Trinity D4 17.5
Old 08-18-2014 | 07:42 PM
  #226
Ok good to know thanks for the info
Jeepgc is offline
Old 08-18-2014 | 07:44 PM
  #227
suby723's Avatar
No prob..On a small/med indoor track I would start with 69/34 45timing.
suby723 is offline
Old 08-19-2014 | 08:58 AM
  #228
RC*PHREAK's Avatar
yeah, i was at norcal friday and started at 34/72 with 60 degrees (i ran 36/72 with about 62 degrees at delta) and it came off at 180 during practice. i bumped it down to about 45 degrees and temps were where i wanted (145-150).
RC*PHREAK is offline
Old 08-19-2014 | 10:32 AM
  #229
Pittsdriver's Avatar
I think I am 32/69 and 55 degrees of timing. I come off at 135 degrees but I have a fan. Works great at Norcal.
Pittsdriver is offline
Old 08-19-2014 | 10:51 AM
  #230
Ya I'm in NY NJ area eather high bite or med bite tracks I'll try 69/32 with 45 timing n see how it is on sat. I'll let you know thanks for info guys
Jeepgc is offline
Old 08-19-2014 | 12:04 PM
  #231
bignik957's Avatar
I'm running 69/33 with 50 deg. timing and run about 130 deg.
bignik957 is offline
Old 08-19-2014 | 03:50 PM
  #232
Originally Posted by slashman404
Anyone have an opinion on one vs the other? Want to go with the new but is there a big difference KV between the two? Thanks
i dont know the kv ratings but i have both and like them both. the killshot maxzilla is also one helluva motor too
glenng is offline
Old 08-19-2014 | 09:05 PM
  #233
Cridd's Avatar
Ranging from 69/32 to 69/34, 125 to 180 degrees at 58-60 boost on can. 69/34, small track hit 180, dropped to 32, went down to 140-150 Bigger track went to 34 and and was at 125-135.
Cridd is offline
Old 08-28-2014 | 09:40 PM
  #234
I am thinking about getting the Maxzilla or the certified 5% D4 and was just wondering which one would be better or if they are pretty simular in proformance. The Maxzilla is about $45 less and currently in stock so it worth it to wait for the 5%?
Mxer210 is offline
Old 08-29-2014 | 07:26 AM
  #235
Suspended
I think you would be just fine with the Maxzilla
Jeepy2013 is offline
Old 08-29-2014 | 03:08 PM
  #236
Do you know what the real difference is between the two? I currently am running the Schuur Speed V3 and it is fast so I just want to make sure if I get a D4 its just as good or better.
Mxer210 is offline
Old 08-29-2014 | 04:24 PM
  #237
elex300's Avatar
I ran 30/72 with 60 degrees timing at Nats in my MM Serpent that weighed 1590. Motor came off at 160 every time and had the perfect amount of low and top end power.
In the RM I ran 32/70 with 60 timing and that car weighed 1545. Came off at 160 every time.
elex300 is offline
Old 08-30-2014 | 11:08 AM
  #238
rcman182006's Avatar
What rotor in the RM Erik?
rcman182006 is offline
Old 09-05-2014 | 06:16 PM
  #239
chonchachencho's Avatar
I'm running 69/31 at 55 degrees with the 5% motor in a 1501 gram centro. its at 13.5 straight up. Geeeze
chonchachencho is offline
Old 09-10-2014 | 06:40 PM
  #240
Was the track tight? I'm having some issues with my power band. Seems to have awesome mid range power but bottom and top end is suffering. WHAT IS EVERYONE GEARING AND TIMING THEIR MOTORSSSSSS
