Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 08-03-2016 | 09:40 PM
  #27916
gigaplex's Avatar
Speaking of droop adjustment, I just installed some big bore shocks on my M03 last night. I added the single limiting O ring as per instructions and after bleeding and installing the shocks, I find I'm stuck at 4.5mm ride height with zero droop on the rear. I guess the instructions assume 60D tires, I'm using smaller ones. Hopefully I can get enough travel back by unscrewing the ball end, I really don't want to have to rebuild them again...
I also noticed the preload adjusters are VERY loose on these shocks. I scored 4 lines on the threads with a box cutter (tip I read on here the other day) to tighten them up, and they're still too loose. Might need blue threadlock after all.
While I was at it, I installed some universal axles (53597). Had to remove the black O ring from the diff outdrive (stock gear diff) as it was causing massive binding with the universals. There's quite a bit of play now, might need to cut up the urethane bushings that came with the shocks to pad it out.
gigaplex is offline
Old 08-04-2016 | 03:50 AM
  #27917
Originally Posted by sakadachi
Also try a different motor. I could not get my V2 to run very well with torquey motors.
I am using the Reedy 21.5 as for TCS rules.. I do not have a lot of options with this...
rzein is offline
Old 08-04-2016 | 04:01 AM
  #27918
gigaplex's Avatar
You're going to get wheelspin with the stock gears in the FWD M-chassis with any brushless motor. You'll need to learn to use the throttle correctly, rather than just flooring it.
gigaplex is offline
Old 08-04-2016 | 04:25 AM
  #27919
The wheelspin is also a result of the design of the chassis, with so much weight being removed from the front wheels under acceleration. It's just a mini thing that you need to adjust your driving style around.
ErikO is offline
Old 08-04-2016 | 04:33 AM
  #27920
I will try to adjust my driving.... and my some Radio and ESC setting... thanks
rzein is offline
Old 08-04-2016 | 08:33 AM
  #27921
k_bojar's Avatar
on your throttle curve (on the radio), go negative - it'll soften the feel a little bit when you pull the throttle
or if your speedo has 'punch' control, lower it some
k_bojar is offline
Old 08-04-2016 | 09:26 AM
  #27922
eR1c's Avatar
...sorry if i missed it, are you running the stock diff' in front? If so, i'd recommend changing to the Tamiya 53070 Manta Ray Ball Diff Set. Its TCS legal -as it is a Tamiya branded part. It really tightened up the front wheels for me and stopped a lot of that wheelspin. If you do get this diff' be sure to really tighten the heck out of it when putting it together.
eR1c is offline
Old 08-04-2016 | 10:08 AM
  #27923
Some Tamiya AW grease in the diff gears also helps tighten it up a bit. Nothing like a ball diff but better than running it dry.
ErikO is offline
Old 08-04-2016 | 11:06 AM
  #27924
AngryRog's Avatar
A firm diff promotes better acceleration out of a corner. Unless your track has better than average traction, this will only exacerbate your wheel spin problem.
Try using the TC aluminum shock adjusters with o-ring on your 54000 shocks. Cured the issue for me...
AngryRog is offline
Old 08-04-2016 | 12:13 PM
  #27925
eR1c's Avatar
not disagreeing, but not sure i follow.
So a tighter diff will have increased wheel spin when traction is great on exit corner. Wouldn't a tighter diff have less wheel spin then a looser diff in this situation-assuming traction is the same for both? Please explain, ..unless I am understanding you incorrectly.
eR1c is offline
Old 08-04-2016 | 12:26 PM
  #27926
k_bojar's Avatar
another crazy question - not sure if i saw this, or dreamed is
did tamiya release a part that is essentially pegs that replace the diff balls in their diffs? kinda like the ones traxxas makes for their 'slipper diff'??
I thought i saw that release someplace
k_bojar is offline
Old 08-04-2016 | 12:37 PM
  #27927
daktulos's Avatar
You are not dreaming
Tamiya part 54424 3mm bushings for ball differential
I use them on the M05 ball diff (54194) with the M05RA hardened cup set (54238)
This is really hard on the drivetrain but the bushings help.
I am not a fan of a locked differential but on certain circonstance it help to get out fast of a corner. I was using this with a 17.5 and was more driving point and shot...
My two cents...
Alexandre
daktulos is offline
Old 08-04-2016 | 12:56 PM
  #27928
k_bojar's Avatar
My two cents...
Alexandre
thank you thank you!!!
k_bojar is offline
Old 08-04-2016 | 01:09 PM
  #27929
AngryRog's Avatar
The opposite, tighter diff will have increase forward bite when track conditions are good. Poor conditions = less pull with a tighter diff due to wheel spin.
AngryRog is offline
Old 08-04-2016 | 01:58 PM
  #27930
eR1c's Avatar
-agreed/and what I thought.
I must have mis-understood your first post.
eR1c is offline
