Trinity D4 17.5
Old 10-20-2014 | 08:39 PM
  #286
Suspended
Originally Posted by elex300
It's just as good as the D3.5 was if not better.
I agree ^^^
Jeepy2013 is offline
Old 11-12-2014 | 09:57 AM
  #287
Jochim_18's Avatar
What's the deal with this motor a lot of guys from my local on-road track seems to not like this motor because they run hot. I'm still running my 8 month old revtech killshot and it's does the job. I TQ on expert 17.5 stock blinky by 5 sec. and win the main with my old killshot.
Jochim_18 is offline
Old 11-12-2014 | 10:23 AM
  #288
elex300's Avatar
Not sure what they are doing to make it run so hot. The D4 runs way cooler then the Kill Shot does. I run stock buggy,sct,and truck all D4 powered. It's a killer motor that runs strong and doesnt fade when it gets a little warm. I found it has a nice sweet spot around 7 amps on the Extreme Motor Checker.
elex300 is offline
Old 11-12-2014 | 02:34 PM
  #289
Jochim_18's Avatar
Is that 7 amps draw @ 8.4V with no load?
Old 11-12-2014 | 04:47 PM
  #290
elex300's Avatar
Yes.
elex300 is offline
Old 11-12-2014 | 05:32 PM
  #291
thecman26's Avatar
R/C Tech Elite Member
+1 I can't seem to get mine warm! ~ 112* is as warm as I can get it geared to the moon! I have to gear it down a lot to get more torque. Its SICK fast still even at current gearing 38/69 with 40* of timing
thecman26 is offline
Old 11-13-2014 | 06:56 AM
  #292
Suspended
I was running mine in a B5M , blinky class at 69/33 @ 35 degrees of timing and I was coming off around 140 degrees after the main. It was a beast for sure!
Old 11-14-2014 | 06:19 PM
  #293
elex300's Avatar
I would drop down to 34/69 and turn the timing up to 50. That motor will come alive.
elex300 is offline
Old 11-26-2014 | 08:24 AM
  #294
Anyone running the d4 with HT rotor in a sct? I have a new 22sct 2.0 I'm looking to put this in what gearing and timing is being ran in this type of truck? it's a big track lots of turns and jumps with a 125'+ sweeping straight.
racer888 is offline
Old 11-26-2014 | 08:28 AM
  #295
The trans ratio is 2.43 on this truck
racer888 is offline
Old 11-26-2014 | 10:13 AM
  #296
elex300's Avatar
I would run 25-27/78 with 50 on the can timing.
elex300 is offline
Old 11-26-2014 | 10:34 AM
  #297
Thanks I will give it a try I'm running a 75 spur so either a 25 or 26 pinion....also have a 69 spur which would mean 23 to 24 ... either one will put me at around a 7.0 fdr does that seem right?
racer888 is offline
Old 11-26-2014 | 11:22 AM
  #298
easye's Avatar
25/75
easye is offline
Old 11-26-2014 | 11:36 AM
  #299
Originally Posted by easye
25/75
Start with 50 deg on the can still too?
racer888 is offline
Old 11-26-2014 | 05:39 PM
  #300
thecman26's Avatar
Oh trust me it's alive! I had it at 50* with the 38/69 but was looking for a lil more punch outta the corners so I dropped it to 40*.
It also isn't a stock D4, it's the super crazy matched Fantom Ion V5 with all the upgrades. Looking at CB's cut gears as my next upgrade. Trying to not buy the carbon chassis right now.
