Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 01-23-2017 | 11:28 AM
  #1156
eR1c's Avatar
viking44,
i will check my kit tomorrow. I built up a Drift "S" kit (yet made it a non drift). I still have everything I didn't use in the box, if I have the parts i'd be happy to send them to you as I don't anticipate using them. ...will get back to you tomorrow (at work now)
eR1c is offline
Old 01-23-2017 | 12:25 PM
  #1157
Thanks in advance for the help guys. I'll keep searching on my end. I'll hold off buying the extra hubs until I can get a set of 4 long axles.
And to add to the discussion, I just saw that blue chassis too. Might look pretty cool under a blue Impreza body...
viking44 is offline
Old 01-23-2017 | 02:42 PM
  #1158
Long axles came with the Mercedes SLS version (1 wide axle per sprue) for the rear end. Ferrari 458, Capri and Porsche 911 definately did not.
Mini35 is offline
Old 01-27-2017 | 11:04 AM
  #1159
eR1c's Avatar
Question for other TT02 owners. I've had mine built for a while and just recently decided to go looking for the wide axles and realized they're not in the box. Is it possible Tamiya doesn't include them in all the TT02 kits? I have the 99 Monte Carlo Impreza. Maybe the wide/long axles only came in the Porsches? Can anyone confirm?
I can confirm that my Drift "S" kit did NOT come w/ extra hubs and longer axles.
..funny, though I purchased the Mercedes body separately from the kit and it fits just fine w/ the "standard" hubs and axles, the fit seems perfect in my opinion. ...in fact I plan on posting some photos soon as I think this is one of the best looking paint jobs i've done. ...really happy w/ the way this one came out.
eR1c is offline
Old 01-27-2017 | 11:22 AM
  #1160
Originally Posted by tommy1030
Good news that tamiya will release the white
part A and white spur gear cover. Must buy item for those who use the white tub!
I've got this setup and it looks gash as the tub is a cream colour and the motor cover is bright white. I'm expecting the "soft" parts (battery posts and bumpers etc) will bra different shade too so it'll all look a bit mismatched.
Mini35 is offline
Old 01-27-2017 | 11:27 AM
  #1161
. The Type S has completely different axles and suspension to the stock TT02 though so it would've been very odd if it had come with long (wide track) axle shafts lol.
Mini35 is offline
Old 01-27-2017 | 11:28 AM
  #1162
eR1c's Avatar
I just had an interesting thought,
if you have the white parts, you may be able to dye them any color you'd like. I am not sure how this plastic would take to being dyed, but you can do this w/ many white colored wheels ...i can find the actual technique, but I believe you slightly heat the plastic in a pot of dyed water. I believe you can use "RIT" dye (used for fabric).
just a thought-
eR1c is offline
Old 01-27-2017 | 11:31 AM
  #1163
eR1c's Avatar
. I wouldn't laugh, -odder things have happened. My Tamiya M06 kit came w/ a bunch of M05 specific parts. Tamiya is known to include lots of option parts and/or parts from other related kits. My TT02 for example did come w/ the suspension parts for the non drift version (it came w/ both suspension sets). --so it is conceivable to me at least that they could have included the longer axles and hubs.
eR1c is offline
Old 01-30-2017 | 11:22 AM
  #1164
valladolidRc's Avatar
Thumbs up
Originally Posted by Raman
Tamiya is releasing two new hard chassis for the TT02.. one in white and one in blue. Should have done black as well..
47339  TT-02 Lower Deck (Hard/Blue)
47340  TT-02 Lower Deck (Hard/White)
Thanks for the info!!
valladolidRc is offline
Old 01-30-2017 | 12:45 PM
  #1165
I have ran the harder deck. Very good and worth the money, just wish it was black.
http://www.thercracer.com/2017/01/47...hard-blue.html
Qatmix is offline
Old 01-30-2017 | 04:50 PM
  #1166
eR1c's Avatar
I painted up a new body for my TT02,
I don't have the correct wheels on it, ...i put them on quickly to snap a few photos. They have the incorrect offset in the rear. Also I have to trim the body posts so they are not sticking up so high. ...so kind of still a work in progress.
Attached Thumbnails Tamiya TT02 Thread-01.jpg   Tamiya TT02 Thread-02.jpg   Tamiya TT02 Thread-03.jpg   Tamiya TT02 Thread-04.jpg
eR1c is offline
Old 01-30-2017 | 08:08 PM
  #1167
Raman's Avatar
Nice paint job.. Looking good
Raman is offline
Old 01-31-2017 | 09:50 AM
  #1168
eR1c's Avatar
thanks!
its simple, ..but it works for me.
eR1c is offline
Old 01-31-2017 | 07:49 PM
  #1169
Raman's Avatar
Not so simple.. you did all the panel lines in black.. that's a lot of work!
Raman is offline
Old 02-01-2017 | 12:05 AM
  #1170
tobyzhang's Avatar
Anyone has experience running the TT02 type s for TCS spec novice? My girl friend is doing spec novice class this year with a TT02R but I'm curious if the much more precise ta05 long reversible suspension makes a noticeable difference with the crappy spec tires.
Thanks!
tobyzhang is offline
