Tekno RC EB48 Thread >
Like Tree2Likes
Old 12-19-2014 | 06:26 PM
  #13996
FastPete's Avatar
Originally Posted by turtle189mt
Do you guys run taper up or down or your 6x1.5. Pistons?
UP
FastPete is offline
Old 12-19-2014 | 06:38 PM
  #13997
Originally Posted by FastPete
UP
Thanks fast Pete
I asked Lutz he runs flat ring up, gonna try that first.
turtle189mt is offline
Old 12-19-2014 | 06:45 PM
  #13998
FastPete's Avatar
Thanks fast Pete
Ya I mean the V would be facing up.
FastPete is offline
Old 12-20-2014 | 08:53 AM
  #13999
Cain's Avatar
So like this?
Top of Shock
"V"
Bottom of Shock
Cain is offline
Old 12-20-2014 | 03:59 PM
  #14000
Originally Posted by Cain
So like this?
Top of Shock
"V"
Bottom of Shock
Yes
Old 12-20-2014 | 05:30 PM
  #14001
hi guys what are the effect on handling in the A block ( front outer sweep)???
what does putting it in the outer bushing and in the inner bushing??
thanks
segreda is offline
Old 12-20-2014 | 06:17 PM
  #14002
Interesting, I have never thought of wheel nuts and hub threads wearing. Good call.
Originally Posted by suzukipro
I can report back that the new hubs and wheel nuts solved this problem .
What I found was that the O.D. of the hub thread and the I.D. of the wheel nut each wore enough that it was possible for the threads to skip when tightened up. I noticed this as the wheel nut had a lot more side to side slop (think hula hoop) than the new hub / nut had, but viewed individually they looked fine. Anyway I must have taken my wheels off too many times to clean tires over the course of a year and a half, causing the threads to wear down.
ktacket1 is offline
Old 12-20-2014 | 07:23 PM
  #14003
FastPete's Avatar
So like this?
Top of Shock
"V"
Bottom of Shock
Yes sir
FastPete is offline
Old 12-21-2014 | 01:33 PM
  #14004
werner sline's Avatar
has someone pics of their chassis after a whole season ? how are the plastics holding up ?
what parts do break ?
werner sline is offline
Old 12-21-2014 | 01:56 PM
  #14005
FastPete's Avatar
The plastics hold up great. They really don't break, unless you have a bad crash just the right way. They take a beating.
FastPete is offline
Old 12-21-2014 | 02:23 PM
  #14006
thanks
Sweeping the arms forward makes the steering more agressive. Sweeping them back numbs the steering feel. I've tried all three position and always go back to the center dot.
MX304 is offline
Old 12-22-2014 | 07:37 AM
  #14007
Honestly I think Tekno's bearings and materials are some of the best.
I put a lot of miles on mine and am just now replacing the arms due general wear/tear/cuts on them with the new versions. There is also a slight amount of slop around the pin, but it's minimal. More than anything it's cosmetic vs required.
The only part that really wears (over time) for me are the spindle carriers. They get a bit of slop over time. Front and rear bumpers (I use the DE skid) are common replacement items every month or so.
RokleM is offline
Old 12-22-2014 | 01:10 PM
  #14008
thank you for those info, I used 2 hobao hyperstar in 2 years and they don't wear well ( soft plastics, but the metal is ok )
Old 12-22-2014 | 02:14 PM
  #14009
Numburn's Avatar
So like this?
Top of Shock
"V"
Bottom of Shock
That is going to give faster rebound, where having the taper up "A" will give faster compression and slower rebound. Most drivers run taper down "V", but a guy at my local track runs it the other way and it handles the rough stuff very well. It scrubs a lot on jumps and landings though with the faster compression.
I think it's more common in Europe to run "A" style since those tracks tend to have smaller jumps.
Numburn is offline
Old 12-22-2014 | 09:03 PM
  #14010
a propos piston : don't forget that smaller holes with a thinner oïl is better : because it is softer on small bumps and on the same time harder when fully compressing in a jump
