Trinity D4 17.5
Old 12-11-2014 | 05:59 AM
  #346
Originally Posted by elex300
Im not sure about using a Amp Clamp. If you use an inline you can just remove the wheels or you can remove the pinion. Some people prefer not to freerev but it's ok for a quick reading.
Is there anyway that someone with an inline checker can also copare readings with an amp clamp too to see what kind of differences there is and post it on a motor they are setting to 10 amps with an inline tool??? If so id really appreciate it.
racer888 is offline
Old 12-12-2014 | 06:11 AM
  #347
Anybody out there that can see what the difference would be between the two? I will be checking with drive train attached and wheels removed.
racer888 is offline
Old 12-12-2014 | 06:48 AM
  #348
Can someone help me understand how to optimally approach end-bell timing vs. gearing? My track recent switched to a tight layout with no straight-away, and multiple jumps that are kind of tough to make. I have a B5R. I need lots of torque, and don't care much about top end speed on this layout.
My current understanding (which could be wrong, please correct me)...
1. If I have have a high final drive ratio, that gives me more torque. I have a 72 Spur. So therefore, I need to have a smaller pinion. I have gone to 30, but now thinking about going down quite a bit further...27? 72:27 with a 2.6 gear ratio gives a FDR of 6.9. That's pretty big, I think.
2. Less timing on the end-bell = more torque. Therefore, I just put it on zero degrees of timing- right?
My confusion comes from many recommendations that seem to suggest a large FDR to generate torque, but then lots of end-bell timing is recommended. Aren't these contradictory suggestions?
Any clarification would be appreciated...
MasterBlaster is offline
Old 12-12-2014 | 10:34 AM
  #349
Ivet ried both on my sct 78/28 with 40deg timing and 78/24 with 55deg and liked the torque alot more with the second one but think i need a little more timing....
On my buggy i run 69/33 and i have plenty of torque and speed combo i can clear all jumps with a blip of throttle
Both are losi 2.0 vehicles with 2.43 trans ratios i believe
racer888 is offline
Old 12-16-2014 | 10:55 PM
  #350
Cridd's Avatar
On a small indoor track, 15-16 second laps, b5m running 72 / 32 with 58 timing. How does that sound?
Cridd is offline
Old 12-22-2014 | 11:36 AM
  #351
aloksatoor's Avatar
What gearing for a 12.5 rotor D4 13.5 in a 1500 gram RB6 MM? I bought it used off this forum and it was set at 52 degree endbell. I ran it with 78/29, motor was barely warm but lacked a bit of punch. I can cure that with a heavier battery with more punch, but wanna use my 150 gram shorty for nimbleness.
Our tracks (wet clay delta rc winter arena) getting stickier by the week and I think we would soon be running slicks. There are some short run up jumps I wanna easily clear, right now car needs to be perfectly setup so overtaking someone or in traffic it gets icky.
aloksatoor is offline
Old 12-22-2014 | 05:19 PM
  #352
Any reason to upgrade from my D3.5? Is it that much better?
joedeman1969 is offline
Old 12-22-2014 | 05:29 PM
  #353
aloksatoor's Avatar
Nope but its legal for us stock racers.
Old 12-22-2014 | 09:08 PM
  #354
Cridd's Avatar
D3.5 is not approved at most big races. D4 is. I think 3.5 is faster.
Cridd is offline
Old 12-27-2014 | 05:50 PM
  #355
Default just picked up the Trinity D4, have a question
I was looking over the instructions and it says it comes from the factory with the timing set at 30 on the endbell. However , the mark on the endbell is pointing to 50. I know the instructions said it could handle an extra 20 degrees, just wanted to be sure.
Brian87gt is offline
Old 12-27-2014 | 07:45 PM
  #356
XXXDad's Avatar
Questions?? Yes it can
With a 17.5 or 13.5 blinky setup yes 50* is good starting point and you might go a few clicks more if your motor is not too hot. Check temps and keep them 180* or cooler. What car are you running it in and what size track? Indoor outdoor? Outside temps? Gearing is KEY!
XXXDad is offline
Old 12-29-2014 | 08:22 PM
  #357
BRSracing's Avatar
How do you tell the difference looking at the big blue and regular certified motor?
BRSracing is offline
Old 12-29-2014 | 08:55 PM
  #358
Losi 22 2.0, 30 pinion , small indoor track.
Old 12-29-2014 | 10:12 PM
  #359
thecman26's Avatar
Big blue is NOT R.O.A.R. legal
Certified are
thecman26 is offline
Old 12-29-2014 | 10:52 PM
  #360
BRSracing's Avatar
Certified are
Both come in certified model i know big blue is not roar just curious if they have different markings they look alike. Seems like it would be easy way to cheat if they look the same.
