Tamiya TT02 Thread >
Tamiya TT02 Thread
Like Tree1145Likes
Tamiya TT02 Thread
    Hide Wikipost
Old 01-14-2021, 03:44 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Tamiya TT02 Thread
Last edit by: pparrett
TT02 Wiki - Post your setups, upgrades and home grown ideas here for us to read...
TT02 vs the TT-01
http://www.thercracer.com/2013/01/ta...irst-pics.html
New flat chassis layout - Easier to run LiPOs vs the cutouts in the TT-01s
Revised suspension geometry
Support for std spur gears
MODELS ----------------------------------------------------
Changes that follow are in comparison to the basic kit.
TT02 - Base Kit. Friction Dampers.
TT02D - Drift: Drift Tires, Hardened A-Parts, Oil Shocks
TT02R - Race: Rear Alu 3* Toe In Hubs, Alu Propshaft + Cups, CVA oil Dampers
TT02RR - Race+: TT02R + Adjustable Upper Arms, Oil Filled Diffs, Hardened Blue Chassis
TT02S - Type S: TRF416 arms, FRP shock towers, bearings,
TT02SR - TypeS Race: TT02S + Double cardan front drive shafts, rear lightweight universals, Rear sealed oil differential, front spool
TT02B - Buggy. Offroad: CVA Shocks, Double Wishbone long suspension
HOP UPS ----------------------------------------------------
Bearings:
#54476 Ball Bearing Set TT02: 8x 1050, 4x 1280, 4x 1150
Propshaft:
#54501 Alum Propeller Shaft TT02
#54502 Alum Propeller Joint TT02
Tip:
Put a 3mm piece of well greased silicone hose between the dog bone and the shaft of each wheel to reduce slop.
Motor Mount and Gearing:
#54558 TT02 Aluminum Motor Mount
#54500 High Speed Gear Set
#54875 Oil Gear Differential
Steering:
#54550 Low Friction Step Screws
- Full Upgrade Kit -
#54752 Steering Upgrade Kit, Includes all below.
- Individual Parts -
#54574 Aluminum Steering Set
#54575 Aluminum Steering Bridge
#54799 Hi-Torque Servo Saver or #51000 Servo Saver Black
#54248 Aluminum Turnbuckles 3x23
#50797 5mm Short Adjustable Turnbuckle End
Dog Bones to Universal Joints:
- Standard Steel -
#53792 Universal Shaft Assembly (steel), NOTE: Must also use item 54477 on the TT-02
#54477 Gearbox Joint for Universal Shaft (steel) (2pieces)
- Lightweight -
#53506 Blue Aluminum 39mm Swing Shaft
#53499 Wheel axle for assembly universal
#53681 Titanium wheel axle for assemblu universal (but this is very expensive)
#53500 cross joints for universal
#54477 Gearbox Joint for Universal Shaft (2pieces)
Tip: Run steel in the front, Alu is okay for the rear but the front takes a lot of wear and impact from crashes
Shock Options:
#54753 Super-mini CVA Oil Shocks, comes with med black springs
#42102 TRF 55mm Shocks
Chassis:
#54639 Carbon Damper Stay Front
#54640 Carbon Damper Stay Rear
#47339 Hard Lower Deck Blue
#47340 Hard Lower Deck White
#54926 Hard Lower Deck Black
#54733 Aluminum Rear Uprights, Gives 3* rear toe in for extra stability
#54549 Aluminum Rear Uprights, 2.5* Rear Toe In
#58584 Hardened A-Parts, Uprights, Hub Carriers, Diff Covers, etc
SUGGESTED BASE SETUPS ----------------------------------
Bashing:
Build to the kit instructions and have fun!
Asphalt Parking Lot Racing:
Front Diff: 300k-500k (or Tamiya #42247 Gear differential putty)
Rear Diff: 3K oil in the rear diff for low / medium grip, 5k oil in the rear for medium / high grip
Carpet Indoor Racing:
Rear Diff: 7k -10k in the rear diff for very high grip carpet.
ADDITIONAL RESOURCES -------------------------------------
TT02 Build and Review here
http://www.thercracer.com/2013/05/ta...nd-review.html
TT02 Tuning and Mods Guide
http://www.thercracer.com/2014/08/ta...-and-tips.html
https://www.rcdriver.com/take-the-versatile-tamiya-tt-02-chassis-to-the-next-level/
Gearing for 17.5t Blinky
http://www.thercracer.com/2013/07/ho...inky-with.html
Print Wikipost
Old 01-09-2017, 02:59 PM
  #1156
Raman's Avatar
Trader Rating: 94 (100%+)
Originally Posted by Qatmix
Yep, it's cool they are doing those stiffer chassis. But blue or white??
