Tamiya TT02 Thread
#1906
#1907
Do you have another Spektrum or a DSM2 compatible receiver you can use other than the AVC one? I have one of those SR3100 orange receivers and had a TBLE-02S soldered directly into a Torque Tuned motor and it ran without getting hot.
#1909
If it's the case, it also doesn't help that the TBLE-02S has, like, no fancy features on it to protect itself from too much current besides the basic over voltage. But considering the quantity made, it wouldn't surprise me that better protection measures were cut for cost. Which is too bad. The TBLE-02 is great.
#1910
My friend's car has a orange reciver that I wired directly with no problems so far. I'm waiting for the LHS to get me a 2 channel spectrum reciver think it's the sr215. Personally I think that Tamiya ESC is a POS. $70 for that thing is way to much. The only reason I'm using it is because the track requires it for the class. Tamiya meeds to get out of the 1900s and put a brushless motor with a descent ESC. I don't think this one even has lipo cut off.
#1913
I'm trying to get my stuff from the LHS, since they have a track for me to race on. I do get practically everthing from them, but $25 is much better then the over $70. I'm already getting another motor and reciver from them to try and fix this problem. Did anyone else have this problem with this ESC?
#1916
Sounds like a fairly high expenditure for an out of the box novelty class.
I run a Trackstar TS-D99X with a TBLE02 with no issue.
#1918
On car that smoked ESC:
Spectrum S6180
100 oz-in @ 6.0v
0.14 sec/60* @ 6.0v
On another car I have with no problems.
Spectrum S6240Rx
208 oz-in @ 6.0v
0.08 sec/60* @6.0v
Spectrum S6180
100 oz-in @ 6.0v
0.14 sec/60* @ 6.0v
Spectrum S6240Rx
208 oz-in @ 6.0v
0.08 sec/60* @6.0v
#1919
Maybe purchase another S6240Rx and put it in your problem car? I have a Savox SC-0254MG which has similar speed and it works/ed fine with the TBLE02
#1920
Euro Truck is a box stock spec class, so was just trying to understand what type of servo was causing the TBLE02 S to go up in smoke in. It only has a 1.5 amp bec so the choice of a high current servo is asking for trouble...
