Trinity D4 17.5
Old 07-26-2014 | 12:46 PM
  #211
elex300's Avatar
Originally Posted by Kave
I think that's really low, I ran a D4 on a similar track last weekend and ran 33/69.
Yes but he is asking about gearing using a 72 tooth spur gear. You are using a 69. I would rather advise someone to start low and work there way up then to max it out and possibly harm the equipment.
elex300 is offline
Old 07-26-2014 | 01:14 PM
  #212
Pittsdriver's Avatar
I emailed Trinity, no response yet.
Pittsdriver is offline
Old 07-28-2014 | 05:09 PM
  #213
elex300's Avatar
What are you stock SC guys using for a set up with the d4,gearing,timing? Also are you using a cooling fan on the motor
elex300 is offline
Old 07-31-2014 | 11:32 PM
  #214
Originally Posted by SilentHunter
Thats the problem they don't answer their phone and I'm not going back and forth on emails when a conversation with someone could clear this up in 5 mins. For this I will continue to trash their weak brand and never suggest anyone to spend a dime on anything trinity.
Proudly Reedy powered
I also bought a D4 from Trackside which did not work. Also bought a Reedy too. I went to the Trinity website and did the email support deal. They had a new sensor board out to me in two days. Put the new board in and motor works fine.
slow is offline
Old 08-01-2014 | 03:19 PM
  #215
I still haven't heard a peep out of Trinity, no surprise though.
Old 08-02-2014 | 03:29 PM
  #216
Cridd's Avatar
Mine is running good, Fantom no issues. Like engine can boost at 55, coming off 155, going to try sweep body and see if the lowers temp since open more back by motor.
Cridd is offline
Old 08-10-2014 | 03:52 AM
  #217
urismo21's Avatar
I am looking at running one of these in 4wd stock in Australia. Would setting it up the same with 10-12 amp draw still work. Thanks
urismo21 is offline
Old 08-18-2014 | 05:06 PM
  #218
Any good places to start with timing on d4 running in b5 rm. gearing 69/33 or 72/32. ?
Jeepgc is offline
Old 08-18-2014 | 05:29 PM
  #219
suby723's Avatar
8th scale sized track I went to 69/40 with 20 degrees timing. 10th track I'm at 69/36 45 timing. These motors like high gearing over high timing imo.
suby723 is offline
Old 08-18-2014 | 07:14 PM
  #220
slashman404's Avatar
Default D4 17.6 MAXZILLA vs Killshot 17.5 Maxzilla
Anyone have an opinion on one vs the other? Want to go with the new but is there a big difference KV between the two? Thanks
slashman404 is offline
Old 08-18-2014 | 07:15 PM
  #221
What is motor temp after 5 6 mins. That is big gearing and realy 45 on timing? Are you running a fan n is that rm or mid? Thanks
Jeepgc is offline
Old 08-18-2014 | 07:23 PM
  #222
Default D4 17.5 MAXZILLA vs Killshot 17.5 Maxzilla
Old 08-18-2014 | 07:29 PM
  #223
suby723's Avatar
155 motor temp no fan 90degree weather. B5m 1500grams. Geared 69/40 20 timing in this video. Dont be afraid to really gear up this motor!
https://www.youtube.com/watch?v=JE1b...MetE4cbcSr_nWg
Silver car started second and finished third.
suby723 is offline
Old 08-18-2014 | 07:34 PM
  #224
How much boost running in esc. Or is that blinky?
Jeepgc is offline
Old 08-18-2014 | 07:36 PM
  #225
suby723's Avatar
Blinky orion r10 160amp. All roar spec car.
suby723 is offline
