Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 03-08-2017, 02:07 PM
  #28771
R/C Tech Elite Member
monkeyracing's Avatar
Originally Posted by ruebiracer
Hi Jim,
last carpet race I ran outside front and rear, Front shocks with long ball pin 64mm from outside to outside measured, rear 60mm with short ball pin.
Not sure, if I used longer piston rods in rear to achieve the 60mm, though.
Br,
Matthias
Thank you! I can get 60mm with the current shafts. 64mm is achievable with the long connectors. I'm considering trying this on each of my cars, as I seem to have a lot of the ball end hinge pins.
Jim
monkeyracing is offline
Old 03-08-2017, 02:44 PM
  #28772
Laguna Bozo's Avatar
Jim,
I think 64mm will be a little too long in the front, 62-63 better, at least at the Tamiya track (outdoor asphalt of questionable quality right now). Also, the normal rear shock position works better for me than the hinge pin position. Good luck.
Craig
Laguna Bozo is offline
Old 03-08-2017, 03:20 PM
  #28773
Schs2013's Avatar
Originally Posted by ErikJan
Our local Tamiyacup organization was very quick with their reply to the Yeah racing diff:
https://sites.google.com/site/betami...greglementmini
Ill be emailing yeah racing to see if they will offer a 39T option
Schs2013 is offline
Old 03-08-2017, 04:37 PM
  #28774
eR1c's Avatar
Wow, I miss a few weeks and tons of new questions and info on this thread.
Enjoying reading through it all
eR1c is offline
Old 03-08-2017, 04:38 PM
  #28775
interesting. the diamter of the gear only changes by 0.04" with the loss of one tooth. (1.3 vs 1.26) The gear ratio changes a bit - about 2.5%. Certainly won't make up for the 9% loss in top speed when using 55d tires.
Old 03-08-2017, 04:52 PM
  #28776
howardcano's Avatar
Trader Rating: 37 (100%+)
It wouldn't surprise me if the tooth profile were a little different to make the diameter the same, so it would mesh well without moving the motor location.
howardcano is offline
Old 03-08-2017, 05:10 PM
  #28777
tony gray's Avatar
Jim, you need to get out more, OK. You're turning into James May.
tony gray is offline
Old 03-08-2017, 05:20 PM
  #28778
I'm on the way to the track now. I'm sorry my inner pedantic nerd escaped again.
Old 03-08-2017, 06:27 PM
  #28779
banana rt's Avatar
Need suggestion here guys, im using teu esc and silver can motor with with high speed gear,, how much pinion should i use with 60D tire and Sweep pre mount tire?,, in order to maintain its top speed with acceptable temperature motor/esc.
thanks
banana rt is offline
Old 03-08-2017, 07:12 PM
  #28780
Schs2013's Avatar
So yeah racing replied to the email I sent they have plans to release a 39T later on.
Schs2013 is offline
Old 03-08-2017, 07:30 PM
  #28781
tony gray's Avatar
They should hurry up, cos no-one will buy the 38..
Old 03-08-2017, 08:14 PM
  #28782
Schs2013's Avatar
The 38 will be first from what I can understand. But I guess we shall see
Schs2013 is offline
Old 03-08-2017, 11:56 PM
  #28783
damang999's Avatar
Trader Rating: 15 (100%+)
Hi all
I have been running my m05 on carpert for the past 6 months and the setup has been pretty sweet running m and s grips .
The local group has left the carpet and now running on ashpalt and running on shimizu 60d slicks .
My car is really lacking turn in in the medium to fast corners.
Setup is as follows
Tamiya big bores 50w front 40w rear with blue front springs and yellow rears with 3 hole pistons
Ride height around 6 to 7mm
Gear diff with 10k oil
Stock silver can motor.
Tires.I have tried hard fronts medium rears then medium front soft rear .
Medium wheelbase
Im thinking im a little heavy on the shocks? Car was consistanly fast on carpet . I have never run on road ashpalt before so im a little lost for direction and any help would be appreciated
damang999 is offline
Old 03-09-2017, 10:51 PM
  #28784
Would love it if they'd make a Nissan Juke body to fit a rally version of this chassis
kenshirogenjuro is offline
Old 03-10-2017, 03:38 PM
  #28785
Try the blitz bodies...
bertrandsv87 is offline
