5.1 with lipo conversion kit to install. Does anyone have a good CRC grey carpet setup for 17.5 class? Any help is appreciated.
tkge is offline
Old 07-12-2017 | 03:17 PM
  #1131
bertottius's Avatar
Blue front tires, Green rear tires, Associated blue center spring, Black side springs, Associated 18 or 19 front springs is a good starting point
bertottius is offline
Old 07-12-2017 | 04:47 PM
  #1132
tkge's Avatar
Thanks!
tkge is offline
Old 07-12-2017 | 05:04 PM
  #1133
bertottius's Avatar
Thanks!
No problem.
Old 08-08-2017 | 04:53 AM
  #1134
teklein's Avatar
Whoops. Ignore this.
teklein is offline
Old 10-15-2017 | 06:44 PM
  #1135
Does any one know where I can get right side brushless hub? Part # - ASC4608
SMOKESHOW86 is offline
Old 10-15-2017 | 07:20 PM
  #1136
MD's Avatar
MD
Associated 12R5 Hub (Brushless Pod) Part # ASC4608 | eBay
http://gshobby.com/content/associate...brushless-12r5
https://www.absolutehobbyz.com/Team-..._p_498669.html
MD is offline
Old 11-07-2017 | 06:03 PM
  #1137
No9's Avatar
No9
Can anyone tell me what other brand axle ride height adjusters fit the R12 5.2
No9 is offline
Old 11-07-2017 | 07:23 PM
  #1138
durtbag's Avatar
I used these when I ran AE.
https://www.tqrcracing.com/shop/prod....asp?p_id=2865
Leave a little flashing on them and they fit nice and snug.
No9 and aracefan like this.
durtbag is offline
Old 11-08-2017 | 05:03 AM
  #1139
Aaron_M's Avatar
The CRC ones work well and allow with much finer adjustments than the standard Associated ones.
Aaron_M is offline
Old 11-13-2017 | 07:00 PM
  #1140
Lord_Darkhelmet's Avatar
Default help with setup problems
I'm having trouble getting the car to be smooth and less twitchy. I have changed the car to run a transverse battery by using the pivot assembly and upper deck from a 12r6. Only other change is the shock, using a one from a 12r6.
We run on CRC black carpet and I'm using the CRC spec tire. The car is not easy to drive and likes to lift the rear inner wheel. Its so responsive just breathing on the steering makes it react hard.
I have tried a soft setup like Keven H but it seems to make it even more aggressive. Soft side springs and heavy tube lube (20k) make the rear wheel lift problem even worse. I was running the dynamic caster block at 10deg and changed it to 5deg, this was the only adjustment which made the car somewhat easy to drive. I have no idea why a soft rear setup is not helping. A fellow racer has a CRC car running soft setup and the car is super smooth to drive.
Attached is my current setup that is somewhat driveable. I hope someone can see something I missed. The only thing I was thinking was to remove the 1mm lower arm spacer and make the front end narrower. I have also tried a high amount of steering expo and turning down the dual rate.
File Type: pdf
Lord_Darkhelmet is offline
