Trinity D4 17.5
#257
Mid Motor vehicles dont accelerate as fast as rear motor. This is why I use a larger spur on my MM. My RM buggy is geared 32-34/70 where my MM is geared 28-30/72. For buggies I set the can to pull 10 amps. I cant say a specific number for the dial because it can vary from motor to motor. However 60 should be close.
Here is the track. It's large for an indoor.
https://www.youtube.com/watch?v=4g8I-mD40Yg
In actuality smaller spur gears will out accelorate a larger spur!
Larger spur gear will calm down the torque of a brushless motor, generally due to excessive wheel spin coming out of a corner. If you dont have enough pop out of a corner, smaller spur will help. Sponsored and non-sponsored guys have verified this.
Sorry but you're incorrect.
#259
After consulting several people on this matter, you're information is dramatically incorrect!
Maybe in a broader sense you are right. But w MM i noticed u simply arent as fast w same gearing u had in RM and a small tweek is needed w gearing to get the acceleration and torque needed
#260
Not so. I did the same thing erik did with mid-motor configuration. I used to use a 66tooth spur. I got no pop (torque) on clearing big doubles or triples with that spur. I went up to 72t myself and got the acceleration and torque i was missing w my 66t. Top end was hella quicker w 66t spur thou
#261
#262
I just chatted with a LONG LONG LONG time AE sponsored racer and he agreed with your statement!
Larger spure equals quicker acceleration Smaller spur gear equals more top end!
Back in the day with RM I was fighting excessive wheel spin coming out of the corners and a guy said to put a larger spur gear on it, didn't do anything with gearing it moved the motor back giving more traction!!!
I stand corrected and will adjust my knowledge base accordingly!
Maybe that's why we run the smallest spur we can get our hands on in oval!
#263
I officially stand corrected, and appologize for making a fool of myself.
#265
#266
I found my mm car would not pull the same gearing as my rm car. Not even close. Out of corner triples that were a breeze in rm were impossible with mm. Went down a couple of teeth on the pinion and it was better. Of course it lost some on the straightaway but if your casing jumps that the other guys are flying over, your in trouble.
#267
#268
Yes it was heavier. I'm going to build a lightweight mm tlr 22 soon. I'm not sold on mm in stock yet. But I have yet to try a 1500 gram one. I think rm cars look cooler and that's most important to me. When I get my lightweight mm car built I will be able to figure out if the 4th gear is the power killer I think it is.
