Tekno RC EB48.4 Thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree311Likes
Last edit by:
Print Wikipost
Old 04-14-2017 | 06:09 AM
  #751
what size drill bit is everyone using to ream out the arms 2 mm maybe wish they put regular bit sizes in the instructions .thanks in advance
ScottZ is offline
Old 04-14-2017 | 06:34 AM
  #752
EbbTide's Avatar
I had to pick up a #19 drill bit. Kinda hard to find but it works.
EbbTide is offline
Old 04-14-2017 | 06:39 AM
  #753
vwduud's Avatar
Works way better:
https://www.lowes.com/pd/Oregon-Chai...g-File/1112123
ezlight likes this.
vwduud is offline
Old 04-14-2017 | 06:48 AM
  #754
thanks will pick it up today
ScottZ is offline
Old 04-14-2017 | 08:45 AM
  #755
Yes, go for the chain saw file. Most of us have moved to that, and it's safer. The #19 bit was the old method and worked, but less precise and you could make mistakes if the bit grabs the plastic and cuts too much. Amazon option:
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
RokleM is offline
Old 04-14-2017 | 08:47 AM
  #756
Mikeand22's Avatar
I'm wondering if the anodizing process is why the shock collars are so loose. My rear shocks are much lighter than the front shocks and the tears are loose. My fronts are much darker and tighter.
Mikeand22 is offline
Old 04-14-2017 | 09:01 AM
  #757
pballer2777's Avatar
easy way to find out is the tray a rear collar on a front shock.
pballer2777 is offline
Old 04-14-2017 | 09:47 AM
  #758
mike142's Avatar
Anyone notice that the kit doesn't seem to include enough rear wheelbase shims?
It seems you need a total of 12mm worth of shims, but the kit only includes 10mm. (4x2mm and 2x1mm).
All the setup sheets on their sites use 12mm (6mm on each side)....? Am I missing something?
mike142 is offline
Old 04-14-2017 | 09:52 AM
  #759
I noticed this, too - more play on the outer hinges than I would have expected...
Jason B is offline
Old 04-14-2017 | 10:28 AM
  #760
The stock setup in the manual only calls for 5mm of shims per side. There isn't room for 6mm per side unless you remove a little material from the arm or the hub.
anr211 is offline
Old 04-14-2017 | 10:41 AM
  #761
The extra mm shim fit in mine without any material needing to be removed.
Jason B likes this.
crash n go is offline
Old 04-14-2017 | 10:52 AM
  #762
I think what he's saying is that there is room for 1mm+, and I found that to be the case on mine, too. I doubt the play will be an issue, but definitely something I noticed.
Jason B is offline
Old 04-14-2017 | 10:53 AM
  #763
mike142's Avatar
I also used 6mm on one side and it fit perfect. 5mm seemed to have way too much play.
mike142 is offline
Old 04-14-2017 | 11:40 AM
  #764
hoyt1967's Avatar
Mine too, I added an exta 1mm as the play bothered me..... I'm sure it will matter when I'm smashing pipes and tumbling down the straights, lol.
Jason B likes this.
hoyt1967 is offline
Old 04-14-2017 | 01:32 PM
  #765
Rasheed's Avatar
this seems like a dumb question, but...
My old (but still working) orion 1900kv motor only has M4 holes on it. The Tekno motor mount uses M3 screws. Is there any solution to this problem other than buying a new motor?
Rasheed is offline
