Tekno RC EB48 Thread >
Like Tree2Likes
Old 12-03-2014 | 04:50 PM
  #13876
Originally Posted by justinco
I don't remember the nut sticking out that far on the bottom. Is that a washer on it that I see? I thought the nut seats into the hub arm there...I will check mine when I get home.
yes, the directions say to put 2 washers above and below... so there are 2 washers between the nut and the hub arm.... if the nut is supposed to go in the arm then why would it say put washers on it?
worm304 is offline
Old 12-03-2014 | 04:59 PM
  #13877
ok, I took the washers off and the nut does fit into the arm, but....... the bottom of the screw is still scraping the A- arm.
worm304 is offline
Old 12-03-2014 | 05:25 PM
  #13878
ok... I'm an idiot... got it figured out! I had it all in the wrong order...ha!
worm304 is offline
Old 12-03-2014 | 06:01 PM
  #13879
Cain's Avatar
good deal you got it figured out!
Cain is offline
Old 12-03-2014 | 06:52 PM
  #13880
Glad you figured it out, it can be a little tricky.
Here is the pic of mine for reference just in case:
justinco is offline
Old 12-04-2014 | 05:26 AM
  #13881
I replaced with just a slightly shorter screw. If you don't use a lot of washers it can be a little long.
RokleM is offline
Old 12-04-2014 | 06:10 AM
  #13882
CORY2974's Avatar
make sure not to over tighten that screw. I check that screw after every run, it tends to back out.
CORY2974 is offline
Old 12-04-2014 | 06:43 AM
  #13883
cpt_RedBeard's Avatar
OK...NEED HELP!
Finishing up this build and have an issue with the clearance of the nut on the end of the screw that goes through the steering arm and through the hub. It gets stuck on the A arm. When the car is sitting normal without compressing the shocks it looks like the following... when I push the chassis flat it clears without a problem. I checked the and rechecked and I believe it is assembled correctly. Per the instruction, the initial bumpsteer setting two washers above and below the steering ball link. I took one washer out from above and below to see if that would help, but it didn't... I made sure I am using the correct ball with the flange faced correctly. I hope I explained it correctly and the picture helps. Thanks for any help you could lend!!
Lately I've been flipping the screw around. That puts the head of the screw into the recess for the nut and lets the extra threads stick out the top.
cpt_RedBeard is offline
Old 12-04-2014 | 10:26 AM
  #13884
Numburn's Avatar
That is a good idea. If you go to the 15 degree caster blocks the threads sticking out become an issue.
Numburn is offline
Old 12-04-2014 | 10:29 AM
  #13885
Cain's Avatar
think I am using a button head screw personally ...
Cain is offline
Old 12-04-2014 | 10:50 AM
  #13886
FastPete's Avatar
That's what I do
FastPete is offline
Old 12-04-2014 | 06:28 PM
  #13887
WonTonsChicken's Avatar
I know of a width difference.. Maybe..
But, has anyone tried putting the nitro body on the electric car?? Im kind of a fan of that body, and think it might be something different..
Just wanted to see if anyone has redly available pics of it..
WonTonsChicken is offline
Old 12-05-2014 | 05:14 AM
  #13888
i had 2 washers between the nut and the arm.... obviously incorrect..i'm good to go now... botton head screw def makes more sense to me in that applicatation... not a priority but i'll probably get around to switching that..
OK big quesiton...
My hobbywing M6C combo arrived yesterday! 1800 kv and 150a... is there anything specific I need to know about choosing a pinion with the 44t stock spur gear? I have a 17 and 18t that I am not using on my 8.2e... Will those work? The combo came with 13 and 21t... any suggestions if I am mainly bashing at this point and runnig 4s but plan on buying a 5s battery? for my first attempt at racing I will probably get some experience with my 8.2e rtr, I would rather destroy that one first! ha!
worm304 is offline
Old 12-05-2014 | 05:53 AM
  #13889
I geared my 2050 at 16 and it's sweet. So 18 on the 1800 should work. Pretty sure it's either the start of this thread or something they have a pinion guide
Vegetable is offline
Old 12-05-2014 | 06:16 AM
  #13890
thanks! I couldn't find it but a chart will be super helpful.
any other suggestions would be great!
worm304 is offline
