Trinity D4 17.5
#376
I was wondering if someone was still riding that horse.
And, actually, as of July 2013 that statement is false.
According to the brushless motors list posted at Roarracing.com, the Trinity 13mm are at the very bottom of the list of approved rotors.
Thanks on everything else though.
Hell yeah!
#378
They do have the inner spec shaft, but max diameter for spec class is 12.5mm
Dayton
#379
#380
The rule book hasn't been updated to reflect a 13mm rotor being approved for the 17.5 class.
Current rule as published for reference.
8.5.4.4.2 ROAR Spec Motors: External shaft diameter must be 0.125 inches (3.175mm). Only one piece, two pole Neodymium sintered, or Ferrite (Ceramic) magnetic rotors are permitted. The magnet length shall be 25.0 +/- 1.00mm not including any nonmagnetic balancing material. The magnet outside diameter shall be a maximum of 12.51 mm, no tolerance, for the entire length of the magnet. The shaft outside diameter, where the magnet is mounted, shall be 7.25 +/- 0.150mm for the entire length of the magnet. This dimension must be measurable without destroying the rotor.
#381
#382
R/C Tech Elite Member
If you are in a class that is designated "Sportsman Modified Short Course" with no motor specifically called out, does that mean this 13mm rotor would be legal?
If not, in what instance would they be legal?
Indeed. I have only heard good things about Fantom Ion motors. When I bought my D4's, the Fantom Ion V5 was on the short list of motors I was going to get, but couldn't swing the difference in price considering I was buying 4 motors at once.
#383
Sorry, I didn't mean that as an insult. I know a lot of people repeat the same information time and time again without doing research.
Thank you for the source. My question is this...
As for your sc class, it would be legal in a modified class.
The Fantom spec models are within a couple dollars of the base Trinity models.
We now offer a spec max version that includes the 12.5mm Ht rotor at a competitive price.
When you start adding tuning options is where the price goes up.
Dayton
#384
That is a question for the track you race at. Everyone around the world will not have the same answer.
#385
Again all to the best of my admittedly limited knowledge about the classes. Hopefully someone will call me out if incorrect.
#386
i'm 99% sure that the 13mm rotor would be fine. you're running modified which should mean that anything goes. if your track STRICTLY adheres to ROAR rules (which very few tracks do), then i'm not sure. it really wouldn't be much of an issue at a ROAR race. if you run a 10.5 and you think the 13mm rotor would be better, just throw in an 8.5 and call it a day.
#387
Ok correct me if I'm wrong but is this motor designed for 1s oval cars?
D4 1s Short Stack Spec Maxilla
http://www.trinityrc.net/shop/index....product_id=705
If so how would it work in a 2wd b5m buggy? I have heard these motors are ridiculously fast. Other wise I was gonna get this certified motor
http://www.trinityrc.net/shop/index....product_id=677.
Just wondering as 150 is a lot for a motor but I know they are nice. Any info is appriciated
#389
What it do' Trinity gives you a sheet with the information on it, but in case you miss used it. Take the internal gear ratio which I believe for AE .2 is 2.60:1 (same as my truck) and divide that by what you get after you multiply pinion and spur teeth. They have an optimal range in which it should fall in.