I get the white since they already have a white. I'm perplexed at the blue, it will look too gaughty in my opinion.
Raman is offline
Old 01-10-2017, 10:15 PM
  #1157
Good news that tamiya will release the white
part A and white spur gear cover. Must buy item for those who use the white tub!
tommy1030 is offline
Old 01-11-2017, 10:18 AM
  #1158
eR1c's Avatar
I like the color options ...but think i'll stick w/ black.
eR1c is offline
Old 01-22-2017, 10:01 PM
  #1159
Question for other TT02 owners. I've had mine built for a while and just recently decided to go looking for the wide axles and realized they're not in the box. Is it possible Tamiya doesn't include them in all the TT02 kits? I have the 99 Monte Carlo Impreza. Maybe the wide/long axles only came in the Porsches? Can anyone confirm?
In which case, I'm now searching for 4 long axles and 2 wide hubs (I still had a pair of the wide hubs attached to the sprue).
viking44 is offline
Old 01-23-2017, 09:46 AM
  #1160
wtcc's Avatar
I seem to remember to have had them come with the Super GT Nissan GT-R, even though they are not needed for the build.
wtcc is offline
Old 01-23-2017, 11:28 AM
  #1161
eR1c's Avatar
viking44,
i will check my kit tomorrow. I built up a Drift "S" kit (yet made it a non drift). I still have everything I didn't use in the box, if I have the parts i'd be happy to send them to you as I don't anticipate using them. ...will get back to you tomorrow (at work now)
eR1c is offline
Old 01-23-2017, 12:25 PM
  #1162
Thanks in advance for the help guys. I'll keep searching on my end. I'll hold off buying the extra hubs until I can get a set of 4 long axles.
And to add to the discussion, I just saw that blue chassis too. Might look pretty cool under a blue Impreza body...
viking44 is offline
Old 01-23-2017, 02:42 PM
  #1163
Long axles came with the Mercedes SLS version (1 wide axle per sprue) for the rear end. Ferrari 458, Capri and Porsche 911 definately did not.
Mini35 is offline
Old 01-27-2017, 11:04 AM
  #1164
eR1c's Avatar
I can confirm that my Drift "S" kit did NOT come w/ extra hubs and longer axles.
..funny, though I purchased the Mercedes body separately from the kit and it fits just fine w/ the "standard" hubs and axles, the fit seems perfect in my opinion. ...in fact I plan on posting some photos soon as I think this is one of the best looking paint jobs i've done. ...really happy w/ the way this one came out.
eR1c is offline
Old 01-27-2017, 11:22 AM
  #1165
I've got this setup and it looks gash as the tub is a cream colour and the motor cover is bright white. I'm expecting the "soft" parts (battery posts and bumpers etc) will bra different shade too so it'll all look a bit mismatched.
Mini35 is offline
Old 01-27-2017, 11:27 AM
  #1166
. The Type S has completely different axles and suspension to the stock TT02 though so it would've been very odd if it had come with long (wide track) axle shafts lol.
Mini35 is offline
Old 01-27-2017, 11:28 AM
  #1167
eR1c's Avatar
I just had an interesting thought,
if you have the white parts, you may be able to dye them any color you'd like. I am not sure how this plastic would take to being dyed, but you can do this w/ many white colored wheels ...i can find the actual technique, but I believe you slightly heat the plastic in a pot of dyed water. I believe you can use "RIT" dye (used for fabric).
just a thought-
eR1c is offline
Old 01-27-2017, 11:31 AM
  #1168
eR1c's Avatar
. I wouldn't laugh, -odder things have happened. My Tamiya M06 kit came w/ a bunch of M05 specific parts. Tamiya is known to include lots of option parts and/or parts from other related kits. My TT02 for example did come w/ the suspension parts for the non drift version (it came w/ both suspension sets). --so it is conceivable to me at least that they could have included the longer axles and hubs.
eR1c is offline
Old 01-30-2017, 11:22 AM
  #1169
valladolidRc's Avatar
Thumbs up
Originally Posted by Raman
Tamiya is releasing two new hard chassis for the TT02.. one in white and one in blue. Should have done black as well..
47339  TT-02 Lower Deck (Hard/Blue)
47340  TT-02 Lower Deck (Hard/White)
Thanks for the info!!
valladolidRc is offline
Old 01-30-2017, 12:45 PM
  #1170
I have ran the harder deck. Very good and worth the money, just wish it was black.
http://www.thercracer.com/2017/01/47...hard-blue.html
Qatmix is offline
