Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree6563Likes
USGT
Last edit by:
Print Wikipost
Old 05-14-2015 | 06:51 PM
  #3946
Originally Posted by SpidarX
I like it. Now there will be two Ferraris, although I'm not quite ready to put scratches on mine yet.
That is a problem when you put the paint on the outside of the body. Too bad, I was look forward to having two Ferraris up front instead of our usual AUDI R8s.
John Wallace2 is offline
Old 05-15-2015 | 02:06 PM
  #3947
kartermdb's Avatar
I'm so close
Photobucket refuses to rotate it, so you guys can read it sideways
kartermdb is offline
Old 05-15-2015 | 02:38 PM
  #3948
Originally Posted by kartermdb
I'm so close
Did you forget the wheels, body and battery?
mooby64 is offline
Old 05-15-2015 | 03:42 PM
  #3949
I'm so close
And another 240 grams and you will be at the USVTA minimum weight for USGT.
Old 05-15-2015 | 04:00 PM
  #3950
kartermdb's Avatar
FWD FTW
Old 05-15-2015 | 06:33 PM
  #3951
patorz31's Avatar
Which chassis you running? We are starting the class up here in Edmonton and I was thinking of trying fwd.
patorz31 is offline
Old 05-16-2015 | 04:23 AM
  #3952
I have never seen a fwd keep up in usgt. The 4wd cars always walk them even with the extra weight.
Howdy_beecha is offline
Old 05-16-2015 | 05:42 AM
  #3953
scirocco14's Avatar
I have.
Mark B. came to Bush River one weekend and ran up front in USGT, despite never having seen the track before and running extra weight (1275).
At 1200g, I would NOT be surprised to see it win on the right track.
Mark C.
Last edited by scirocco14; 05-16-2015 at 09:54 AM. Reason: Talked to Mark B and got info on weight as raced
scirocco14 is offline
Old 05-16-2015 | 05:53 PM
  #3954
kartermdb's Avatar
I have a slightly modified sakura FF. The biggest thing I have found is getting the weight down. Most of the fwd cars available weigh 1350-1400 in stock form. I know thats what a local VBC weighs. Its hard to get the weight down while trying to keep a full size battery in it.
Old 05-16-2015 | 08:13 PM
  #3955
Has anyone played around with less rear toe in?
Friulimotosport is offline
Old 05-17-2015 | 04:00 AM
  #3956
howardcano's Avatar
I run all of my cars with zero toe on both ends. It works especially well on high-speed tracks, as it scrubs off less speed. I use all of the other chassis adjustments to change handling.
howardcano is offline
Old 05-17-2015 | 06:23 AM
  #3957
Thanks. I'll give it a try next time out.
Old 05-17-2015 | 06:43 AM
  #3958
beemerfan's Avatar
I've played with this a lot too. On the rear, it usually works better on big fast tracks that are well prepped with enough traction. I have occasionally run into situations where the rear end starts to whip around on me and unexpectedly spin the car out on tight turns when I'm carrying a lot of speed. Usually putting the rear toe back into the car gets rid of that.
beemerfan is offline
Old 05-17-2015 | 09:31 AM
  #3959
OttoKrosse's Avatar
Default Body selection for GT
Been running the E46 BMW M3 for the last 10 months or so (the one in my avatar), but looking for a change. Many locals like the ZL1 Camaro but I'm not one to follow what others are doing (not that I won't if it'll help), especially since a lot of guys are running the ZL1 already.
Is there another body that is an acceptable alternative that will improve the handling over the BMW?
I have an Audi R8 that is ready to go but I've been hesitating to use it because of some feedback I've heard from others that have tried it. I've only been back into RC racing for about a year now so my experience with bodies is rather limited....any input is welcomed.
Thank you,
OttoKrosse is offline
Old 05-17-2015 | 10:03 AM
  #3960
Thank you,
This is the body that's winning at our track.
http://m.ebay.com/itm/231530945103?nav=SEARCH
Joe Maxey is offline
