Tekno RC EB48 Thread
Anyone have a good e-buggy light setup for the EB48 (2S lipo, small track indoor clay) Mainly concerned with oils to run in diffs and shocks, along with springs. I have Kyosho 1.3x8 pistons front and rear.
I previously had my EB48 setup for the Blair DNC setup at my old huge outdoor track on regular 4S electronics but the track has since closed down.
For shocks, my general recommendation is if you like how it drove with full 4s pack and 8th scale motor weight on the new track, drop the springs 1 color and your oils by 2.5 or 5 wt and start from there when switching to the 2s and sc motor setup.
I don't have a full setup sheet on me right now, but most of us are running 7-7-5 now at my local track where 2s eBuggy Lite has taken off. Most of us run a stiffer suspension setup on the medium grip clay/dirt mix with super soft tires or clay/soft if you like to drive sideways.
I've been enjoying the eb48 as an eBuggy lite, but I think I'm going to try a few things to lighten it up a bit more to make it easier on the electronics. I have my eye on a few spots to cut up or dremel off. But what I'm also going to do is replace the center driveline with the lighter SC driveline for less rotating mass where it is spinning the fastest. I'll start the project in a couple weeks and make sure to document everything, as well as the weight and balance changes from the existing full car.
Note: I'm purposely not just using the SL conversion because I want it to be easier to convert back to the full thing on the occasions I get to go run outside again.
Thanks Dave! See you at a Norcal race pretty soon hopefully.
I've been a bit paranoid about heat issues too. I still have the mech brakes on, seems like it would add less stress on the electronics for a slight weight penalty. Had a lot of fun practicing with the EB48 last week.
first run of my buggy went pretty well once i got the alignment set. 18t pinion might be a tad hot though so i am gonna drop to a 17 and see how that works. Other than that i am very happy. Need to get a few more sets of tires though as the clay panther rattlers i was normally using for the track i run on turned my buggy into a drift missile on tuesday.
I just ordered my EB48.2. Anyone have a good starting setup for medium bite dirt tracks. All the tracks I run on are outdoor, larger tracks with medium to large jumps. I was just looking for a good starting point.
The Ryan Lutz and Joe Bornhorst setups work great outdoors, but indoors they probably wont be as fast as the more traditional setups using 8 x 1.3/1.4 pistons. That is, unless you drive with a heavy throttle finger like those guys.
http://www.rcmag.com/modules.php?nam...iewforum&f=334
check out the various french TEKNO EB48 used by racers
2Likes
