Like Tree649Likes
    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Old 07-18-2016, 12:32 PM
  #1681
Trader Rating: 61 (100%+)
ANyone using the MIP alum t-nut with the B6 kit outdrives? Any issue with fitment? I cant stand the new AE plastic t-nut.
Why, what's wrong with it?
Socket is offline
Old 07-18-2016, 12:44 PM
  #1682
Tech Prophet
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
too tight, I have to hammer it to get it out, lol
Wildcat1971 is offline
Old 07-18-2016, 12:46 PM
  #1683
How often are you removing that nut? Is that an everyday occurrence or?
Socket is offline
Old 07-18-2016, 12:47 PM
  #1684
Tech Prophet
Does not matter. I dont like it.
Old 07-18-2016, 01:06 PM
  #1685
Originally Posted by Allen Drebi
Just finished building all of this and found out our track is closing for good next week
Does that mean you're going to be selling them?...lol
Jade67 is offline
Old 07-18-2016, 02:25 PM
  #1686
Trader Rating: 13 (100%+)
Build done, just need to hit the track to try it out and tune. I went 100% factory settings just to get a baseline. My b5m with lay down is set up to very different so I'm curious how it drives out.
dsms4ever is offline
Old 07-18-2016, 02:30 PM
  #1687
Im running a 13.5 in blinky for pro stock. It's a small track like 16 seconds and faster and technical, I put in the 78 spur with a 32 pinion. Is that a good starting place?? Thanks
Old 07-18-2016, 02:42 PM
  #1688
awidz's Avatar
Trader Rating: 15 (100%+)
Default Chasis weights
I know these are not out yet, but what will they help out on. Trying to figure out if worth getting them for my b6 for indoor carpet Offroad. I am using the cav eos setup, but they only list total car weight on there setup sheets, they don't list what chasis weight or where they are putting them.
awidz is offline
Old 07-18-2016, 03:07 PM
  #1689
Because total car weight is more important.
That said, I believe they used both steel plates.
Socket is offline
Old 07-18-2016, 03:10 PM
  #1690
Silverstonev8's Avatar
I may be wrong but I see it showing he was using the steel weights under servo and electronics.
Silverstonev8 is offline
Old 07-18-2016, 05:45 PM
  #1691
Trader Rating: 12 (100%+)
When applying the 4 gear to the B6D, I see the specific Cover, Plate and Cases, but what you need for the idler gears?
Is it just 2 pieces of the same # 91717 these 26T ones?
190mph is offline
Old 07-18-2016, 05:50 PM
  #1692
BRSracing's Avatar
Trader Rating: 67 (100%+)
Really like the new car
Attached Thumbnails Team Associated B6 & B6D thread-20160718_194618.jpg   Team Associated B6 & B6D thread-20160718_194647.jpg
BRSracing is offline
Old 07-18-2016, 06:26 PM
  #1693
aeRayls's Avatar
It's just another of the same gear and idler shaft that comes in the 3 gear
aeRayls is offline
Old 07-18-2016, 07:54 PM
  #1694
tony montana's Avatar
Trader Rating: 76 (100%+)
If anyone is looking for a b6d absolutehobbyz has some. Also has the laydown conversion in stock
tony montana is offline
Old 07-18-2016, 08:16 PM
  #1695
If their website worked, I'd order something!
Sean B. is offline
