NOVAROSSI Engine thread....
#9241
#9244
086 without a doubt, more power basically everywhere. The 9901 is ok, but the top end is very restricted. If your track has no real straightaway it will be fine, but the 086 will feel and perform like an entirely different engine…
#9245
#9246
So I've had my mito 4 for only 2 gallons now. When I first got it, it would start at the tiniest bump on the box. Now it take about 1 minute of on the box to start it. But after it starts she runs fine.
I've noticed that some times she would throw fuel out of the exhaust so maybe she's being flooded? No leaks, new plug, clean filters. My lsn sits close to flush, my hsn is a touch in from flush.
Using byrons 30/8.
Using byrons 30/8.
#9248
You guys talking about pinch crack me up....you realize that if it's still metal to metal it's not 100% broken in right? A well done motor will last forever as long as you keep the dirt out of it and don't run it lean. Compression is a good thing....if you are only getting 3 gallons out of a motor you are failing somewhere in your process or judgement of what is a word out motor.
#9249
BUT, it's still an ABC engine, therefore zero interference when cold means there's going to be a gap at operating temperature between the piston and sleeve due to expansion.
With that said, I have plenty of old engines that have no "pinch" at all. With a lot of fuel ran through them.
They run good and I could probably use them if I needed to.
However, the first sign (in my experience) of lower compression is lack of a solid low idle. Which is when I rebuild or replace my engines.
So are they worn out?
They run.. just don't idle well.
#9251
Using byrons 30/8.
Using byrons 30/8.
#9252
To an extent, I agree with you. People get too wrapped up in "low compression".
#9253
Rex www.rwmods.com
#9254
I also put the exhaust port up to my ear when doing it, because there's even a certain sound, I'm sure you know!
Again, super hard to describe.
#9255
Who has tested the Adam Drake motor ? What pipe worked best on it and how was your fuel mileage with the motor compared to what you was driving before you had this motor? Is it an easy motor to break in or does it take awhile like the Novarossi p5 ? What the differences between P5 and a Adam Drake motor they both are 5 port?
352Likes
