Like Tree352Likes
NOVAROSSI Engine thread....
Old 03-21-2016 | 11:04 PM
  #8836
dmartin's Avatar
Originally Posted by Maximo
And yes you can remove 0.2 mm from a stock Nova and still run 30% fuel...just run a colder plug like a C7TGC
So you're saying on Nova like my P5-based Maxy Cinco I can remove 0.2mm of shims and run a C7TGC on 30% with a good tune, good fuel and I won't have detonation?
dmartin is offline
Old 03-22-2016 | 06:11 AM
  #8837
Maximo's Avatar
Easy ! just have to be sure engine is loosened up
Nova's have the biggest shim stack of all the engines...average being 0.7 mm between piston and button....a stock XZB Sopeed has 0.4 mm between piston and button ( And can run a P3 )
Maximo is offline
Old 03-22-2016 | 06:29 AM
  #8838
dmartin's Avatar
Very good to know! Engine's got about 4 gallons so it's good to go. I've been looking for more top-end so I just got a 9886 per your recommendation and I'm going to throw a 41019 on it too. Should be a screamer. Thanks for the info Sir.
dmartin is offline
Old 03-22-2016 | 06:53 AM
  #8839
Maximo's Avatar
that is the main reason why OS Speeds are so fast compared to most others...having the head tight like that makes a massive difference in performance.. An engine can have the best port timing, the fanciest crankshaft, all the bells and whistles and if the head isn't tight enough it will all add up to nothing...Its amazing having a dyno and being able to see how much effect the shims have on power...egnines that are known to be mild can simply be over shimmed and can turn into total beasts just by lowering the button by a shim or two.... conversely add 0.3 mm of shims to a OS Speed and watch what happens to it ! will go from wild to mild instantly......
Maximo is offline
Old 03-22-2016 | 09:39 AM
  #8840
Maximo's Avatar
also to add here...when you do drop shims you must be careful not to run it too lean...use the glowplug as your canary in the mine and if you see any distortion in the coils its not happy..either fatten it up, run a cooler plug or add a 0.1 mm back to it....They can run really good this way but have less tolerance for being lean, thats when they will start to detonate....
Maximo is offline
Old 03-22-2016 | 08:40 PM
  #8841
bash bros's Avatar
New engine- Drake special edition 5 port
http://novarossidirect.com/ADAM-DRAK...FF_p_3411.html
Looks kinda cool, not sure what it's all about though. There's not much else out there on it, except I'd guess it's mostly based off the Rex R21 Plus5
bash bros is offline
Old 03-22-2016 | 10:29 PM
  #8842
Audiobahnaholic's Avatar
Steel bearings looks pretty basic and cheap to be a special edition
Audiobahnaholic is offline
Old 03-22-2016 | 11:40 PM
  #8843
The main question is if you do need ceramics. I am pretty sure that 99% of the drivers or lets say 100% of the non sponsored drivers do not need it.
Roelof is online now
Old 03-23-2016 | 03:38 AM
  #8844
dmartin's Avatar
I've already got a #7 plug in it from the last time I ran it in the summer. I'll pull 0.2mm of shims, fatten it up and tune from there.
What do you think about the 9886/41019 combo on a Cinco BT in a buggy? Hopefully I'm not going to lose too much bottom.
dmartin is offline
Old 03-23-2016 | 05:05 AM
  #8845
bash bros's Avatar
+1
Novarossi steel bearings are good bearings
Old 03-23-2016 | 06:03 AM
  #8846
Maximo's Avatar
it will will probably have better bottom then all the 3 chamber pipes like the 2096 and 9901
Maximo is offline
Old 03-23-2016 | 07:38 AM
  #8847
HaulinBass's Avatar
anyone know where the mc8 and mc9 plus fit in around novas plugs, got full sheet of each id like to get rid of as they are almost ten years old
HaulinBass is offline
Old 03-23-2016 | 04:42 PM
  #8848
elex300's Avatar
Hello, I'm still pretty new to nitro. I have a Mito4/021/2096 in my RC8B3. How would a 9901 perform compared to the 2096?
elex300 is offline
Old 03-23-2016 | 05:23 PM
  #8849
Diff Balls's Avatar
Slightly less top end, slightly more bottom end. Not a whole lot of difference...
Diff Balls is offline
Old 03-23-2016 | 05:56 PM
  #8850
What's the trick/purpose of the 3 needle carbs? I just pulled the trigger on a mito7 for my truggy....noticed a 3rd needle...what's really for?
motoclay is offline
