Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree6563Likes
USGT
Last edit by:
Print Wikipost
Old 04-26-2016 | 02:04 PM
  #4696
Kregger's Avatar
I'm disappointed by the body rule, Localy I'm not worried we can run just about any real body. It's the bigger races I may have second thoughts about.
Also gotta say I think the weight should have been left alone. I less of a problem with 1450 than with VTA old 1550.
I do want to say thank you though for giving plenty of advance warning for when the rule change takes effect
Kregger is online now
Old 04-26-2016 | 02:07 PM
  #4697
ThrottleKing's Avatar
Originally Posted by JimmyMac
I say no on minimum body weight. I would rather see the 10mm wing rule enforced instead.
It is at the larger events if using a lexan wing. Still up to your particular track on how strict the rules are followed. I don't disagree with you though. It would be great if everywhere we traveled to had the same rules so we could just get down and race. I do like the 1380wt so I can remove 60g of tungsten but that half second gap between 17.5 and GT just shrank a bit more. That would be the only downside I see to these changes.
ThrottleKing is offline
Old 04-26-2016 | 02:08 PM
  #4698
NutDriver's Avatar
JimmyMac,
Enforcement of ANY of the rules is a track/RD issue, not a rules issue.
NutDriver is online now
Old 04-26-2016 | 02:14 PM
  #4699
IndyHobbies.com's Avatar
Originally Posted by scirocco14
In addition, the Hot Rod GT isn't really a scale version of an actual car. I think we should at least be using scale bodies.
I thought the Hot Rod GT was the Morgan GT? I get it that you love it or hate it. But it is as scale as many other bodies being used in USGT.
As for the body rule changes, I don't have a problem with that. I wish the Hot Rod GT was on the list, but rules are rules.
IndyHobbies.com is offline
Old 04-26-2016 | 02:27 PM
  #4700
Trez83's Avatar
Tell me you race with that paint job? It's spectacular!
Trez83 is offline
  #4701
JimmyMac's Avatar
Originally Posted by NutDriver
JimmyMac,
That IS true. Good point.
JimmyMac is offline
Old 04-26-2016 | 02:30 PM
  #4702
Minimum body weight to encourage better paint jobs isn't really necessary, most of the Top 10 @ the '15 USIC had some pretty intricate paint, effectively rendering the "get all the weight low" crowd moot. Besides, creating an extra metric in Tech would make things more painful.
I will say I am not sad to see the prototype/GTP bodies go.
nwagner is offline
Old 04-26-2016 | 02:36 PM
  #4703
DARKSIDE's Avatar
these rule changes are for a select few....not the majority. Well enough alone was the battle cry. Now its cater to the crying that want more speed and no balls
DARKSIDE is offline
Old 04-26-2016 | 03:47 PM
  #4704
Xpress's Avatar
So the McUgly bodies are no longer legal?
Xpress is offline
Old 04-26-2016 | 04:39 PM
  #4705
How is the PFM10 still on the list? It doesn't represent any real car I have seen.
linkless is offline
Old 04-26-2016 | 05:08 PM
  #4706
It does look like the Jaguar C-X75 concept supercar.
Old 04-26-2016 | 05:40 PM
  #4707
NutDriver's Avatar
This doesn't look like a PFM-10 to you, linkless??
Old 04-26-2016 | 06:54 PM
  #4708
howardcano's Avatar
I can't answer for linkless, but for me, no, it doesn't. The front grill/air intake is entirely different, and the side air intakes are entirely different. But as I said, the PFM-10 does look like something that is well within the realm of possibility.
I'd say it looks as much as the PFM-10 as the Morgan looks to the McAllister Hot Rod... Which is: close, but only sorta-kinda.
howardcano is offline
Old 04-26-2016 | 07:00 PM
  #4709
While everyone is fired up, keyboard slam your way over to rcsignup and get registered for the 2016 USVTA Summer Slam, 29-31 July (cough last weekend of the National Championship cough). We've got a bunch of sponsors getting onboard, and some team guys making the trip this year to get the experience of a layout that only The Gate can bring you.
nwagner is offline
Old 04-26-2016 | 07:03 PM
  #4710
angrymelon's Avatar
Ouch! Right in the feels! Paint work on this one was done by the excellent Todd Daly. Mounted on a VBC Ghost EVO. Wheels and tires were just for the photos. Sadly won't look nearly as killer with the zero offset Gravity's.
forFREEDOM likes this.
angrymelon is offline
