Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 01-23-2017 | 02:57 PM
  #28621
Originally Posted by Raman
Can someone direct me to a link or post on how to make the TA03 ball diff as tight as possible.
I have tightened mine as far as it will go and secured it with thread lock. I'd like to have it even tighter of possible.
I have done my research and have treid some suggested tricks but nothing I have tried has made it tighter so far.
I have added 2x 0.2mm shims to my ta03 ball diff and it was tight ,almost spool and it doesn't came to loose again😀
kytr8matic is offline
Old 01-24-2017 | 08:33 AM
  #28622
DarthRacer's Avatar
For those of you racing on the new black ozite carpet using a gear diff, what weight diff fluid are you using?
DarthRacer is offline
Old 01-24-2017 | 12:01 PM
  #28623
Raman's Avatar
Where are you putting the shims?
Raman is offline
Old 01-26-2017 | 03:54 PM
  #28624
Initial D - Honda S2000 of Dr. Toshiya Joushima on an M05 chassis.
rccartips is offline
Old 01-26-2017 | 04:42 PM
  #28625
sakadachi's Avatar
The Hachiroku looks good! but that S2K.. WTF!!
sakadachi is offline
Old 01-26-2017 | 05:02 PM
  #28626
That's the best I could do to turn a Mazda MX5 into a Honda S2000
Old 01-26-2017 | 06:50 PM
  #28627
I like it
sipaboy is offline
Old 01-27-2017 | 04:07 PM
  #28628
I put the shims right under the screw to tighten the diff..
So, what i did is open the diff remove the screw, insert shims and put it back again
Old 01-27-2017 | 05:07 PM
  #28629
TENCHO's Avatar
i wish Tamiya would make a New Ford Fiesta ST body....for the M05
TENCHO is offline
Old 01-28-2017 | 06:46 AM
  #28630
Agree.. i have the real car of mk7 fiesta, been searching online for scale ford fiesta m chassis body.. no results 😖😖😖 other brand make the body just look alike, the exact same detail body that i've found just hpi wr8 body (1/8) and rs micro (1/24)
Old 01-29-2017 | 06:25 PM
  #28631
theproffesor's Avatar
I just installed the adjustable upper links and M05ra hubs and knuckles on the front of my car. I am now getting some serious bump steer. Like 5 degrees out when extended to 5 degrees in when compressed. I can't figure out how to get rid of it. It's causing a major issue with handling. The le car is unpredictable and very squirmy.
theproffesor is offline
Old 01-29-2017 | 06:33 PM
  #28632
Ok... I guess you'll have to take it off...
bertrandsv87 is offline
Old 01-29-2017 | 07:20 PM
  #28633
IndyRC_Racer's Avatar
professor, did a quick internet search and found your answer on the tamiyaclub.com website. Here is a link - http://www.tamiyaclub.com/forum/inde...d-info-please/
Basically you need to go with a longer ball connector/stud on the steering knuckle. According to the post you need Tamiya part number 19805825.
Check out this picture and you will see the longer ball stud which is a brass piece
https://www.tamiyausa.com/product/it...oduct-id=92231
Bump steer is usually caused when the steering turnbuckles change at a different rate/angle when compared to the front a-arms. Adjusting the height of the ball stud on the steering knuckle should help alleviate/lessen the excessive bump steer.
IndyRC_Racer is offline
Old 01-29-2017 | 07:31 PM
  #28634
gigaplex's Avatar
Which holes did you use to mount the rally hubs? Is there a particular reason you went for the rally ones? You need to use extra long ball studs on the knuckles when using the raised ride height setting on the rally hubs.
Edit: Looks like IndyRC beat me to it
gigaplex is offline
Old 02-06-2017 | 11:45 AM
  #28635
NomadRacer's Avatar
Could someone recommend a Savox servo for the M05 that's less than 50 bucks?
NomadRacer is offline
